Question about Xerox WorkCentre 4260/S Multifunction Multi-Function Laser Printer
Paper size mismatches on screen. Wont receive fax
I added 4.3 x 5.5 paper size on the computer yesterday and trying to print from bypass. It failed. Erase the job from printer. This morning, my xerox is not receiving fax. It prints and copies. Screen keeps showing needs paper size 4.3 x 5.5 in bypass. Inserted the size paper. Now the screen shows "paper size mismatches".
  • 208 Answers
SOURCE: [No Paper] error
take out the paper tray and look inside. You will see a feed tire about 4 inches in, on the upper frame over where the paper stack would be. Right behind that feed tire, there should be a black hook shaped actuator that contacts the paper stack when you put the tray in. It is about 3 inches long.
Either that is knocked off or the sensor popped out of its slots.
The board could be bad, but that is very unlikely.
95 percent of the time that actuator is knocked off or the sensoe is out of place.
If you cant find the actuator, if that is the problem, you can slip a piece of tape , not scotch tape, some type of tape you cant see through, into the channel of that sensor. the only difference you would notice is you would not get an out of paper message but a jam when you ran out of paper.
Posted on Dec 20, 2007
jonb3838
  • 237 Answers
SOURCE: I am trying to print
The tray itself should have tabs on the side telling the type of paper look at those and see if there is anything broken off.
Posted on Feb 11, 2009
vincent721
  • 240 Answers
SOURCE: when trying to print from computers the message
double check the paper setting and margins set up on your computer.
check the printer properties
Posted on Mar 23, 2009
SOURCE: RX 420 PRINTER WONT PRINT AS PAPER JAMMED WARNING KEEPS FLASHING
hi i hope i can help you? remove the cover from the machine and load paper as normal. and watch if the mechanics is sticking or anything that you can see give a clean with wd40clean all rollers check that you are puting in the correct amount off paper.check for loose connections.check for dirt on the switches.
Posted on May 05, 2009
  • 193 Answers
SOURCE: Replace Drum
your toner has nothing to do with sending/receiving faxes. If you can print to the xerox...something is wrong with the software..
delete and re-install software..Xerox website is useless
check the black sensor that dangles into the paper tray. wiggle it up and down, ahten resintalled the tray
Posted on Dec 03, 2009
How do i print on cardboard (heavy paper card)
The mx2300n only supports up to 209gsm heavy card. You must make sure that your heavy card is not over this rating.
Set the bypass tray as 'Heavy' by clicking on the trays on the main copy mode screen, select type & size for bypass. Select heavy, and Auto AB as this will allow the tray guides to detect the size of your paper. Load the tray with up to 20 sheets of Heavy paper.
Open your document, select Print, then properties. Under the 'paper' tab, select paper source as bypass tray, and paper type as heavy (if you miss one of these steps, the ,machine will ask to load paper due to size or type mismatch).
That's pretty much it.
Oct 16, 2013 | Sharp MX-2300N Color Copier
Hp j6480 printer wont print keeps sending a paper mismatch message
Paper mismatch errors occur because the product scans the width of the envelope before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the product, the product reports a 'Paper Mismatch' error. The message saves paper and ink by preventing print jobs from accidentally printing on the wrong paper. For example, the print job might be for a 101.6 x 152.4 mm (4 x 6 inch) photo, but there is letter-size paper loaded in the product. The error message displays to make sure that ink is not wasted on the wrong paper type. try this out , disable the automatic paper type sensor.
  1. Open the Print dialog box.
    1. In Word 2003, click File , and then click Print
    2. In Word 2007, click the Office button (c01850900.gif ), and then click Print .
  2. Make sure that your product is in the Name drop-down list box, and then clickProperties .
  3. Click the Features or Paper/Quality tab.
  4. In the Paper type drop-down list, click Plain paper .
  5. Click OK to close the Properties dialog box.
  6. Click OK again to print the current print job.
Feb 24, 2011 | Digital Products Hewlett Packard OfficeJet...
