Question about Brother PE770 Computerized Sewing Machine
The safety device continues to activate on my Brother PE 770
I have cleaned and checked the bobbing and the safety device continues to activate every time I sew. It sounds like something is grabbing the top needle, but it appears clear as well.
  • Brother Master
  • 7,365 Answers
It sounds like the machine needs to be serviced to see that wrong
with the machine
Posted on Jan 10, 2013
SOURCE: Brother SE-350 "The safety device has been activated"
Return the bobbin winding shaft on the top right of the machine to the Left Position. It may be stuck in the middle.
I had this same problem. After an hour or two of fiddling, this fixed my problem.
Posted on Nov 03, 2010
  • 399 Answers
SOURCE: I have a Brother SE-270D
its the problem of the timing belt in your machine its extra loosen or extra tightned or is slightly came out of its position or finally broken.
as the machine is proper just missing the proper speed as it should be .
it is running continuosly as you stated.
check the timing belt and make it proper if its worn out and needs replacement this is how its done
There is an adjusting screw on the right side of the machine head. Follow the motor bracket to the machine head and loosen that big old screw or bolt which will raise or lower the motor giving you slack to remove or replace the belt.
feel free for further queries
thanks
Posted on Sep 19, 2008
  • 323 Answers
SOURCE: Brother 2001 sewing and embroidery machine.
The fact that your machine is turning hard says you still have some thread inside the machine that is binding up and activating the safety device. It must turn easily before it will work properly again.
Sometimes the machine must be disassembled to remove these threads.
sewman7
Posted on Jun 18, 2008
SOURCE: My brother PE-400 sewing quit sewing
i had the same problem and realized i was using the wrong kind of bobbin. there are specific ones for an embroidery machine and specific ones for a reg. sewing machine. hope this helps
Posted on May 03, 2009
  • 52 Answers
SOURCE: Brother 270D Jams when sewing anything
You might have thread caught in the take-up lever linkage and it has soaked up all the oil my recommendation would be take it to your local dealer
Posted on Jun 25, 2009
Brother pe 770 brand new with this error message F02 SS SW ON
Brand new? Take it back where you bought it. It is a defective unit.
Mar 01, 2017 | Brother PE-770 Embroidery Machine
My CS 770 displays a flashing F4 Brother sewing machine
Perhaps this will help:
https://answers.yahoo.com/question/index?qid=20120713084921AAH7Vxl
Not much information on a Brother C4 error. You might try contacting Brother Support. Support Center
Jun 13, 2016 | Brother PE770 PE 770 Embroidery Machine w/...
Machine locked up with needle down in the machine
If you can, try to remove the needleplate and the bobbin case from the machine. Once the bobbin case is removed, the needle should be free.
Embroidery Problems Brother Sewing Machine
Dec 05, 2015 | Brother PE-500 Embroidery Machine
My Brother PE-770 presser foot Q has started making a clacking noise. If I press in on the lever on the back of the foot, the clacking stops. What is causing this loud noise and how do it fix it?
Sounds like something in the machine in the head that makes it go up and down. either wear or something loose. I would have it checked by a Brothers repair shop
Jan 10, 2015 | Brother PE-770 Embroidery Machine
I need to rotate my pattern by 45 degrees on my brother pe 770. I've tried going to layout but it only does 180. Any ideas?
Get software such as Embird Design to do it and then export the .PES file and transfer to the machine. Unfortunately the low end machines do not have this capability.
Apr 02, 2013 | Brother PE770 Computerized Sewing Machine
What kind of plug/cord do i use to plug my Brother PE-770 into my computer
Just use a regular printer type cable. On newer models, they use a regular USB connection so it's easier to use USB keys
Jan 29, 2012 | Brother PE770 Computerized Sewing Machine
Brother PE770 Computerized Sewing Machine Logo
1,380 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
