Question about i-mate JAM Pocket PC
I Mate Jam Blue Tooth sync
When i try to sync with ActiveSync on my desktop with the blue tooth option the device gives me error massege. the massege state that the com port in not avialble !?!?!? please help me to understand this. thanks Dagan
  • Anonymous Aug 01, 2007
    thanks
    dagan
  • 56 Answers
Dear sir , when you try to connect using bluetooth you have to define the COM port from the control panel >> bluetooth devices then you add a new port and remember the number of it . then open Activsync. click on file >> connection setting then check this option : allow connections to one of the following .. then choose the COM that you just add it from the control panel. it will works now
Posted on Jul 31, 2007
SOURCE:
No bluetooth can i get an app
Blue tooth capabilities requires hardware chip and programming.
If your tablet does not have built in blue tooth, then the answer would be a negative. If tablet is blue tooth capable, the blue tooth device must be capable to mate to tablet blue tooth version technology.
Feb 26, 2014 | ZTE V9 Smartpad Android Internet Tablet
I want to transfer picutes from my phone to PC
Welcome, Thank You for giving fixya.com the opportunity to HELP!
Your issue:
I want to transfer my pictures? from my phone to my pc.
Solution:
Your case will need the following kit witch you can purchase from HERE
If you already have the USB transfer cable all you need to do then is download the software from that website, install it on your computer, this will sync all your photos to your pc without a hassle.
We only give you the facts that you need in order to get the solution done. You will need to purchase if you have not already the transfer cable and kit from the source given.
Your ratings are important to us. Please be considerate when passing through Fixya.com to leave feedback so we know how we are assisting our askers.
Best Regards,
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 16, 2011 | Motorola Mobility V265
I have a lanzar sd32mts. and the option for the bluetooth is not lighting up for me to select, i do have the bluetooth "on" on my phone ive tried listen and search but nothing. any ideas why
have you read the instructions that came with your device? normally you have to try to sync them both together at the same time within about 100 to 300 seconds. first you have to set your phone on discovery mode under the blue tooth options then next you have to hold down the blue tooth sync button on your other device for a few seconds till it lights up, then they are paired. But also sometimes to complete the pairing process you have to enter a default code. normally something like 0000, or 1234.
Mar 11, 2011 | Car Audio & Video
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
Bluetooth is not found in the control panel of my laptop
goto start and type bluetooth in search...if bluetooth drivers are installed ull get some icons like bluetooth, bluetooth devices etc.....try clickin bluetooth devices.....n u can try to connect with ur mobile.....if it doesnt show anythin u may have to install bluetooth drivers....hope this helps...
Mar 07, 2010 | Lenovo ThinkPad R61i 14 inch widescreen...
Trying to sync with my blackberry 8900 asking for numeric passkey for my plantronic 220 ... dont think I needed this when I had a Motorola Razor.... annoying.... any thoughts.
the passkey is just like a password which is a single time entry into your phone for connecting blue tooth devices in a secured way.
once you enter the passkey the phone will be able to identify and connect to your device each time you search for blue tooth devices in the phone.so please do not get annoyed, go ahead and give a passkey of your own choice(like birth date. so that you wont forget it easily since you wont use it again until you reset the phone or connect other devices).
this passkey can also be used to connect it to laptops, desktops if they have blue tooth.
also remember this passkey is used to restrict any unauthorized access to your phone.!!!
should you have any questions please write to us again.thanks for contacting fixya !
Oct 23, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Camera phone bluetooth
-First you must "enable" your blue-tooth on your handset.
-Secondly you need to make set your blue-tooth feature to "always visible" (this setting is within your blue-tooth application).
-Third, you need to search for all available blue-tooth devices within your range.
If the kiosk shows as an one of the available devices, try to pair with it. (Note: If your blue-tooth feature prompts you for a pass-code, enter 0000.This also applies if the kiosk prompts for a pass-code.)
If you have followed all these guidelines and you are successfully paired with the kiosk, Congrats! At this point, you will need to send the kiosk all your current pics. Your blue-tooth should give you an option to send and what information your a restricted to send.
Hope this can be of any assistance. Thanks!
Mar 19, 2009 | Cell Phones
I am using i-mate JAMA 1) I wana know about Bluetooth; how to send and receive files through Bluetooth. 2) how to Turn on WiFi Service and GPS Service Thanks Regards
turn on your blue tooth by clicking the bluthooth sign on the bottom right of your device. and check both the options that appear then( turn on blue tooth and make my device discoverable to all) then your blue tooth is on. ok then press and hold the menus on the file u want to send. when u do it, just beam your file. when u do it. then the device will look for all blue tooths on at that time. select the name of bluetooth u want to send the file. ur problem is solved. by a cute pakistani. love u.
Jan 25, 2009 | i-mate PDA2k Pocket PC
Conecting Blue tooth phone to acer laptop
has your model actually got bluetooth built in as most Acer laptops have the switch, but do not have it fitted, if you do check in control panel> device manager and see if it reports any problems by way of an exclamation mark. You will probably have to purchase a bluetooth usb dongle for about £9.00 or $18 US and use that
Sep 14, 2007 | Computers & Internet
Imate jam PC synch
dear abid, connecting the i-mate to computer using bluetooth is a good and a fast way and give you the an option to connect more than one device, you can connect through bluetooth with this procesure : step one: set up a bluetooth COM port : 1- Open the Bluetooth Devices Control Panel. On the Options tab, select Turn discovery on and Allow Bluetooth devices to connect to this computer. 2- On the COM Ports tab, click Add. 3- Select Incoming (device initiates the connection) and click OK. 4- Note the number of the COM port that was added. The COM port number must be no higher than 20. 5- Click OK to close the Bluetooth Devices Control Panel. step two: 1- In ActiveSync on the PC, on the File menu, click Connection Settings. 2- Select Allow connections to one of the following. 3- Choose the COM Port with the number you noted in Step 1 Set up a Bluetooth COM port. 4- Click OK. Step 3 Start Bluetooth sync from your device: In ActiveSync on the device, tap Menu, then tap Connect via Bluetooth. that's all... and i am waiting for your replay
Jul 27, 2007 | i-mate JAM Pocket PC
i-mate JAM Pocket PC Logo
70 people viewed this question
Top i-mate Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
