Conia split system won't turn on
I have a Conia split system air conditioner and it just won't turn on using the remote, tried changing batteries and now looking for manual switch on unit
SOURCE: Westpoint split air conditoner remote contol unit
I want to locate a Eolia West Point A/C remote
Posted on Oct 23, 2008
  • 400 Answers
SOURCE: Kelvinator Split System Air Conditioner not turning on.
On some remotes there is a reset button which is pressed by using the nib of a pen. Or if this does not work you should look under the cover for a manual button, most units have one, and see if the aircon responds. I suspect your remote sensor is faulty, but try the previous suggestions first.
Posted on Mar 05, 2009
SOURCE: remote control not working for split system
slide the slider down until it stops, then lift/prize the middle of the slider lid upward (or outward,, however you concieve it) and continue sliding the final 2cm. Voila! batteries are revealed. 2x AAA.
Don't understand? (Don't worry, my wife can't do it even after watching me do it TWICE !!)
Okay... the slider stops about 2cm from the bottom of the remote (when slid down as far as it will go). The reason for this is a small catch in the middle of the remote, just below the lidof the slider-bit. You need to LIFT the lid of the slider over that catch. The reason I use the word 'prize' beacuse you'll need to dig your fingers downwards, just below the TIME ADJUST button, and at the same time work the lid upwards against this pressure. LIFT / PRIZE the lid up in the middle, and away it comes!!
Still don't get it? YOU ARE USELESS and must go and pay one of the clever people to do it for you, *******!!!!!
Ha Ha aaaahhhh!
Posted on May 13, 2009
SOURCE: Remote does not turn on or off the Split System Air Conditioner
take your cellphone and turn on the camera,then put the remote in front of the cell and push any button.if you see the light of the remote to the cell then the remote is ok and the problem is to the eye of the plate.its a small plate in front of the split
Posted on May 29, 2009
SOURCE: I have a Panasonic split
I have a A C Panasonic, I m operate with remote bat not communicate, and than b emergency switch. indoor unit "on" but out door unit doesn't running. what wrong?
Posted on Jun 10, 2010
Is Conia air conditioner CA24001 split system reverse cycle I cannot get heat?
Sounds like either bad reversing valve or to get you going during the summer someone may have wired it to stay energized all the time which would have been a thermostat problem.
May 30, 2016 | Dometic Heating & Cooling
How do I turn on heat on my air cond. Conia split system?
if it is set up for it
no heat on/off button on ours
we increase the the temp setting till warm air flows
May 30, 2016 | Heating & Cooling
Conia split system operating manual
Not sure if this is what you are looking for. A Make and Model would be a great help in finding the information that you are looking for. So we at West Palm Beach Air Conditioning would love give you a hand.
Manuel:
https://highcongtana.files.wordpress.com/2015/10/conia-air-conditioner-manual-ca24003.pdf
Oct 16, 2015 | Heating & Cooling
Remote with new batteries won't work
Even after replacing new battery cells only ON/OFF button responding and other buttons are not responding. Pl suggest how to solve it
Jul 15, 2012 | LG LSC121PMA Split System Air Conditioner
Need a conia airconditer remote control here in Australia. We have 2 split systems that use the same remote. Models CA 24003 & CA 3003. Conia have gone bust here and we can't get a replacement remote....
i had the same problem and i managed to find a universal remote control from JARCAR Electronics. Model of the remote: Digitech AR-1729. It doesn't list Conia as compatible but I managed to gain control of the aircon using the code: 291. For some reason when you press the power button on the remote, it's like your double pressing the on button so the aircon switches on and off quickly. You need to press the power button on the remote quickly and move it from reception before it powers down the unit again. At least I have control of the aircon again and I don't have to put up with these humid hot days in melbourne... Good Luck.
Jan 01, 2010 | Heating & Cooling
Conia 3 HP, 5 yr old air con/ condensation from wall unit
NOW, THE EVAPORATOR COILS NEEDS CLEANNING OR THE DRAIN LINE PLUGGED,OR JUST CLEAN THE FILTER.
Nov 30, 2009 | Heating & Cooling
Jan 18, 2009 | Heating & Cooling
Stand By Mode
1. use remote properly
2.first off the unit then again the unit
3 if same problem change remote by new one
Mar 18, 2008 | Sanyo 24KS62R Cool Mini Split Air...
Heating & Cooling Logo
56 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
