Question about Generic KEEBOX W150NR Wireless-N 150 Home Router
How to change dns settings - Generic KEEBOX W150NR Wireless-N 150 Home Router
Cannot get Netflix on. can only see some ad about Alexa. How do I get to watch my shows again.
I suspect that the DNS settings on your computer might have been changed by an advertising program (like a browser toolbar that you might have accidentally installed)?
You can check - and also change - the DNS settings on Windows, using a free program like this one:
http://www.nirsoft.net/utils/quick_set_dns.html
However, I do not know what your original settings might have been.
If you don't know where to find that information (probably through your Internet Service Provider), you could try using Google's free DNS service:
The Google Public DNS IP addresses (IPv4) are as follows:
  • 8.8.8.8
  • 8.8.4.4
More information:
https://developers.google.com/speed/public-dns/
Feb 23, 2016 | Computers & Internet
Tip
How to change your DNS (Domain Name Server) on your Windows computer. Faster...
Hi Thanks for looking.
Your ISP (Internet Service Provider) provide you with Domain Name Server which translates website names to language that computer can understand which is an IP address of the website. Faster the response from DNS the faster your website will load.
In this tip I will explain how to change your Domain Name Server (DNS) in order to speed up your web browsing.
Go to
Start--->Control Panel--->Network Connections
Please note that you may need to switch to "Classic view of Control Panel in order to see default view.
Right click on network connection that you are currently using and choose "Properties"From the list in box choose "Internet Protocol (TCP/IP) and click "Properties" below. You will be shown a window with two tabs and in General Tab you will have options to change your IP address (we don't want to touch this)and option to set DNS manually.
Click on " Use the following DNS address"Now you can change your DNS to whatever you like. I recommend "Open DNS" which is faster then most of default DNS's.
Ok to change your DNS to "Open DNS you need to type 208.67.222.222 in preferred DNS box and 208.67.220.220 in Alternate DNS box.Click OK and then OK again.
Bravo! You just changed your DNS.
slow internet, website will not load, speed up my internet, how to speed up my internet
on May 07, 2010 | Computers & Internet
Find proxy server address
Changing TCP/IP settings Win 7 TCP/IP defines how your computer communicates with other computers.
To make it easier to manage TCP/IP settings, we recommend using automated Dynamic Host Configuration Protocol (DHCP). DHCP automatically assigns Internet Protocol (IP) addresses to the computers on your network, if your network supports it. If you use DHCP, then you don't have to change your TCP/IP settings if you move your computer to another location, and DHCP doesn't require you to manually configure TCP/IP settings, such as Domain Name System (DNS) and Windows Internet Name Service (WINS). To enable DHCP or change other TCP/IP settings, follow these steps:
  1. Open Network Connections by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, and then clicking Control Panel. In the search box, typeadapter, and then, under Network and Sharing Center, click View network connections.
  2. Right-click the connection that you want to change, and then click Properties. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Click the Networking tab. Under This connection uses the following items, click either Internet Protocol Version 4 (TCP/IPv4) or Internet Protocol Version 6 (TCP/IPv6), and then click Properties. 25e7e385-9327-4f7d-aab0-afa5aaf952ba_49.jpgThe Network Connection Properties dialog box
  4. To specify IPv4 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IP address automatically, and then click OK.
    • To specify an IP address, click Use the following IP address, and then, in the IP address, Subnet mask, and Default gateway boxes, type the IP address settings.
  5. To specify IPv6 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IPv6 address automatically, and then click OK.
    • To specify an IP address, click Use the following IPv6 address, and then, in the IPv6 address, Subnet prefix length, and Default gateway boxes, type the IP address settings.
  6. To specify DNS server address settings, do one of the following:
    • To get a DNS server address automatically using DHCP, click Obtain DNS server address automatically, and then click OK.
