Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
My shark vac then steam wont steam
My machine was clogged and wouldn't steam and when I tried to use it a hose blew. I fixed the hose and put CLR in it to clean the clog. It was working ok for a few tries and now it heats but will not steam.......
  • Euro-Pro Master
  • 18,408 Answers
Sounds like it's clogged again
Posted on Jan 10, 2013
  • sweetlesliej
    sweetlesliej Jan 10, 2013
    Thats what Im thinking....... time to take it apart again.....maybe I can get my husband to do it this time LOL
  • sweetlesliej
    But what if I tell you that it doesn't sound like it's pumping the water ????
My Shark hand held steam cleaner sc 505 is not building up pressure, steam is leaking from lid
Throw it out, get a hoover floormate, best machine I ever had. My Shark steam/vac now resides at the dump after steam clogging problems and not being able to remove the hose to blow it clear.
Mar 17, 2014 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My shark vac and steam model mv 2010 pump wont come on help?
If your not using distilled water the machine is probably loaded with mineral deposits from hard water and is plugged. you can try running some vinegar through it which may or may not work depending how plugged it is.
Oct 22, 2013 | Shark Vac Then Steam Mop MV2010 NEW
How to fix shark vac then steam that doesn't emit steam
Replacement parts can be found on amazon, take a look: Amazon com shark vac parts . Have a nice day
May 08, 2012 | Vacuums
Both the triangular and rectangular nozzels are clogged. How could I fix the problem ?
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
May 07, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark Steam Mop - Gray/ Purple Vacuum: I left water in the steam mop and now the steam is...
heatman101
k
May 17, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark Euro pro mop the ligt wont turn on anymore.
my husband fixed my shark steamer by taking it apart and testing it wire by wire .the problem ?a fuse hidden inside the unit..unscrew the screws and get inside the steamer .at the bottom of the steamer there is a gold orange foil looking piece .under that is a small fuse .unless you can find another fuse just cut that one off and rewire the wires together .shark now comes on
Sep 27, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My shark steam mop heats up but won't steam. help
Problem: mineral dleposits. Just fixed mine.... DO THIS OUTDOORS. Add 1/2 c CLR to the tank, let sit for an hour, turn on, allow to heat and pump. May have to refill with CLR and repeat. Be persistent, and eventually you'll blow out a wad of dissovled minerals followed, happily, by billows of steam. Again, do this outdoors and keep the mop pointed away from people, plants and things. (I aimed mine into a cardboard box.) Follow up with a couple of tanks of water and pump until empty to clean out any residual CLR and loosened deposits. (I continued to get some black precipitate through the first water cleaning.) I will add that I began this process first with white vinegar, then with Lime Away..no luck put perhaps I was not sufficiently persistent. Or perhaps it was the sequence of attempts. (Also, do not take off the mop head...the part to which you attach the pads...it's tough to get off, does not allow access to parts that need cleaning (thought it would, not not so), and practically impossible to get back on.)
Alternatively, call Shark...they'll offer to repair for $18 plus $10+/- shipping, or may offer you a new one at "preferred customer" rate of $39.95 plus shipping. Good luck, and please remember to try the CLR outside.
Jan 10, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
This is a EURO-PRO X Shark Steamer Model S3325, there doesn't seem to be any power in plugged in, no lights on the handle. Bad switch or is there a fuse?
There is usually a heat sensitive fuse link installed in the handle and is incorporated in the cord connection. If the machine gets too hot or is run while dry, the fuse can blow. You would have to replace the fuse, as they are not resetable.
Mar 28, 2008 | Euro-Pro Shark SC-505 Handheld Steam...
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
117 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
