Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
TI 84 Calculator has unwanted tabs at bottom of Y= screen.......?
When I open my Y= screen there are 5 tabs at the bottom: an equal sign, and greater than and less than signs. And in the upper left corner next to the Plot1 there is an X=. Also, in the WINDOW the first thing it asks for is the ShadeRes= instead of Xmin=. It still shows Xmin= and all the other stuff like Xmax= but that's under the ShadeRes=. Plus, in my GRAPH screen there are tabs at the bottom that say Shades, PoI-Trace, and (?). They don't even work when I press the buttons at the bottom of the tab. I think all the tabs are there because I was exploring the App4Math and CabriJr Apps. It must of changed one of my settings. But how do I change my calculator back without deleting any Apps or Prgms.
  • 11 Answers
Ok, your calculator is running the program Inequalz
what you have to do is
go into APPS, go to the program Inequalz, and it will give you options. choose the one that says 'Quit Inequal'
that should work
Posted on Mar 01, 2009
How do you use the equal sign on the ti-84
The equal sign of the TI83/84/Plus is a relational operator like less than , greater than, less than or equal to) You use it when you are testing if two values (numbers, expressions, or matrices) are equal.
For example, if in one your programs what you do at a certain time depends on the equality of two expressions, you test the equality by a statement :
If A=B do this action.
Jan 30, 2012 | Texas Instruments TI-84 Plus Silver...
My y= window now has 5 boxes, an = ,<, greater than or equal sign, > and a less than or equal sign on the bottom of the window and my graph window now has three boxes on the bottom that have...
Somebody went to the APPS menu, scrolled down or up to reach an applications called INEQUALZ. When executed it remains in memory until it is kicked out. Do the same operation as described above and press INEQAULZ. In the subsequent screen select the option that says Uninstall or quit Inequalz.
Aug 08, 2011 | Texas Instruments TI-84 Plus Calculator
For my Ti-84 plus edition when I type in the graph equations there is an equals sign, a greater than sign, a less than sign, and some other signs at the bottom of the screen. How do I get rid of this?
You, or someone else played with INEQALZ (inequalty graphing) applications. The problem is thet it remains in memory and takes over the graphing duties from the native OS. If you do not want Inequalz to manage the graphing, just kick it out of memory.
Press [APPS¨] key.
Use arrows to scroll through the list of APPS.
Locate INEQALZ and highlight it.
Press [ENTER]
In the new screen INEQALZ RUNNING, press the number that corresponds to the option Uninstall.
Feb 23, 2011 | Texas Instruments TI-84 Plus Calculator
How to you change Y1 great than or equal to, to =
If you are running the Inequalz application, you can access the menu tabs at the bottom of screen by pressing the [ALPHA] key. Thus pressing [ALPHA] [Y=] in [Y=] editor puts an [=] sign after the Y-variable.
Oct 14, 2010 | Texas Instruments TI-84 Plus Silver...
Where are my less than and greater than signs on my TI-84 Silver Edition calculator?
The less than and greater than signs are above the "(" and ")" keys.
Hope this helps.
Apr 11, 2010 | Texas Instruments TI-84 Plus Silver...
Where is the equal sign on the ti 84 plus
hello sir, Press "second" "math", and it should be the first thing listed. If you need other commands hit "second" "0" that will enter the catalog and you can press any letter (without hitting alpha) to jump to that letter in the list. Please click on the following link to see the manual of the TI-84 Plus Calculator:
kindly rate me.. thanks for using fixya..
Mar 03, 2010 | Texas Instruments TI-84 Plus Calculator
On my Y= menu, Y1 has a greater than or equal to sign instead of = also, at the bottom of my screen an equals sign, a less than or equal to, a greater than, and a greater than or equal to, are lined up
You are running the application called Inequalz. You must uninstall it (NOT DELETE) to return to the normal calculator configuration.
Press [APPS]. Scroll down to find Inequalz. Highlight its number in the list and press {ENTER]. You will see a screen Inequal Running and
  1. Continue
  2. Quit Inequal
  3. 3:About.
Press [2:Quit ..]
Your calculator will unload it out of memory.
Hope it helps.
Dec 04, 2009 | Texas Instruments TI-84 Plus Silver...
I have 3 unwanted tabs at the bottom of my TI-84 graph screen : Shades, PoI-Trace, ? How can I get rid of these? Thank you!
Natively the OS of the TI84 does not use tabs: It only uses menus and submenus. These tabs come from the game or application you were running before. Terminate the application and clear the RAM because third party applications have a tendency to linger in memory.
Hope it helps.
Nov 18, 2009 | Texas Instruments TI-84 Plus Calculator
How would you enter the following equation to graph on a TI-84 Plus Silver Edition calculator? 2 <= t <= 9
To enter the inequation you split it into two inequalities
Graph is as follows
Use [2nd][CATALOG] to access the relaional operators less than or equal, greater than or equal, and the operator AND.
To access the inequality signs scroll upwards from abs( to reach the bottom of the catalog.
Note: You can use t as variable only in parametric graphs. Use x.
Hope it helps.
Oct 19, 2009 | Texas Instruments TI-84 Plus Silver...
I do not know how to find the greater than and equal to sign on the ti-84 silver plus calc
press 2nd, then math. It will bring you to a menu with =, not equal, >, <, and that kind of stuff
Feb 28, 2009 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
1,612 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
