Question about Miele Optima G2470SCVi Built-in Dishwasher
Miele dishwasher Intake Drain light on and beeping. No water in tray or blockage I can find..
Checked tray for water. Just found out you cant use Cascade gel tabs! Especially with DAWN! Anyone ever heard that???? Tech guy says the soap causes ploblems and thinks the tray is full but its not! Alot of soap scum in tray tho. Still cant get it to run. Checked the line to garbage disposal and it seemed clean...??? Am I doing something wrong?
Dishes not clean, soap not dissolving completly(powerball tabs and cascade gel)
first step would be to cut your soap usage in half. To much soap will cause the problems above.
Jun 10, 2010 | Maytag MDBS561AWS Stainless Steel...
My dishwasher leaves a fine white chalky residue on the plates. What causes this problem. How do I fix this problem?
Generally this happens when you have a very low water pressure in your home or the pump in the dishwasher is getting weak. Check your pressure first in your home and if good the pressure feed pump is getting weak and needs to be replaced
Mar 30, 2010 | Dryers
Dishwasher leaves behind gritty residue i am not sure of what to try...
We have a Kitchen Aid dishwasher, 10 years old, never any problems until 2 weeks ago, then we started noticing a gritty subtance on the dishes and glassware. We're on well service, psi 40-60. water hardness is 6 grains. small trace of sulphur, and we have a Mermaid sulphur system, then a complete house carbon filter, and finally a Culligan water softner. Checked everything, Water temp. at kitchen was 120, all cycles on dishwasher were operating. Called in repair service, he says something is breaking down in the dishwasher, best to buy a new one. That'll be $150.00. Thank you very much. Tried the white vinegar, no change. Next bought 2 bottles of Dishwaser Magic. Slight improvement. Next bought 1 bottle of Finish Dishwasher Cleaner. Bingo. The thing is like brand new. even the trays slide in/out much easier. None of the dishsoaps contain phosphate, which is what helps disolve the minerals in the water. I'm not sure what the gritty stuff is, maybe the buildup over time, and it just keeps getting redistributed through the wash and rinse cycles, and finally baked on in the dry cycle. According to a tech with many years repairing appliances, the majority of their calls are for dishwasher poor performance, all because they removed the one compound that's been cleaning our dishes for years, Phosphate. We've always used Cascade gel soap. best on the market today, Finish Quantum. We tried it and dishes look terrific. It's a small tablet that fits in the soap dispenser. All Mfg's. today recommend that you run a dishwasher cleaner once a year, Experienced tech recommends every 3 months maybe more if you're on hard water. Good luck.
Mar 25, 2010 | Maytag Dishwashers
Dishwashing liquid ( Cascade Liquid- gel- with Dawn) seems to be crytalizing is dishwashing reservoir on the door. After running the dishwasher the small door holding the liquid is open but still has some...
Tide is having a problem with it freezing during shipping. Call for a free replacement. Or...to thaw it she said to put it in hot water in a sink for one hour, then do it again (not boiling...have lid on tight).
Jan 01, 2010 | Whirlpool Dishwashers
Dishes never come out clean
Sounds like not getting sufficient water. Replace water valve if that's the case.
Nov 14, 2017 | Whirlpool 24 in. Built-In Dishwasher w/...
White film on dishes/not rinsing properly?
Buy a name brand powder (like Electrosol or Cascade) and use less than full in the dispenser cup.
Do not use gel or tablet, ever.
Final option: (the perfect fix, expensive, but worth it... install a whole house water softener and cut the use amount of detergent in half that you use in both your dishwasher and clothes washer. You will love it.
If problems continue, have the heating element checked/replaced. When it fails, you will always get film/residue on dishes, especially your glassware, even if your water heater is set to the proper temp of 120 degrees.
Good Luck!
Apr 01, 2009 | Dishwashers
Detergent (gel) always left in dispenser and on bottom of door
Get package of unsweetened limonade drink mix and put in machine and run a cycle, this will clean all parts of hard water deposits. Cascade powder is the manufactors choice, till they get ad space and samle giveaways
Mar 12, 2009 | Whirlpool GU2700XTSS / GU2700XTSY Built-in...
Dishwasher leaves soap in dispenser.
Hi Dirty Dish gang.
After having 2 appliance repairmen here, I now have the latest scoop on our dishwasher problems, $200 later!
Los Angeles IS currently having hard water issues. Also, all the new cleaning gels etc. are actually a cause of our dishwasher problems.
So, here is what we need to do:
1. Use Cascade POWDER detergent only.  Make sure is is just "plain" no "scented" or "complete"  or gel, etc. (I have tried a phosphate free powder and gel and this is a cause of our problem as well!) 2. Use Jet Dry in the dispenser (set it to a 2-3 opening) 3. Make sure water is at least 120 degrees 4. Only run dishwasher on "normal" setting.  All others just run it longer, hence causing more water stains. 5. Do not pre-wash dishes! You can knock of chunks with a "non" soapy brush, but don't rinse (the oils actually help to clean the dishes) 6.  Do not wash sponges in dishwasher.
Acid Wash: The repairman just gave my washer an Acid Wash today. It says it is an acid derived from lemon, I got mine from Carters appliance in Torrance, CA for about $19. I am to run a normal cycle with the above mentioned Cascade after this "acid cycle" is finished.
If you are still having problems:
Monthly maintenance: Glass Magic: Buy a box of Glass Magic (near the Cascade)  Use 1 Tbsb in main detergent compartment of dishwasher along with the Cascade, till washer starts working again. White Vinegar: You can run an empty dishwasher with white vinegar once a month.  Fill a bowl with 2 cups vinegar and place on bottom rack.  Then run as a normal cycle...this allows vinegar to disperse slowly.
So far it seems to be working.  Good luck.
Nov 07, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Soap left in the dish
With the LG LDS5811 dishwasher and other water/energy saving dishwashers, they are VERY ineffective with untra cheap powder detergent. Switching to Electrosol or Cascade has solved the problem -- and don't use too much.
If you add a whole house water softener, you will be AMAZED how much better your dishwasher and clothes washer work -- especially if your cut down on the amount of detergent your use.
Oh, never use gel or tablets in your diswasher. Ever.
if the problem with the detergent dispenser not opening is a seperate problem. Recommend you submit a seperate problem/question.
Good Luck!
Aug 26, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
Soap Dispenser Problem with Kenmore Elite Dishwasher
its possible to have a faulty dispenser, but i would look for other reasons first. Im a big powder user and proponent. powder just breaks down better in hot water.Have found that by using the tabs(whoch im sure the gel packs could give same issue) that they dont really fitting the dispenser as well they're a little tight to close the door and the spring action of the dispenser is sometimes not enough with te extra pressure from the tablets.also ck to make sure youre loading it correctly and nothing is blocking the water form spraying into the cup fully emptying it
Mar 22, 2008 | Dishwashers
Miele Optima G2470SCVi Built-in Dishwasher Logo
51 people viewed this question
Top Miele Dishwashers Experts
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
