Question about Pentax Optio W10 Digital Camera
Flash and battery
My Pentax Optio WP flash does not work. Does due to the bad battery or any other reasens
Arcan from Cyprus
  • acar acarcan Jan 21, 2009
    I'm sorry but here in Cyprus where I contuniu to live there is no any expert for repairing such a camera. Can you advise any other solutions. Thank you.
    I've got a Pentax Optio wp digital camera. I dont know why, its flash unit stoped working. I dont know what to do. İs it due to its battery or anything else.
  • 1,596 Answers
See if the BULB is in TACT they are Very Fragile
Posted on Jan 21, 2009
    Top Expert:
  • Pentax Master
  • 77,194 Answers
Verify the batteries are not an issue as advised, if they check ok the capacitor discharge circuit that fires the flash is defective and will have to be replaced, this is a job for a Pentax factory service center, look on the net for a phone number or in your owners guide.
  • 3,037 Answers
Hi Arcan
I assume that you have the flash set to on, but double check again to make sure and then proceed to the next steps.
First try opening up the camera and seeing if there is power going to the flash bulb by attaching a multimeter to it and then seeing if you get any voltage. If you do, then the bulb is bad and needs to be replaced, if you don't then, something else is bad and it is better to replace the camera rather than fix it if you want to have the flash work.
bestdarngood
  • 350 Answers
The flash uses a lot of battery power so even though your other camera features work it's probably the battery!
  • Jack Iaria
    Jack Iaria Jan 31, 2009
    Has anyone here helped FixYa ?
    Hoping to hear from you!
    jackiaria
    For FixYa!!!!
    Sergeant:
  • 221 Answers
Its the problem due to faulty flash unit in the camera.but many a times if the battery is very much old or drained due to overcharging the camera does not get required power to function and due to this weak battery it functions but not properly.sp first replace the battery and check out.and for reparing you can click the link below
for reparing estimates cost of camera
http://www.advancecamera.com/repair
    Brigadier General:
  • 5,158 Answers
Digital cameras "eat" batteries... you need to invest in a set of rechargable batteries
Robert
    Sergeant:
  • 367 Answers
Rylee_smith has it correct unless you do have a bad battery. Then of course this is the issue
    Brigadier General:
  • 3,614 Answers
Can be cause of a bad condition of a battery, it cannot get charged anymore, even you try so...
try using and test it first with a new battery.
  • micromaster
    micromaster Jan 21, 2009
    see also the battery terminal, better to clean for any dirt (battery liquid) that have leaked on each terminal battery contacts.
  • Pentax Master
  • 19,396 Answers
Test the camera with Alkaline new batteries, and check for oxide on batteryu contacts.
If you still get the problem, that is probably a faulty flash unit and must be replaced.
Take the camera to a repair shop for a quick checkup, they will tell you if it is the battery or an internal fault at a glance.
  • Ginko
    Ginko Jan 22, 2009
    If you do not have any onsite technician contact the website below for an estimate, and ship them the camera.
    Advance Camera Repair
    All repairs have one year guaranty.
    Brigadier General:
  • 8,619 Answers
Hi!
Your "FLASH MODE" may be set to OFF!
Check your manual, you probably have 5-6 flash modes available. You need to go to your flash mode and see if it is turned off. Hope this helps
My Pentax Optio M90's Flash has stopped working.. it doesn't matter if I have selected the flash to be on or off it still won't work. Even when setting are set at auto it still won't work...
Hi kerritm,
This indicated that it's time you need to replace your flash , therefore you can get it done via a service center,
The camera's flash has a certain life and you can't expect it to be ok for many years together ,
In unfortunate cases , it stops working due to hard ware failure.
Therefore , Please get the flash replaced and you would be able to use it.
Hope this helps..:)
Jun 19, 2011 | Pentax Optio M90 Digital Camera
Damage camera flash
the flash damage is due to some reason:
1.the flash bulb is broken
2.some wires is not linked as it used to
3.the firmware problem so the camera can`t command the flash to produce light
my advise is contact your pentax official service center near your place
Jan 03, 2011 | Pentax Optio M30 Digital Camera
Pentax Optio S10 cannot take photos in flash mode
HI there check the battery first. Red light blinking in working mode when the battery not having enough power for flashing. So i suggest you charged the battery fully or if its old then replaced it. Thnaks.
Apr 04, 2010 | Pentax Optio S10 Digital Camera
My camera pentax optio wp wont turn on. though is
If possible, check the charger output or the charge status of the batteries with a voltmeter. That will narrow the field for you. If the charger and batteries seem OK, your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Oct 21, 2009 | Pentax Optio E40 Digital Camera
Flash not working
Hi there and welcome to FixYa.
Bad batteries can cause that. The flash module needs alot of power to charge. Your camera will still work, but without enough power to charge the flash module, it may take along time. Again.
Try fresh batteries.
Rob
Feb 25, 2009 | Pentax Optio T10 Digital Camera
Can my pentax optio WP can go underwater without a water housing unit? How deep under can it go?
The pentax optio WP can go underwater without a water housing unit. It can only go underwater about 5 ft.
Aug 30, 2005 | Pentax OptioWP Digital Camera
Pentax Optio W10 Digital Camera Logo
52 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
