Question about Linksys Computers & Internet
I have a Linksys router and a Westell modem bridged together. Whenever I boot the computer, the internet connection cuts out. I always have to reboot both the modem and the router to establish a connection again. Both are at least 5 years old. Is this a sign that one may be dying? Thank you ~
  • Linksys Master
  • 2,072 Answers
I would just replace them if they are being flaky. 5 years is old for tech now-a-days. I replace mine every 3-5 years.
Posted on Jan 11, 2013
ImWireless
  • 113 Answers
SOURCE: connecting westell 6100 (verison) Vonage and linksys WRT53G 2.4 and computer
try this resolution provided by me earlier. In any case if this doesnt work, you may initiate a chat with me and we can carr on from there... http://www.fixya.com/support/t139545-configure_router Good luck
Posted on Apr 22, 2007
SOURCE: configure WRT300N wireless Router to connect internet using PPPoE
Often the nets and subnets are NOT the same.. ie The Fixed connection often uses 192.168.0.1, 192.168.1.1, however sometimes the wifi is setup 10.1.1.1, or 10.0.0.1 etc, have you checked this? Esentially tho ya router is an "Acess Point" and ya Lappy etc is ya "Client" the links below has a lot of tutorials to help have a look. http://portforward.com/routers.htm http://portforward.com/guides.htm
Posted on Aug 05, 2007
SOURCE: Connecting my westell 6100 modem to my router
linkseys Wireless G broadband router need to hook up to Verizon router/modem
Posted on Jun 22, 2008
SOURCE: zhone linksys router
I had same problem but I think it's more of a simple solution. Linksys default IP it uses is 192.168.1.1, and guess what...so is the zhone router. I changed my linksys router to 192.168.10.1 and i am able to connect to the internet. Only problem I have left is some things are not working such as MSN messenger and https pages. I am wondering why...
Posted on Aug 27, 2008
  • 20 Answers
SOURCE: Can not setup modem:Westell 6100 to router:Linksys WRT54G
i think the best way is to describe to you the physical setup first. so you have a computer, a modem, and a router. the setup should be like this: from the walljack, the phonecable is connected to the 6100, make sure there are no micro filters connected between the walljack and the phone line because it will not allow you to connect to the dsl. from the modem, the data/internet cable at the back of it, using an ethernet cable, should be connected to the router. and at the back of the router E1 to E4, another ethernet cable is connected there and the other end of the cable is to be connected to your computer. you are right in bridging the modem, the reason for that is because both the westell 6100 and router have GUI's or Graphical User Interfaces, in short, they each have their own virtual brain. you will not have a connection if both of them have this GUI thing, so you need to bridge your westell 6100, so that the only GUI active is the routers. to bridge the modem you may need assistance from tech support of your ISP provider. assuming that's done, light status in your 6100 should have a solid DSL light. for the router, it should have lights in WAN, WLAN if you want to connect wirelessly and E1 to E4, whichever ethernet port you're using for a wired connection. you have to access the GUI of the router to make sure you have a routable WAN IP Address. As for the IP address in your computer, it should be a 192.168.x.xxx type of ip address. this is the LAN IP Address. Basically you need to have routable WAN and LAN IP Addresses to be able to connect online. you will need to configure the GUI of your router to be able to do this. for that you may need assistance from tech support of the router or if you can follow the instructions in the manual, by all means do so. the most important thing in this setup is bridging the modem.
Posted on Dec 20, 2008
Can't connect my wrt56gs to my westell 6100 modem, could you please help?
You are using westell modem that means your internet service provider must be DSL.You will need to make sure that your computer is able to go online when connected to the modem. that will decide the type of ISP connection.
Click Here for more info on how to set up the router.
Oct 18, 2009 | Linksys Wireless-G WRT54G Router
Westell modem/roter and linksys not working together I have tried almost everything ans they will not work. changed to bridged on westell pppoe onlinksys as well as ip add change tried static ip. I can...
What you need to do is this. I have the exact same setup on my network and I got mine to work perfectly. Take the router to your computer and hook it up only to the network card. Change the local IP Address to 192.168.9.1 and the subnet mask 255.255.255.0 tell the router to reboot. Once the router have rebooted you will need to disconnect the cable few minutes and reconnect. Make certain that support say 192.168.9.1 as the gateway. If it does you have done it right. On the westell modem under the advance settings change the default gateway to 192.168.1.1 and the subnet mask 255.255.255.255, if there is an error message change the last 255 to 0, it has been awhile since I had to do mine. Unpluge everything the modem and the router and plug the cat5 cable into the modem and the other end into the WAN port of the router.
