Question about Thermos Leak-Proof Travel Bottle - JMW500PBR6
I need a lid for thermos JMW500PBR6 - Thermos Leak-Proof Travel Bottle - JMW500PBR6
Why after cleaning my thermos with bleach does it no longer holds heat?
The bleach would not have affected the inside of the thermos, but it may have deteriorated the seal of the cap? Try filling it with water, cap it and turn it upside down and leave it for a few hours, see if you get a leak. Or you could submerge it in the sink and look for air bubbles.
Mar 02, 2015 | Stanley Classic Vacuum Thermos 16-Ounce...
I need a lid clip for thermos grill 2 go part no. 11-6047-012-200 model no. 4656110
You can purchase them from this site: http://www.grillparts.com/thermos/
Jun 15, 2014 | Vacuums
How do i set the thermo sensor 433mhz to my westclox 70034 model
Hi, First check the both channel of clock and thermometer (you can see the controler in battery insertion of thermometer and you can set up channel by pressing ch button on the clock)
Next press F/C search button until the clock find thermometer and press F/C search button again.
Oct 11, 2010 | Vacuums
The top of my 500ml/0.6qt thermal vacuum flask is broken and i'm not sure if i can get a replacement as the thermos is still okay. i would be grateful to know if i can get a replacement top so i don't have...
Well yes you can purchase a separate flask for your thermal vacuum, you may purchase them from the dealer or you can please post the brand of your thermos so we can help you to find the part.
Good Luck!!
Thanks
Aug 04, 2010 | Vacuums
Sharp steam cleaner starts but soon turns off and stops sounds like a thermo problem. where can I get a replacement thermo?
Nowhere they don't ell them...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
May 26, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I have an older Electrolux canister vacuum - model #2100 and the temperature sensor shuts down the motor. How to I take apart and clean?
Check to be certain the thermo lite is on and not the bag full indicator. The thermo detector is very reliable, but the bag fill valve often fails. If it is the thermo, check your hose and wand for blockage by dropping a coin through them,before opening the vac itself.Otherwise you may have a bad set of motor bearings causing the motor to overheat due to its age.
The 2100 and all its canister cousins made since 1982 seem to be prone to failure of the dial valve on top cracking internally. The causes the bag full indicator to come on and the vac to shut down.
To open the vac you will need to slide the locking keys and bumpers forward with the bag door open. Do this with a set of pliers. Once done the vac will open from front to back like a **** shell. Be careful to look at the underside hinge are of the bag door before separating and mark and locate the wiring harness . This vac only goes back together one way, perfectly assembled it pops together with ease. If any piece is out of line it`s like a RUBIKS Cube. Take your time . OEM parts are only available through an AERUS Elctrolux dealer or repair shop
Dec 14, 2009 | Electrolux UltraLux 2000 Bagged Canister...
My daughter purchased a Steam iron Make
Don a thermo fuse can generally be bought at an electronics parts store or Radio Shack type outlet in the hobby parts area. Like any other fuse they are rated specific to the requirement of the appliance, do NOT use a higher temp one.. If you have warranty, ( likely 1 year???), return the iron, If you replace it, it is generally an in line crimp. I would only attempt it once as the iron may be defective.
Sep 11, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Our vacuum (a miele S718) has cut out.
Probably WAY too late to help you now, but may be of assistance to others (I repair appliances): Several times, I've had Miele Vacs which show the red light, but the motor never powers up. If the vac was working perfectly before, 98% it will be a bad solder joint on the Motor pcb. Although it varies per vac: Remove the bag & 4 screws around.
Unclip & remove lid (flex off pivots), then remove centre screw. Lift off control panel. Remove all other screws under the control panel area.
Lift out motor & unscrew motor pcb. Turn over & inspect for any black joints - repair as ness. Reassemble in reverse order - note: difficult to locate top cover back on if lid wasn't removed, as lid power connection can interfere. Hope this helps...
Jan 31, 2009 | Miele Red Star Bagged Canister Vacuum
Windtunnel
The thermo is a small square piece with two wires coming out of it. Did you check the switch? The switch has a high failure rate.
Dec 23, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Thermos Leak-Proof Travel Bottle - JMW500PBR6 Logo
41 people viewed this question
Top Thermos Vacuums Experts
JoeVacs
Are you a Thermos Vacuum Expert? Answer questions, earn points and help others
