Question about Dell A940 All-In-One InkJet Printer
My dell printer wont turn back
The power will not come back on to my printer, but the computer says "in safe mode" . how do i fix this and whats wrong? thank you.
julie
    Novelist:
  • 140 Answers
Power down the computer and the printer. Disconnect the printer cable from the computer. Disconnect the power cable on the printer for 30 seconds or so. Without connecting the printer back up to the computer, turn the computer back on as you normally would. It may come back to the screen that asks you if you want to start windows normally or in safe mode. Start windows normally if you do not know how it got to that point. Once windows is started then go back and go through your shutdown procedure and let the computer power down completely. Now reconnect the power to the printer, but not the cable to the computer. The printer should come back on. If it does not come back on standing alone not hooked to your computer then you have a power problem. If it does come back on (powers up). Then turn it back off and reconnect your printer cable back to the computer. Turn the printer back on first, then power your computer back on like before and let it cycle on until you get to your desktop. By this point everything should be on. Let me know how it goes ,but I believe by going through the cycling on and off of both units you'll get back to normal operation. From your posted problem this is the best solution I can give you. God bless.
Posted on Jan 21, 2009
KEYBOARD WILL NOT WORK ON DEMENSION 3000 UNABLE TO TYPE ANYTHING
Keyboard might be bad or you might have a virus that has hijacked the keyboard.
Make sure the keyboard is plugged into the computer good. Then reboot the computer into Safe Mode and see if the Keyboard works.
Turn off the computer, then hit the power button to turn itback on and immediately start hitting the F8 key repeatedly until you see SAFEMODE. Take the Safe Mode option and let it boot up. Safe Mode will lookdifferent to you, the screen will be darker and the icons bigger, this isnormal.
Apr 02, 2012 | Dell Dimension 3000 PC Desktop
When booting the cp is going to power saving mode
Unplug power sources for the monitor and computer.
Hold down the power button of the computer tower for 10 seconds, this will drain remaining from the motherboard.
Plug back in the power sources for the monitor and computer tower.
Power on the monitor first, make sure the monitor power button will turn green then amber.
Power on the computer tower.
Try to check if you were able to see the Dell blue logo just right after you power on the computer.
If you were able to see the Dell blue logo then do these steps:
1. Turn off computer then turn it back on then immediately keep tapping on the F8 key. If options will appear please select safe mode.
2. If you were able to access in safe mode the problem we have is the video card driver needs to be uninstall then reinstall. To uninstall/reinstall the video card driver. Once you access the safe mode go to device manager then uninstall the display driver. Reinstall the display driver using the CD drivers came with the computer.
3. If you were not able to access safe mode then try again step 1, when you reach the option screen then select "last known good configuration".
If all fails from these steps, back up your HD files by asking a local tech to use an enclosure to copy all your data from your HDD to a different storage cause this will end up reinstalling the windows operating system.
Just in case just right after you power on the computer and it immediately gave you the message entering powe safe mode then you need to re-seat the video card which needs to open the side cover of your computer.
Re-seating the video card ut's just like taking it out from the slot then put it back again, make sure it's properly seated.
Jun 30, 2011 | Dell Dimension 2400 PC Desktop
In stage 3 of the system updates it wont load the last stage and keeps re starting itself
We are not really sure if the Windows got corrupted or it might be the Hard Drive.
Please do this first.
Turn off computer.
Remove all power sources.
Hold down the power button for 20 seconds.
Use ac adapter alone.
Do this while the computer is off.
Hold down Fn then press power button to run PSA.
Wait and follow the prompts on the screen.
If all test passed then do these.
Boot up to F8 then select last known good configuration.
If no fix then boot back to F8 again then do safe mode then in safe mode try system restore from the time it was working fine.
If all fails you need to do factory restore.
F8 then select repair computer.
Follow the prompts select Dell Factory Image Restore.
Make sure all files been back up using an enclosure connecting to a different computer.
Feb 21, 2011 | Dell Inspiron 1525 Notebook
I need to get this laptop into safe mode and don't know how there's no prompt so what do i do it's a dell Inspron 8500
Shut off the computer. Then turn it back on. Strike the F8 key several times while it's powering up. You should see the screen that allows you to go to safe mode.
Dec 15, 2010 | Dell Inspiron 8500 Notebook
I have a dell inspiron 630 the computer turns on but then shows a blank screen after window start up, what can I do to fix this problem ?
When your turn on the computer try pressing the F8 key to access Windows Safe Mode.
Are you able to boot in Safe Mode?
Aug 14, 2010 | Dell Inspiron 630M Notebook
Black screen
exacley what it say it makes it think its in safe mode it will turn on go green then turns in to safe mode then stayes whats wrong
Dec 22, 2009 | Dell E173FP 17" LCD Monitor
I have a dell monitor model e177fpv. It is stuck in power save mode. What do I do?
I have worked a great deal with the Dell E177fpv boards and when it is blinking power switch then it's bad. Most the time it's the C204,and C203 compositors that are bad (100uF 10v), and 70% of the time the C159,C154 ( 470 uF 25V are bad as well. now i have replaced them many of time and it had came back to life. i have also found other caps bad on it as well. i know you can order a new board for $39.00 and here is the link. http://www.lcdrepair.us/e177fpv_inverter-power.html
Dec 08, 2009 | Dell E177FP LCD Monitor
Monitor is in power safe mode
your resolution is set too high go into safe mode and turn the resolution to min and then play with it until it shows nothing push the space bar and leave the setting on that
Nov 18, 2008 | Dell E153FP 15" LCD Monitor
Dell A940 All-In-One InkJet Printer Logo
93 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