If this doesn't work there is a third party firmware that you can put on and it makes it alot easier, but you have to be careful when you program it or it will brick your router. If the other configuration doesn't work the third party would be next to try.
Jul 26, 2009 | Linksys Wireless-G WRT54G Router
Cant connect to the internet with linksys wrt160nv2
if this is DSL connection then you have to configure your modem before you connect router
follow this
first disabled wireless on your modem/router
.1) Turn off DHCP on your modem/router I am assuming this is verizon westell
2. Configure the first VC port to Bridge-Bridge mode
3. Keep hitting "apply" in the windows until the 7500 reboots
4. Plug the "Internet" port on the linksys to one of the normal ethernet ports on the modem /router
5. Turn on the Netgear and wait for the green Internet light to go solid
good luck if this does not work provide more info on your setup
Jun 12, 2009 | Linksys WRT160N Wireless Router
DSL line disconnects on WRT54GS only
Try to change the LAN IP address of your router to 192.168.2.1 by accessing the router's Setup page. You also need to set your Westell modem to "full-bridge mode". You need to ask assistance from your ISP to bridge the modem. After that, set-up the Linksys router to PPPoE then power cycle it.
Apr 15, 2009 | Linksys Wireless-G WRT54G Router
Ps3 key change timeout using westell 6100 modem on verizon
there might be a problem with the Linksys router, the Westell 6100 should be 1st set to bridge mode in order for your router to be connected to it. or there could also be a proble on the Verizon server.
Apr 10, 2009 | Westell Wirespeed LiteLine 6110 Modem
I have a dlink router and I want to connect my usb modem to it
is this an additional router?
Verizon are issuing modem with built in wired and wireless modem.
Try this;
How do I properly set up a D-Link Router with a Westell Modem? (#7125)
This FAQ is for setting up a BellSouth supplied Westell 2100/2200/6100 modem (Models A90-210030-04, B90-220030-04 and B90-610030-06/C90-610030-06, respectively) with a D-Link DSL router. Although actual screen shots vary throughout the DLink line, the instructions below are applicable to all models. Important Note: These procedures and pictures are based on the most recent firmware for the Westell. Other Westell firmware menus and screenshots are slightly different but the bridge options and functions are still available. It is highly recommended that you click here and update your Westell firmware.
This FAQ has 3 Major sections:
Section 1 - Overview
Section 2 - Westell modem configuration
Section 3 - D-Link router configuration information
Section 4 - Connections and power up
bred.gifImportant Note: Due to some known operational issues it is VERY important that you have the latest firmware on your D-Link router. Please go to the D-Link Support Site for firmware updates.
bred.gif The best configuration for networking a router with the Westell is to set the Westell to "Bridged Ethernet" mode and allow the router to do the routing and DHCP functions. The Westell is also a router with full DHCP functions and may not function correctly when connected directly to another router. Not changing the modem to Bridged Ethernet will result in double NAT'ing, increased latency, possible IP conflicts, or possibly a network that doesn't work at all.
bred.gif Before proceeding both the modem and router should be set to default. Despite what the help desk tech tells you, resetting the Westell does not put it into Bridged Mode.
bred.gif The BellSouth Installation CD and Connection Manager are not required to use this configuration.
bred.gif Since BellSouth assigns static WAN IPs via your username the configurations shown are applicable to both dynamic and single static IP customers. Select dynamic PPPoE regardless of your setup.
bred.gif You must connect the Westell directly to the computer's NIC to make the necessary changes before you connect the router, because you will be unable to access the modem interface after you connect the router. The reason is that the modem interface is 192.168.1.254 which is a local IP. By default, most routers do not have the capability to route a local IP out of their WAN port (where your Westell is connected). Additionally, they may be on completely different subnets. After you have made the changes to the Westell you can then connect the router and configure it for use with FastAccess. There are several alternatives around this problem. One method involves extra equipment (second NIC and a hub) and major configuration changes. The second method requires you to utilize the router as a simple switch and use the Westell's PPPoE and DHCP functions. Click here for more information.
bred.gif If you encounter any problems simply reset the Westell, connect it directly to your NIC, restart your computer, log into the Westell interface, and start over again.
bred.gif More information about the Westell is available here.
