Question about HP OfficeJet 7310 All-In-One InkJet Printer
Hp 2355 all in one error message
Hp printer had a paper jam. Paper was removed. Another paper jam error appeared, with a "lift top" message. No paper was jammed.
After restarting the printer, this message appeared:
oxc0620004
411:lib micci2.c
How can I fix the errors?
Patty
I found a paper jam, cleared it, cant find any broken pieces, triedresetting with and without the printer carriages, and still get theerror code. Now I am trying to find the firmware file on the site andcant.
  • 2 across Jan 21, 2009
    Thank you so much. But, it didnt help. When I turn it back on it tries to start, then there are 3 clicks, as though something is trying to happen but cant, and then it smells of ink.
    Scholar:
  • 97 Answers
open the rear access door and clean the rollers with a cloth, dam it with little water and unplug the machine and press and hold the ON button for 1 min and release the button and plug in the power cord, it should resolve the issue.
Regards,  raj_p5983
Posted on Jan 21, 2009
Getting an error message of 0xb900009f on my HP
Most likely problem is paper Jam of some paper particles are still present on paper pick up rollers gears, printer needs physical inspection
Aug 05, 2012 | HP PSC 2355 All-In-One InkJet Printer
Hp 4345 won't lift paper says paper jam. I open the tray close it and it works for one paper. Then it happens again.
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Jul 31, 2010 | HP LaserJet 2840 Printer
My hp psc 2355 keeps on sayin CARRIAGE JAM
Hey
I gues this video in youtube sloves your problem
please let me if you face further problems
Thanks Anil
Jun 14, 2010 | HP PSC 2355 All-In-One InkJet Printer
Hp Officejet L7480 false paper jam message. Resetting the printer has no effect.
Hp paper jam error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
May 20, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
reset to factory defaults, also check the whole printer for paper jams. A paper jam can often casue smaller pieces to get stuck in gears or rollers. The message about opening and closing the lid is how the printer knows you went in to check it and closeing it triggers it to try again. If thers still a jam it will keep giving the message. The fist jam was caused by something, check and make sure there isnt any pieces of plastic broken off inside. If it has a rear access panel, check there also.
Feb 16, 2008 | HP PSC 2355 All-In-One InkJet Printer
Hp 2355 all in one
Does the same message come up when you try to copy?
Oct 28, 2007 | HP PSC 2355 All-In-One InkJet Printer
HP PSC 2355 paper jam
I had the same problem. When I inspected the printer inside I detected that on the right sight of the metal thing that's guide te cartridge holder some plactic piece had broken.
When I glued it, everything went OK for a couple of minutes. Because of the presure on that plastic nock it broken again and the same error appeared on the screen.
Sep 21, 2007 | HP PSC 2355 All-In-One InkJet Printer
HP PSP 2355
the only thing that can be done is to go to your printers and faxes folder and looking for your HP printer icon, right click on it and select uninstal, switch off and remove printer from the usb port Next go to add/remove programmes and look for any HP printer software listing and uninstall it and restart the pc. If you have the installation cd that came with the printer reinstall the driver and when prompted reconnect the printer to a usb port preferebly a different one than before if you have spare and continue. reset the HP printer to the default printer if not already been prompted to do so by the software and try again printing, if the result is the same the printer itself is faulty and requires servicing or replacing
Jun 24, 2007 | HP PSC 2355 All-In-One InkJet Printer
Out of Paper. Load Paper Error
Check
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00265823&cc=nz&lc=en&dlc=en&product=422000&dlc=en&lang=en
HP PSC 1600 and 2350 Series - Paper Jam or Paper Feed Problems"
When the all-in-one detects a paper jam, the following message appears: Paper jam: Press OK to continue . The computer might display the following message: There is a paper jam (or misfeed). Clear the jam and press the Enter, Resume or OK button on the HP PSC. This document will assist in correcting paper-feed problems such as paper jamming, print slanting, and multiple pages feeding into the all-in-one. s.gif Clearing paper jams
Jul 28, 2006 | HP PSC 2355 All-In-One InkJet Printer
HP OfficeJet 7310 All-In-One InkJet Printer Logo
362 people viewed this question
Ben Johnson