When I try to line tells me that the paper size mismatch and only takes a copy of the text
Have/had the same problem: Getting "paper size mismatch" on the C4280 status screen, after we got a paper jam. Every time we hit OK and put in paper, Message about "Now printing Alignment page", it feeds through quickly, with nothing printed on the page and reverts back to Paper size mismatch. Finally got rid of the error, not sure how, but now when I try to copy anything, we only get the lower right postion of the document that I'm trying to copy. Printing from the PC seems ok.
Powered off and back on, and it is back to P"now printing alignment page, quick feed through and "paper size mismatch" error. AND
When copying directly from the glass panel,it will only print a quarter of the page -however it prints and coorectly if we print directly from the computer.
The problem is the paper size sensors. Remove the plastic access panel that is for access to the rollers in the back and has 4 rollers on it. There are two papaer sensors attached to the printer circuit board (PCB). The control arm for the sensor is a small plastic piece that extends slightly into the paper path above the PCB. The plastic can be broken when you are removing a paper jam. I stuck a small piece of a match stick in the sensor to keep it open (as though a wider piece of paper was passing throught the printer). I can't switch to smaller card stock, etc, but who cares, it works.
The copying problem is caused because the C4280 will not scan correctly until after it does the alignment phase.
Dec 16, 2010 | HP PhotoSmart C4280 Laser Printer
Paper size mismatch is appearing on the screen
if that is when your printing you have to check and be sure the paper tray size is set correctly. You press the machine status button and make sure, tray 1, 2 and the bypass are set to the proper size paper.
Nov 03, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Hp fax/scanner # 6110
Hi Judy,
The only document I found at HP.com that may seem to address your issue is the following:
A 'Paper Mismatch' or 'Paper too Narrow' Error Occurs While Receiving a Fax
Have a look at the suggestions on that web page and see if anything there helps. Post back you results and good luck.
Nov 07, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Printing to 4 x 6 paper
Hello oyam26,
For any paper mismatch issue, first thing you do is try to set the paper type to plain. This will fix the issue in most of the cases.
gud luck
Nov 01, 2008 | HP Photosmart C4280 Aio Printer
Paper
If you see this message on the front panel of the HP PSC 2210 when you are receiving a fax, check that the paper size is set to match the paper size in the paper tray. (You cannot receive a fax on 4 x 6 paper or on an envelope.) Checking the paper size setting
  1. Press Setup .
  2. Press the right arrow until you see 3: Basic Fax Setup .
  3. Press Enter .
  4. Press the right arrow until you see 4: Paper Size .
  5. Press Enter .
  6. Press the right arrow until you see the paper size that matches the size of the paper in the paper tray.
  7. Press Enter .
Aug 28, 2008 | HP PSC 2210 All-In-One InkJet Printer
Cannot print from Tray 1 in Gestetner 6002
First make sure that the machine is reading/ seeing the paper size of the paper that is in the tray ( select tray 1 from the touch screen and see what the paper size reads). If the machine sees a different size then that in the tray, use the 'user tools' and change the paper for that tray. Also, go into your printer settings on/in your computer and make sure that the proper paper size is selected ( the size that is in the tray you want to print from). If the orientation of the paper size is different from the tray -- will not print and give you the error.
May 06, 2008 | Gestetner - 6002 Digital Imaging System...
Incoming fax problem
DON'T KNOW IF THIS WILL HELP-BUT MY PROBLEM WAS SIMILAR--MINE WAS SAYING PAPER TOO NARROW WHEN I WAS TRYING TO PRINT AND COPY. I JUST KEPT MOVING THE FRONT SLIDER AND THE LEFT HAND SIDE SLIDERS BACK AND FORTH AND TOOK THE PAPER IN AND OUT --TRIED AGAIN AFTER EACH TIME--IT EVENTUALLY FIGURED OUT I DID HAVE THE RIGHT SIZE PAPER--
ALSO TRY---MENU--THEN--COPY SET-UP--THEN PAPER SIZE--SEE IF PAPER SIZE IS SET RIGHT.
Mar 01, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Xerox WorkCentre 4260/S Multifunction Multi-Function Laser Printer Logo
41 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
