Question about Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens
Canon Rebel 300D does not take picture. No error codes, battery charged, memory card in place. What could be wrong?
Camera stored in oringinal box for a few years, worked when placed there. Took out charged battery. Review all operating procedures and no error codes. Press shutter button no response. Tried different memory card and lens. Still does not work.
    Sergeant:
  • 321 Answers
Check lens aperture
Posted on Jan 10, 2013
philipp
  • 217 Answers
SOURCE: Canon G5 Lens error message
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Posted on Nov 12, 2007
hsanfor
  • 71 Answers
SOURCE: Camera turns off when pressing shutter button
Sounds like a compatability problem. If available, try a genuine Canon battery new and fully charged.
Posted on Jun 17, 2009
  • 51 Answers
SOURCE: Hi! I got a Canon rebel XT. problem... the camera is dead
Like all electronics, water is it's worst enemy so even by drying it (which is commendable) you still may have traces of water somewhere on the circuit board. We all know water is conductive, so if some solder tracks were shorted there can be a problem there or if the water has corroded through a solder track the circuit fails. There are numerous chips in the camera that are super tiny so even the slightest water can damage them.
In my experience when something is water damaged (and seriously water damaged) it is beyond repair.
Posted on Nov 02, 2009
SAFFOTO
  • 77 Answers
SOURCE: Canon EOS Digital Rebel XT will not turn on.
It could be a number of things. The first thing you shouild do is remove the back cover and check for loose screws. If you don't find any, the problem may be a damaged battery door switch, a damaged memory card slot door switch, or worse- it may be a defective power board.
Posted on Feb 03, 2010
  • 72 Answers
SOURCE: Canon lens locks when taking a picture.
Mirror lockup is probably enabled. You can disable it by going into Menu and then Custom Functions. Select Mirror lockup and disable it.
Posted on Jul 15, 2010
Busy flash picture and 3484 code
When showing busy, most of the time the camera detected an error, but can't find out what is causing the error.
Try the normal "reset" method as follows:
Like a cold boot for a computer, the camera can be "rebooted"
follow the following steps:
Switch of the camera and remove the battery.
Remove the memory card and the lens. (if possible)
Recharge the battery. Wait till the indicator on the charger indicates the battery is fully charged.
Check all contacts, if they are clean and shiny. Contacts (from battery and memory card, only to be cleaned with a dry cloth or cotton swab(s).
Reinsert the battery, reinsert the memory card and re-attach the lens.
Then switch on the camera.
If this does not help, contact a certified Canon repair centre.
Nov 29, 2013 | Canon EOS 400D / Rebel XTi Digital Camera
My canon rebel xti will not power up with a cf memory card in place. I tried two different cards. With no card in place it works fine.
check for bent CF pins. Also remove the back cover and make sure the bottom right rear circuit has not come loose and is not shorting out the board
Oct 13, 2013 | Canon Digital Rebel / EOS-300D Digital...
Im getting an Error 99 on my EOS-300D Digital Camera when I turn off my YN 465 Speedlite flash gun (still mounted) and then I start shooting manually without the flash. Help please, its a bit annoying, but...
To fix this err99 issue, do the following
1. Turn off the camera. 2. Remove the lens, battery, and CF card. 3. Allow the camera to sit without power for approximately 20 minutes. 4. Insert a fully charged battery, and turn on the camera.
If it appears again, then proceed to next steps 1. Turn off the camera. 2. Insert the CF card. 3. Turn on the camera. 4. Format the CF card in the camera.
If you still get the error you should send your product to canon for servicing.
Apr 15, 2010 | Canon Digital Rebel / EOS-300D Digital...
Canon EOS Digital Rebel 300D will not take pictures
Have you tried to take picture by switching off the autofocus to manual focus in a prperly lit environment?
If it takes a picture, then it has something to do with your auto focus system of your camera. In such a case: try taking out the battery, the memory card etc and switch off the camera and keep it for like that for about 5 minutes. And then insert only the fully charged battery and try again.
If it still gives you a problem and keep trying to focus You will need to take it to the nearest Canon Service centre.
Mar 08, 2009 | Canon Digital Rebel / EOS-300D Digital...
Canon rebel xt EOS
Take a strong light and look into the slot where the CF card is placed. See if any of the pins are bent or touching each other. If the camera senses a fault in memory card communication, it may not power up.
Also check the battery contacts in the camera. If you can see any corrosion/discoloration of the contacts, try and clean them up with a pencil eraser.
Otherwise, it looks like you have done what is possible without taking the camera apart. Check into getting it serviced.
Jun 02, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Absolutely screwed up, recently purchased camera
try to shoot without a card. or better use a known good card. [:0)
Jan 10, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon eos 300d (digital)
your manual is the first place to look for an error code. then the canon site.
guessing it is a defective on board battery (the smaller of the two) or your main battery is depleted.
try removing and reinstalling the main battery first. then check the on board battery.
you may have a lens partially mounted, or some contamination on either the battery terminals or lens terminals, or a door partially open.
also, you should take out the mem card and check it in a card reader.
none of this will likely be needed if you can find the error code data. it might be that the code is specific enough to indicate the root cause of the problem.
good luck
mark
Dec 24, 2007 | Canon Digital Rebel / EOS-300D Digital...
Camera does not work when memory card is inserted
I have had this problem, and it was a bad CF card. Are you sure both of them are good? If a computer can read them, maybe try formatting them.
Dec 05, 2007 | Canon Digital Rebel / EOS-300D Digital...
Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens Logo
65 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
