Question about Zodiac Clearwater Lm2-24 Complete Salt Cell - W202051
Broken electrode on outside . Chlorinator not producing chlorine
    Top Expert:
  • Zodiac Master
  • 8,163 Answers
Check cell for calcium and replace cord with cell also check sensor
Posted on Nov 30, 2017
3 Suggested Answers
thepatioman
  • 52 Answers
SOURCE: Can't adjust the chlorine output level of Zodiac LM3-15
Nost often it just needs to be cleaned. Calcium build up can clean in a tub of 1 Part muratic acid to 5 parts warter. or a 2 to 1 soultion of vinigar and water, otherwise it could be faulty. Cleaning typically works.
The Pool Tech
Posted on Jul 14, 2010
Ironfist109
  • 3018 Answers
SOURCE: Hi..my duo clear is leaking
  • It sounds to me like the threads on the chlorinator cell have stripped so that even a new cap will not bite the threads properly. Normally I would say try a new "O" ring and possibly a cap but you replaced them already. This leaves the teeth the cap grip as the only possible reason for it leaking. Unfortunately the fix is a new chlorinator jug.
  • You may want to take a look at the new "O" ring and make sure you got a good one. Make sure you push it clear down past the the last thread with your fingers first.
  • Inspect the new cap for cracks or splits. New stuff is not impervious to defects.
  • Unfortunately when plastic to plastic is used, often times things strip and sometimes it can be costly. It's the price of manufacturing cheaper items. It cost less indeed but they break faster too.
Good luck to you, best regards, Tony
Posted on May 17, 2011
Ok i have the intex 1600gph sand filter saltwater combo system and my pool hold 8000 gallons i can run the chlorinator 24 hrs a day and it will not get the chlorine and free chlorine above 1 the ph is 7.5...
Yes, what is your stabilizer level? It should be between 30 and 50 ppm. If the stabilizer is too low then the sun will cause the chlorine to dissipate faster than the chlorinator can produce it. Some salt chlorinator manufactures recommend 80ppm but that reduces the chlorine efffect. If you can't get the chlorinator working then using a floating tablet chlorinator is a good option to keep the pool open. I hope this helps.
Aug 12, 2011 | Intex Automatic Salt Water System for ...
Intex salt water chlorinator I added a higher flow pump and chlorine levels seem low no matter how many hours I run the chlorinator
your pump has nothing to do with chlorine generation.
You need to get a salt test kit that reads in #'s not colors.
Now get your salt to 3000ppm or as close to it as you can.
The amount of salt reccomended in the manual is just a starting point
any lower than 2800 and you will not produce enough sanitizer and over 3600 and your pool can go cloudy, taste bad, and rust metal parts
Jun 28, 2010 | Intex Automatic Salt Water System for ...
Cleaning the inside -Pentair 320 Chlorinator Model R172276
their is a set screw in the side of the chlorinator towards the bottom (you should see a little hole in the side of the chlorinator near the base). remove that screw and the chlorinator will unscrew from the base.
Jul 13, 2009 | Pentair 2.0 Hp Whisperflo Pump
My intex saltwater chlorine generator & filter beeping forever!!!
hello our pool chlorinator keeps comming up low salt 91 no matter how much salt we put in this is frustrating why is this happening ,,,please help
Jun 06, 2009 | Intex Automatic Salt Water System for ...
Zodiac Clearwater Lm2-24 Complete Salt Cell - W202051 Logo
55 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