Section 2 - Westell Configuration
bred.gifStep 1
Verify that your NIC card is set to "Obtain IP Address Automatically". Completely power down the Westell and the computer(s). Power up the modem and press the reset button on the back of the modem. After the modem has fully initialized connect the Westell to the NIC and then power up the computer.
bred.gifStep 2
Open a browser session and enter 192.168.1.254 in the URL address field to access the Westell interface. If you are unable to access the interface make sure your NIC is set to "Obtain an IP address automatically". This may require you to reboot the computer (or release/renew) to obtain a proper IP.
bred.gifStep 3
Click on Broadband DSL Line from the top menu. Click on Configure Connection from the right menu. Select "Bridged Ethernet" from the Protocol pull down. Click on Save and restart the connection at the bottom. This will automatically restart the modem and the interface will return after the changes are saved. Note: functions like NAT, DHCP, IP Passthrough, and username and password will be disabled or irrelevant and can not be selected. After the modem has restarted, power down both the computer and the modem then physically disconnect the Westell.
Section 3 - D-Link Router Information
bred.gifStep 4
After the PC is powered down connect one of the router LAN ports to the computer NIC and power up the router and then the computer.
bred.gifStep 5
Use the following steps to configure your D-Link DI-604 Router. Important Note: You must use the username@bellsouth.net format for your username. If you do not add "@bellsouth.net" after your username you will be unable to connect to the internet.
Section 4 - Connections and Power Up
bred.gifStep 6
Power everything down and physically connect the Westell, the router, and any computer(s).
Westell 2100 shown. Pictures by Andy Houtz
bred.gifStep 7
Power up the network equipment in this order:
•Westell Modem (wait till the Ready light is a steady green)
•D-Link Router
•Computer(s)
Open a browser session and go surfing!
bred.gifAdditional Imformation
•You should check your tweak settings to optimize your new network. Reminder: If you are required to change your MTU, make sure that it is identical on all equipment (PCs and routers) in the network. For more information about changing MTU on a D-Link please click here.
•The 6100 has an "Internet" light that is green whenever there is an active PPPoE session initiated by the Westell. Since you are using the DLink to establish the PPPoE session the light will stay off. This is normal.
Mar 13, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Dec 20, 2008 | Computers & Internet
Connecting new Linksys WRT160n to existing modem Westell 7500
You have to call your internet provider and ask them to help you put the Westell modem in "Bridged ethernet" mode. This will by-pass the Westell modem and use your linksys as the wireless.
For AT&T:
http://www.dslreports.com/faq/6405
Site with good info:
http://www.voip.com/help/Residential/Installation/Networking/bridged_westell.aspx
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 15, 2008 | Linksys WRT160N Wireless Router
Get no connection useing 6100 modem connected to wireless B router
Hi starman re westell 6100.
Hi i hope you have find solution with your issue ifnot let me walk you through on how to get it up and working.
First , you need to connect your modem directly to your computer. We need to access its Graphic Unit Interface by opening your browser and type onyour address bar its default gateway.
The def. gateway can be 192.168.1.1 or depending what ISP youre connected to . For ATT broadband its 192.168.1.254 / verizon broadband is 192.168.1.1..  { onyour address bar : type in 192.168.1.1 and hit Enter.
to check def gateway : you can go to start > run > cmd then enter > on DOS command type in ipconfig /all  then HIT enter > itl provide you your network list > your default gateway is your westell modem or if your linksys is connected than it should be you linksys.
Itl route you to your westell page. Try to go to  Broadband and choose connection or configure connection.button. Look for configure and by default you will see its in PPPoE> change it to bridged ethernet and save.
By enabling bridge to your modem w/c is westell youl have a chance to configure you linksys to PPPoE.
Connect you westell to your linksys and on your computer try to check your default gateway as seen above. By default linksys can be access by typing in 192.168.2.1 or 192.168.1.1. Itl prompt you for UN and PW: by default your Username is : Blank and Password should be admin. { blank = dont type anything}
On your linksys SETUP page > by default it is set to DHCP or obtain IP address automatically. Pls change it to PPPoE and type in your UN and PW : username@isp { your ISP name}. and hit save settings or save.
Restart your linksys and try to browse to check fore connection.
For all types of modem such as westell : you need to set it to bridge mode first foryou wireless router to work ie linksys. Set linksys to PPPoE .. that should work .
For more detailed steps or questions re: this issue pls dont hestiate contact me. Best wishes.
Pls enable you Wireless Encryption for your home network security.
Ciao .
Prince
May 21, 2008 | Westell Wirespeed LiteLine 6100...
i there ;
the solution for ur problem is :
> As ur isp is verizon so they must have provided wu wuth a username and password ...
> Open the routers page 192.168.1.1 ...
> Instead of automatic configration click on pppoe ...
> type in username and password for more help contact technical support at 1866-283-6613 . i hope this will help Linksys Tech support
Dec 09, 2007 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
32 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
