Question about Sewing Machines
My toyata SL3455DS first thread ( yellow ) is not sewing withother threads have tried tension do i need a new tention spring or can i leave first needle unthreaded
FIRST THREAD (YELLOW ) IS LOOPING & NOT SEWING IN WITH THE OTHER THREADS IT IS GOING THROUGH BUT NOT STITCHING HACE TRIED PLAYING WITH TENSION NO LUCK. DO I NEED A NEW TENSION SPRING ??? WILL IT STILL STITCH IF I LEAVE FIRST NEEDLE UNTHREAED MAKING IT A 3 THREAD MACHINE. THANKS CAROL.
  • Carol Nicholson
    Carol Nicholson Jan 16, 2013
    i changed both needles but no difference
  • Sewing Machines Master
  • 7,365 Answers
Try changing the needle first and see if that solves the problem
Posted on Jan 10, 2013
  • it sounds like it is time and the machine needs to be serviced
SOURCE: looping underneath
I watched a 'You Tube' demo that showed ........if you loosen or tighten the very small screw at the base of the bobbin this gives you the correct tension & stops the looping under the fabric........I didn't even know this screw existed ! It is trial & era at first re the correct tension but you do get there.... the art is to do it in small mini stages.....like you hardly move it ! Thanks to 'You Tube' I can now get on and finish my drapes !
Posted on Nov 24, 2009
Mongo32
  • 111 Answers
SOURCE: my machine is not stitching
needle in backwards?
Posted on Jun 13, 2009
  • 96 Answers
SOURCE: stitching loose. won't thread the fabric
try to rethread the machine all the way back to the spool of thread and check the top and bottom tensions on scrap of same fabric
Posted on Dec 13, 2009
  • 13 Answers
SOURCE: Needle thread tension is too tight even at minimum
if you are routing the thread through the round button-like guide on top, you are not supposed to.
Posted on Mar 05, 2010
  • 1116 Answers
SOURCE: Needle thread looping underneath, threads not interlocking at all
If the machine is now threaded, lift the presser foot.
Now, pull about 10" of thread through the needle.
The next time you thread the machine, lift the presser foot first.
When the presser foot is up, the tension control opens and allows the thread to "seat" into the control, then when the foot is down the control closes to the indicated setting.
When threading the machine with the foot is down, thread does not enter the tension control and when you start to sew, there is no tension on the thread.
No tension = loosey, goosey, loopy stitches underneath.
Because the lack of tension on the top thread, the bobbin thread cannot lock a proper stitch.
Posted on Mar 10, 2010
Will not sew,looks like its sewing but can pull right out. have changed needle, rethread,checked tension, not changed bobbin tention got any ideas
the needle thread is not picking up the bobbin thread
could be a case of needle /hook timing, not pulling the bobbin thread down the slot in the bobbin case to under the spring
Take it to a sewing machine repair shop for a service
Jan 05, 2016 | Sewing Machines
Bobbin tention
general guide - full bobbin if threaded into the bobbin case , there is a small screw on the spring - the correct tension is - when whole bobbin case with bobbin inside - being held by thread (like yo-yo) and the lot should drop just a fraction when jerked down-up a little. Then match the top thread tension.
Nov 06, 2015 | Sewing Machines
How do I adjust tension on a Necchi Lydia 510 sewing machine?
loops under fabric means top tension needs to be tightened
try cleaning the top tension dial with some unwaxed dental floss and see if that helps. if it doesn't then the tension dial may need to be replaced
also check to make sure the spool of thread is not getting caught on the spool holder
also try a new needle--one that is correct for the fabric being sewed
Feb 10, 2015 | Necchi Sewing Machines
Toyota SL3455DS overlocker tension problems
Did you thread in the proper order? Upper looper, lower looper, needles from right to left?
Oct 06, 2012 | Sewing Machines
Bottom tention thread loose
try adjusting the top thread tension up one number till the stitches look normal
Feb 07, 2012 | Singer Inspiration 4212 Mechanical Sewing...
I need to adjust the bobbin/lower thread tension on my Freesia Viking sewing machine.... Now I know why it was sold. I sew lots... but am at a standstill on how to remove or get to it to adjust it..
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 08, 2011 | Husqvarna Freesia 415
Needle keeps jamming, won't thread
Good day!
Good day!
Jun 07, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
My singer curvy 8780 has a timing issue the needle is scraping on the bobbin casement and will not sew,cleaned and oiled, changed needle turned off and on. any suggestions?
Good day!
Good day!
Jun 06, 2011 | Singer Curvy 8770 Electronic Sewing...
Keeps skipping stitches and knots thread
Good day!
Good day!
Jun 06, 2011 | White Sewing 2037 Mechanical Sewing...
Could not adjust both looper thread tention on singer ultralock
When servicing these machines I have found that the cover over the tensioners needs to be removed so you can see if there is more adjusting possible. If its a newer serger you would hold the knob somewhere in the middle (4-5) and adjust the knurled part that goes through it. Many times I have had to rebuild these tensioners as they get dirty and need cleaning and adjusting. It may take many tries until you have it adjusting correctly. But it needs to be done.
Feb 12, 2009 | Singer Sewing Machines
Sewing Machines Logo
32 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
