Question about Cisco 4027668 - DPC3010 DOCSIS 3.0 Cable Modem
Registry keys update - Cisco 4027668 - DPC3010 DOCSIS 3.0 Cable Modem
My computer avg antivirus is not working?
first of all remove the avg from you computer then remove in registry files too
Click Start, and then click Run.
In the Open box, type regedit, and then click OK.
In Registry Editor, locate the following registry key:
HKEY_LOCAL_MACHINE\SOFTWARE\
here you find avg key delete that key and restart you computer and make new installtion of avg after install register with key if you d'nt have key go to this link...
http://www.debrastagi.com/2011/09/avg-2012-serial-keys-all-type.html
then update you are internet security and restart again its will work fine...
good luck
Apr 15, 2012 | AVG Internet Security 2011
While trying update my Adobe reader, i got the message of the updater: error 1402: could not open key: HKEY_LOCAL_MACHINE\SOFTWARE\... i have tried to uninstall the Adobe reader from the control panel,...
The error is in a registry file.....you need to repair the registry...you can use any registry mechanix for it.....try downloading registry mechanic and running it on your system.
Feb 15, 2011 | Computers & Internet
Since downloading the suggested Ceedo update Ceedo will not open. A message tells that the module cannot be found. How can I recover Ceedo?
Your Ceedo drive does not need to be connected when the steps below are carried out
  1. Click start ' run, type in regedit, and click OK
  2. When the registry editor opens, click on Edit ' Find, and type in menushowdelay and hit the Enter key on the keyboard
  3. When the first MenuShowDelay registry key is found, press enter to edit the key's value
  4. Change the value to 400 and hit Enter again
  5. Hit the F3 key to automatically search for the next MenuShowDelay registry key
  6. Change the value of the key to 400
  7. There are four MenuShowDelay registry keys. Each of these keys must have the value changed to 400
  8. When all four MenuShowDelay keys have been edited, close the registry editor and restart your PC
  9. When you reach the desktop again, connect your Ceedo drive and lauch Ceedo
The issue should now be resolved.
If you need more help come back.
Post / thumbs / testimonial are welcome!
Dec 22, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
I could not open my web cam
check for ur driver, install updated driver, check registry key of diver, go to device management and check the device , clean registry key of driver and enable it use registry cleaner reg in out may solve it
Sep 12, 2010 | HP Pavilion dv6000z Notebook
My samsung laptop n148 win7 are redy but web cam are not workin plese tell me solution
update ur driver for web can, if there is an error in the driver registry key it could be the cause, run registry fix tool
first update the driver for web cam
reginout is registry fix tool
Aug 19, 2010 | Samsung Computers & Internet
PROBLEM IN INSTALLING AUDIO DRIVERS
Hi, could you explain further! but in the mean time to check for driver problem. Go to start key then control panel, system, hard ware then device manager. Any problems will be high lighted by a yellow key, click on the + sign. you can right click audio and update your driver i.e from disk.
Hope this helps, if not come back to me with further details.
Jul 19, 2010 | Microsoft Windows XP Professional SP3 Full...
Runs for about 5mins and screen goes grey
Uninstall unwanted Programs: Unwanted programs installed oncomputer may cause Slow Windows XP issue on your computer. The best way to fixthis problem is to remove unwanted programs from your computer. Here are steps: 1. Click on Start button on thetaskbar.
2. Click on Control Panel.
3. Double click on Add or Remove Programs.
4. Select the application which is not in use.
5. Click on Remove button.
6. Follow simple instructions.
7. You are done. b> Update drivers: Outdated drivers often result inslow performance of PC. What happens is that duplicate keys are created whenprograms are updated or reinstalled. It is always good for your computer tokeep your device drivers updated. b> Why Windows XP Lags? Cluttered or fragmented registry isroot cause behind Slow Windows XP . When registry is cluttered the XP wouldresult in poor program executions, freezing during load time and it alsodecreases overall PC performance. Damaged entries in registry also cause Javascript errors, Windows errors and blue screen errors which are extremelyharmful. b> How to clean your registry?: The best way to clean your registryis to download and utilize a good registry cleaner. This software will scanyour registry for errors, corrupt keys and links, duplicate and unneeded files,and it will fix and eliminate what you need, all at the click of a button. Agood registry cleaner such as RegInOut will also defragment and organize yourregistry, recover lost keys, and perform regular scheduled scans to keep yourregistry into shape.
