Question about HP 1220 Plain Paper Inkjet Fax
HP 1220 Fax had message :cartaridge jammed"
I looked inside and the belt is broken. I don't know if that is why the cartridge was jammed or if someone was trying to ujam and broke it. Could I get an approx cost for repair.
    Novelist:
  • HP Expert
  • 297 Answers
Belt is $15-$25 and labor will be $50 - $75...depending on where you take it. Here is a diagram with part numbers if you would like to try and replace it yourself !
http://www.partsurfer.hp.com/cgi-bin/spi/quickpic?model=C8461A&picture=OJ-K/PRT_MEC2
Posted on Jan 22, 2009
Hp laserjet 1200 printer.. i have a paper jam.. i've looked all over to see where i access the roller to get the paper out and i can't find it!
Paper Jammed can be found inside the toner cartridge compartment.
It can also be found in the paper feeder.
It can also be found at the back of the printer (if it can be accessible or can be open).
It can also found in the toner cartridge itself.
Check this areas to find for a paper jammed.
Jun 08, 2011 | HP LaserJet 1220 Printer
Number of color ink toner cartridge for hpfax 1220 purchased an old machine and the color toner cartridge was missing. I need to know the toner number to make a purchase
go to this web site for the type and number of your cartridge.
You DO NOT have to buy from them, but it is the first I found with the number.
http://www.worldclassink.com/ItemListing.aspx?Id_PrinterFather=9110&crcat=GG&crsource=GG+Model+Num&crkw=hp+fax+1220+ink&gclid=CNjxwJH1qqQCFY5a7Aod7Uj-5A
good luck and don't forget to vote!!!
Sep 28, 2010 | HP 1220 Plain Paper Inkjet Fax
The alarm keeps flashing and the message says there is a paper jam. I cannot find a paper jam, but the fax cannot retrieve items in memory either.
Hi;
  1. Remove the cartridge look inside is there any paper rmove it carefully
  2. remove the paper from cassette
  3. load the paper again
Aug 10, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
Jammed paper
There are 3 places to check for jammed paper.
Turn off the fax machine, then remove the tray and open the back cover, and open the front cover to remove the drum and toner (cartridge) and look inside machine.
After you find the jammed paper put the cartridge and tray back in machine and close all the covers.
Error message should go away.
Apr 06, 2010 | Brother IntelliFax-2820 Laser Fax
My printer carriage won't move???? It is an HP C 4180 printer. I put in a new black ink and it jammed. I know how to install the ink and nothing happened that was different except now it won't move. Can...
Make sure the cartridge is firmly seated in its holder. It's possible that the carriage belt has broken or has slipped off the motot pulley. Look inside the printer and locate the flat toothed belt that pulls the carriage back and forth. follow it to either end and make sure that it isn't broken or slipped off the motor.
Jan 24, 2010 | Office Equipment & Supplies
HP Laser Jet 3055- "No print cartridge" message
This could also happen due to the censors.
Try these steps.
1. Take all the papers out from input tray.
2. Open the cart door & take the cart out,and let the door be open.
3. Turn Off the printer.
4. Clean the metal contacts on the cart.
5. Reinsert the papers & the cart.
6. Turn the printer on.
This could resolve the issue.
All the Best!!!!!!
Feb 27, 2008 | HP LaserJet 3055 All-In-One Printer
Replaced Ink Cartridge
turn fax machine off open cover and put 3 drops of 3 in 1 oil on the the big silver bar the ink cartridges ride along perform alignment and try to recieve fax if this doesnt work clean all the rubber feed rollers with isopropanol alcohol (rubbing alcohol) applied to a microfiber towel then try.
Jan 15, 2008 | HP 1220 Plain Paper Inkjet Fax
Brother intellifax 770
did you take out the cartridge and look inside, the papre might be under the cartridge.
Oct 26, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
HP 1220 Plain Paper Inkjet Fax Logo
761 people viewed this question
Ben Johnson
