Question about Lenovo ThinkServer RD220 Server - 372919U
Lenovo rd220 brd light - Lenovo ThinkServer RD220 Server - 372919U
I have a LG 47LV5500-UA. Power light & shows LG symbol briefly, then no picture. sound went away. Followed SJvideo and there are no backlights, but can see menu on screen with flashlight.
Who are "THEY", will "THEY" pay for the parts if the problem is not fixed with the two boards? I would not listen to them, have a shop that knows for sure repair the problem.
Jul 06, 2017 | LG Televison & Video
Mthr brd FC-GB/ 7VM333M-RZ not working ???
you want to take an format cd an insert it and format the full system and install an windows xp pro as ur operating system and put an 1 gb ram in it
Mar 30, 2012 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
I have a dl 380 g4 it powers up, the hard drive lights come on. I get all green lights no amber. I get no video and the keyboard lights do not come on. It acts as though it does not POST. I have swapped...
Unfortunately, this is most likely a bad system board. Have you tried to RDP or telnet to the machine after it boots? That is, assuming you have some form of remote access enable of course.
Jul 10, 2009 | HP ProLiant DL380 G4 Server
Cmptr not working
reinstall your Windows
Jun 30, 2009 | Gateway GT5654 Desktop PC
Ps3 wont start error code 80010514
Two things it could be. Either corrupted disc (formatting will not help this since it's caused by moving the unit while running, damaging the disc and not corrupting files) or your BRD is malfunctioning. If it is only on games and not on movies,
I would say it's the HDD, if it's on everything, then the BRD. You can get repair parts on Ebay for the BRD by punching in KES-400AAA and it takes about 15 min. for an expert and about an hour and a half for a newbie to replace. Good luck.
Jun 28, 2009 | Sony Playstation 3 (PS3) Console
On the harp al-1631 what does the flashing f then 5 mean ?
*** ALWAYS DICONNECT POWER SOURCE BEFORE REPAIRS****
Check and clean white stripe, make sure it is clean and white.
Check and /or Replace the exposure lamp, they go bad and cause F-5.
If lamp is good, replace exposure lamp sensor.
Check connector ( flat cable) connections to scanner brd.
Replace scanner brd ( board) if defective.
If scanner brd is good, replace power brd.
Jan 18, 2009 | Sharp AL 1631 Copier
50lg 50px5d plasma green light goes on, but no sound or picture
Your friend is probably right. It will either be the Y-sustain brd or the Z-sustain brd. I have seen both bad at one time or another, The part numbers are on the boards.
Dec 08, 2008 | LG 50PX5D 50 in. Plasma HDTV
Picture turned pink
This all of the sudden happened if so you may have lost the green alot of times yoiu can fix the CRT drive Brd there is a video amp ic and a resistor that can be replaced or yo can replace the whole Brd a little harder to do than just replacing the parts on the Brd
Oct 17, 2007 | Samsung HC-P5241W 52" Rear Projection...
Lenovo  ThinkServer RD220 Server - 372919U Logo
23 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
