Question about Garden
Product is LED grow light, not flat panel TV
I specifically ordered 250 nm wavelength for a reason; 230 nm is not acceptable. Your website plainly states the light is 250 nm. this was bought as a gift, so now time is critical.
2 Suggested Answers
pumpkinman
  • 1144 Answers
SOURCE: 400 watt grow light
ballast is weak ,or the bulb. i would never by the combo lights /use a hi pressure sodium for both vegative state and flowering.you dont necessarily need a MH..
Posted on Jan 03, 2010
I have a Samsung led tv model number un50h5203af. I have black lights and audio but no picture. Which board should I replace? Do you have a website to order parts for this tv? Thank you so much!
Normally the T-Con board will cause this loss of video image. You can order parts from any of the many TV parts suppliers online, just Google "Samsung TV repair parts" Remember this is just a guess since the diagnostics have not been run.
Dec 05, 2016 | Samsung 50" Black LED 1080P Smart HDTV -...
I have a samsung led smart tv 50 inch model UA50F6300AMXXY we have sound but no picture. when you shine a torch to the screen you can see images, any idea what the problem could be? Thanks
The inverter board that is used for led powering has failed or some of its connection isnt good. That is the reason that you can see picture but the panel doesnt light up. Try finding am inverter board for the specific model or send it back for repair claiming that it is their device malfunction.
Oct 21, 2016 | Samsung Televison & Video
5000mw Pointeur laser vert puissant
Sorry I don't understand your symptom description.
Jan 10, 2014 | Televison & Video
Why is it recommended to have a roof aerial for the DVBT broadcast? a; In order to receive any signs of DVBT broadcasting stations, from a great distance b; In order to receive more signs of any D
First thing to think about is what frequency of radio is DVBT on ?
I think you will find that the Analogue tv was VHF where as digital tv is on UHF .
This means that the wavelength of radio signals on UFH is smaller and as a result radio waves do not bounce as readily in the Air and thus the coverage range is less efficient as compared to VHF.
Also being a smaller wave length a new antenna that can cater for the different frequency ranges of digital TV would be required
To efficiently receive a radio signal the antenna's yagi elements have to each be at a length that is at a multiple of the wavelength of the radio frequency. Either 1 or 1/2 or 1/4.
wavelength = speed of light (299792458 metres per second)/ frequency in hz
Feb 26, 2013 | Televison & Video
What is the best grow lights to grow *********
That depends on what you're trying to grow and what phase the plant is in. Certain plants are adapted to grow in the shade or in warm, sunny environments. Depending on the plant, one type of light may work better than another. For example, if your plant needs a shadier environment, then a regular incandescent bulb may work best.
The other factor that goes into choosing the right grow light is what phase your plant is at. For example, a high-pressure sodium bulb may be best when your plant is in the flowering or fruiting stage.
Personally, I love using LED grow lights. Modern LED bulbs are more energy-efficient (they produce more light with less power), so they cost less in the long run. They also produce less heat, which means you don't have to worry about a ventilation system. Plus, they emit light wavelengths that correspond to the peak absorption peaks for most plants.
When choosing your bulb, you should look at the requirements of the plant and how those requirements change as the plant continues to grow. Keep in mind that the larger your plant gets, the more light it will need, so plan ahead.
Feb 07, 2012 | Jump Start 4' Fluorescent Plant Grow Light...
Recently I purchased Toshiba REGZA 47 XL 700 E is LED. Is this TV LED ?
Yes and NO your tv is a LED. To be exact it is a LED Backlight LCD TV. An LED-backlight LCD television is an LCD TV that uses LED backlighting instead of the CCFLs used in traditional LCD televisions. It is not a true LED display but is called "LED TV" by some manufacturers.[1] The use of LED backlighting has a dramatic impact, resulting in a thinner panel, less power consumption and heat dissipation, and a brighter display with better contrast levels. You can go to http://www.regza-asia.com/pdf/LEDTV/XL700/47XL700SPEC.pdf and look at the complete specs for your tv
Mar 07, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
My TV won't turn on
Ur tv have LED front panel power indicator light blinking?Or completely dead,no LED light indicator at all?Check ur power outlet source.Yes,than ur power supply board it dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 28, 2010 | Soyo DYLT032D 32 in. LCD Television
Garden Logo
70 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