May 15, 2010 | Acer TravelMate 2355 Notebook
Dell optiplex 280 dvdrw drive not regonized
It may be a registry issue .Try following steps but remember take a backup of your registry (upper filter & lower filter)
Using Device Manager
To fix this error, first try to update the driver from the Device Manager. To open Device Manager, right-click My Computer on your Desktop, and then on the Hardware tab, select the Device Manager button.
In the Device Manager window, identify the CD or DVD drive item (with Yellow exclamation mark), right-click on it and select Update Driver. Follow the screen instructions to update the device driver and restart your PC.
Using Registry Editor
If updating the driver does not resolve the problem, it indicates that there is a problem in the registry. To fix this problem, you may have to remove a few keys from the registry.
Note: Be careful while working with the registry editor because changes done to the registry using the Registry Editor are irreversible and mistakes can leave you with more problems than when you started. Therefore, it is recommended that you make a backup of the registry before proceeding with the changes.
After you have removed the registry keys listed below, you will have to reinstall all applications that you use for CD or DVD recording to make them work properly.
To fix the error by editing the registry, perform the following steps:
  1. Exit and close all applications currently running on your PC.
  2. On Start > Run type Regedit and press the Enter key.
  3. Next, navigate to the following registry key:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\ Control\Class\ {4D36E965-E325-11CE-BFC1-08002BE10318}
  4. Delete any of the following registry entries if they exist under this key:
    • LowerFilters
    • LowerFilters.bak
    • UpperFilters
    • UpperFilters.bak
  5. Restart your PC and open My Computer to ensure that the CD-ROM drive is visible.
  6. Also, open the Device Manager again to ensure that the yellow exclamation mark and the error code is now gone.
  7. Restart your PC and open My Computer to ensure that the CD-ROM drive is visible.
  8. Also, open the Device Manager again to ensure that the yellow exclamation mark and the error code is now gone.
Preventing System Errors
To prevent frequent system errors on your system, you must take care of the following:
  • Be a vigilant and aware user by being careful about the websites you visit and the email attachments you open.
  • Do not visit dubious websites and do not open attachments that come with unsolicited mails.
  • Implement antivirus and antispyware programs on your system, keep them updated, and run them regularly to prevent any malware infestation on your PC.
  • Keep your operating system, device drivers, and installed applications updated with the latest patches and security updates released by their manufacturers.
  • Use system utilities included with your Windows system to perform regular system maintenance.
Mar 22, 2010 | Computers & Internet
Missing dll
When you start the computer, you see an error message similar to " S32evnt1.dll. An installable Virtual Device Driver failed DLL initialization."
Solution:
To fix the problem, edit the registry and restart the computer. Then update the Symevent files and restart the computer again.
Follow the directions for your version of Windows:
To edit the Windows XP registry
  1. On the Windows taskbar, click Start > Run.
  2. In the Run dialog box, type regedit
  3. Click OK.
  4. Go to the following key:
    HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlVirtualDeviceDrivers
  5. In the right pane, delete the VDD value.
  6. In the left pane, right-click the VirtualDeviceDrivers key, and then click New > Multi-String Value.
  7. Type VDD for the name of the new value.
  8. Exit the Registry Editor.
  9. Restart the computer.
To edit the Windows 2000 registry
  2. In the Run dialog box, type regedt32
  3. Click OK.
  6. On the Edit menu, click Add Value.
  7. In the Value Name box, type VDD.
  8. In the Data Type drop-down menu, click REG_MULTI_SZ, and then click OK.
  9. Exit the Registry Editor.
  10. Restart the computer.
To update the Symevent files
  1. Follow the directions in the document Updating the Symevent files.
  2. After you update the Symevent files, restart the computer.
Oct 22, 2008 | Compaq Presario 5000 PC Desktop
Dvd rw
Please go through the below provide steps.
Fixing Code 39 Error
If your CD-ROM drive is not visible in My Computer, you may see the following error message displayed with the CD or DVD drive item in your Device Manager. (Steps to open Device Manager are discussed later in the article.)
"Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)"
    • LowerFilters
    • LowerFilters.bak
    • UpperFilters
    • UpperFilters.bak
Thank you........
Sep 18, 2008 | Computers & Internet
Cisco 4027668 - DPC3010 DOCSIS 3.0 Cable Modem Logo
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
brian soufane
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