    • To specify a DNS server address, click Use the following DNS server addresses, and then, in the Preferred DNS server and Alternate DNS server boxes, type the addresses of the primary and secondary DNS servers.
    f598cd96-6bf9-47be-942d-7d0b0afdbd88_47.jpgThe Internet Protocol Version 4 (TCP/IPv4)Properties dialog box
  7. To change advanced DNS, WINS, and IP settings, click Advanced.
Mar 10, 2014 | Dell Latitude D600 Notebook
Netflix is not working
Cannot Connect to Netflix" message
  • Make sure your home Internet connection is compatible (more info)
  • Manually change your Wii console's DNS settings. To do this, follow these steps:
    1. Access the Wii system settings (how to), and use the right arrow twice and select "Internet."
    2. Select "Connection Settings," and choose the connection file (1, 2, or 3) that are you are currently using.
    3. Select "Change settings" and click the right arrow 3 times to reach "Auto-Obtain DNS."
    4. Select "No," and choose "Advanced Settings."
    5. Click into the "Primary DNS" field and enter: 008.008.008.008
    6. Click into the "Secondary DNS" field and enter: 008.008.004.004 Please note: These are public DNS's provided by Google and are subject to Google's Terms of Service. If you prefer to not use this service, doing an Internet search for "public DNS" will provide you with several other options you can use.
    7. Select "Confirm," and then "Save."
    8. Select "OK" to start the connection test. Once the test finishes, try to download the update again.
Oct 16, 2011 | Nintendo Wii Console
My ps3 has an error 80710092 how do i fix it
  1. Change your DNS settings manually on the PS3 via XMB > Network Settings > Internet Connection Settings > Manual. Just allow the default entries until you get to dns, select manual and change it to 8.8.8.8 for the main dns and 8.8.4.4 for the secondary dns.
  2. Go to your router settings, select dmz and add your ps3 IP address to the list and select apply. You can see your ps3 IP address in XMB > Network Settings > Settings and Connection Status list.
  3. Change the password for your PSN account. The easiest way to do so it to log in via their website on a computer.
  4. Restart your ps3, sign in using your new password and you should be good to go :)
May 27, 2011 | Computers & Internet
Error code52131
  1. Manually change your Wii console's DNS settings. To do this, follow these steps:
    5. Click into the "Primary DNS" field and enter: 8.8.8.8
    6. Click into the "Secondary DNS" field and enter: 8.8.4.4Please note: These are public DNS's provided by Google and are subject to Google's Terms of Service. If you prefer to not use this service, doing an Internet search for "public DNS" will provide you with several other options you can use.
  2. If you are still getting this error code after trying the steps above, please call 1-800-255-3700 for further assistance.
May 21, 2011 | Nintendo Wii Console
Can not hook up to internet. error # 52130
Sorry to hear your having issues with your wii's internet. Error code 52130 means your DNS is not set up correctly. You can manually add the DNS servers by these instructions from Nintendo:
"Access the Wii system settings (how to), and use the right arrow twice and select "Internet." Select "Connection Settings," and choose the connection file (1, 2, or 3) that are you are currently using. Select "Change settings" and click the right arrow 3 times to reach "Auto-Obtain DNS." Select "No," and choose "Advanced Settings." Click into the "Primary DNS" field and enter: 8.8.8.8 Click into the "Secondary DNS" field and enter: 8.8.4.4"
This updates your DNS with google's DNS servers.
You can see the full support article at:
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=52130&system=Wii&locale=en_US
Apr 29, 2011 | Nintendo Video Game Consoles & Games
Problem with the Sony Playstation 3 (PS3) Console PS3 says DNS error (80710102) when i try to connect to the internet with a wired connection
Try changing your DNS settings on the PS3 or on the router
Changing the DNS on your router: Go to 192.168.1.1 Default password is: admin Static DNS1: 208.67.222.222 Static DNS2: 208.67.220.220
Those DNS setting are from OpenDNS
After doing this, reconnect your PS3 to the router and set it to Automatically adjust the settings. Once you have reconnected, check if you are still having the DNS problem.
If you are still experiencing the problem, try changing the DNS directly from the PS3 Go to Internet Connection Settings and set everything to Auto except DNS When asked if you should set the DNS automatically, choose "Manual" Input the same DNS settings: Static DNS1: 208.67.222.222 Static DNS2: 208.67.220.220
Apr 09, 2011 | Sony Playstation 3 (PS3) Console
Im trying to connect online with my ps3 but it keeps on saying it had an error with the server and that it is a DNS error.. what should i do???
Renew your DNS configuration or change the DNS settings to Obtain DNS server address automatically.You can change that in your network connection settings.
Nov 05, 2009 | Computers & Internet
Generic KEEBOX W150NR Wireless-N 150 Home Router Logo
Top Generic Computers & Internet Experts
D. E. Hev
Steve
Are you a Generic Computer and Internet Expert? Answer questions, earn points and help others
