Marwan_vaqub,
Dell does not supply bios passwords for Desktop systems. You would have to change the motherboard jumpers to clear the bios password. For help to clear the password please contact Dell Support for system ownership verification and they will then help you resolve clearing bios password.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
SOURCE: Bios default password
The BIOS default password is just blank, and it is not asked.
When you set a bios password, you are asked to enter a value, therefore if bios is asking the password, the password had been changed.
To reset the bios password if you do not know the password you need to access to motherboard and temporarily remove battery for few seconds.
Removing battery will reset bios and delete the password.
Unplug power cord before accessing the motherboard, and try not touching the motherboard with your finger.
Put battery back in place before restarting computer.
See also the following websites:
technibble.com/..
satyathakur.com/blog/
SOURCE: Dell Dimension 2400 Lost Password for Bios
:0 easy
1.) remove the side panel
2.) locate the battery on the main board and remove it
3.) make sure the system is unplugged
4.) press the power button and hold for 10 seconds
5.) replace battery, plug in and power on.
SOURCE: Dell Dimension 2400 PC Desktop CPU Fan Suppose To Blow?
Blows air into the case away from the cpu.RICHARDM69...This is a solution please vote as such.
SOURCE: Upgraded Dell Dimension 3100 memory to 2 Gigs - Windows XP fails
Did you add the two sticks with the 512 or remove the 512 and add the two 1gb sticks? Try booting the machine with ONLY the 1gb sticks in.
Your machine supports 1gb modules but they can't be higher than 533MHz. Check that the memory you purchased was either PC3200 (400MHz) or PC4200 (533MHz) and is 1.8v. If you post the part number off of one of the modules I can look it up for you.
SOURCE: Cannot boot from USB on Dell Dimension 3100 even
you have to make sure that the usb has boot files. for example windows file.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Turn on your computer. If your computer is already on then reboot it. You need to see the initial display screen to get into the BIOS.
Press the "F2" key when you see the initial screen displaying the BIOS provider information. If using the Optiplex and Dimension models, press the "DEL" key instead of the "F2" key.
Enter password if required. When finished in the BIOS be sure to save your changes. For changes to take place you must reboot the computer.
Read more: How to Get to BIOS on a Dell Computer ' eHow.com http://www.ehow.com/how_4745021_bios-dell-computer.html#ixzz1VDktcHYE
If the bios is password protected you will have to dump the bios batter first, then reconfigure the bois.
