Question about Altec Lansing MX6021
How to power up Altec Lansing MX6021 without controller
Missing controller
SOURCE: Finding replacement Power Supply for Altec Lansing
I did the same! Thanks for suggesting a call to Customer Support (800)258+3288. The guy didn't seem overly pleased to help, but he did promise to send me a new power supply. Also, he said that they don't make the iM7 anymore, but I had already found out that the iM9 uses the same power supply. I, too, will wait and see.
Posted on Jul 07, 2008
edwinmeyer
  • 57 Answers
SOURCE: I have Altec Lansing AVS 300 multimedia speakers with no power
Unfortunately the subwoofer supplies the power to the amp on the speakers, Once again I have the solution,
These speakers are factory molded so that the only way to open them is to break the factory seal
this can be done by sharply rapping the seam at the bottom of the speaker with a heavy screwdriver handle or something similar.
Now you need to supply power to the amp...If you do not have the subwoofer you will need a 4.5volt power supply, after removing the board from the casing find the red white and black wires connecting
the orange plug wire to it, Personally I removed the entire cord from the unit, shough you can splice in at this point if you desire.
Connect the white lead to your posative on your power supply by either splicing or soldering, connect the ground to the heat sink using the screw that is already there holding the chip to the sink. reassemble the speaker.....super glue... and you are now in business.
Ed Meyer
Owner AACS
www.alwaysaffordablesolutions.com
Posted on May 22, 2009
  • 4 Answers
SOURCE: how to repair atp3 altec lansing
Best bet would be to just strip the wire with a wire stripper or utility knife and twist the bare ends together to fix the connection. A little electrical tape around those wires and you should be almost good as new. Of course you might notice some difference in quality but I'm pretty sure the only way round that would be replacing the cable.
Try it out and let me know how it works out for you. If you know how to solder it might be a good idea to solder the connection as well.
Posted on Jan 05, 2008
SOURCE: Altec Lansing PT7031 - ''Panel Key is Locked''
With the unit turned on...
Press the following front panel buttons in sequence within a 10 second span:
[Vol+] / [Vol-] / [Vol+] / [Vol-] / [Vol+] / [Vol-]
Successful unlock is indicated when the front panel led's flash.
Posted on Jul 01, 2009
  • 10 Answers
SOURCE: Altec Lansing ATP3 volume control/power know gone bad
just sone it, i had to break a whole in the bottom part , work my way around it with a screwdriver , it will snap every 2-3 cm and come off in the end.
after its off start at the (now exposed) bottom of the front bit and work your way up and aroud `till it comes off. mind the wires . as for the volume button fix , as soon as i played with it and tried it again , everything was good. even though replacing it doesn`t seem like a big deal
put it back together and will superglue it in the future( while typing this i doubt if it will ever happen), and it lookes good( except from the bottom ,where its broken !).
now the button is solid and the sound as well.
SWEET
SWEET
Posted on Nov 05, 2009
Pins out diagram for controller
theres an app or your phone you can download for free called ElectroDroid ,its on google play store .this has alot of info for Pin outs .best part is its free ,hope this helps
Apr 30, 2016 | Altec Lansing MX6021
Altec Lansing Mx6021 power supply
Hello there!
Can you be more ...specific on your problem?
thanks
Carl
Jan 28, 2016 | AccessData Password Recovery Tool Kit (ftk...
Power trafo altec lansing atp3
Is the label missing? All the information is printed on a label or stamped into the plastic housing. Have you opened it? Many have an internal fuse you can replace.
Jul 15, 2014 | Audio Players & Recorders
Mx6021 power supply burn
The cost to repair these speakers would be prohibitive. Get a replacement system on ebay.
Mar 22, 2014 | Altec Lansing MX6021 200 Watts RMS 2.1...
Left tweeter is not working
The tweeter could have failed. Failure of a single speaker does happen occasionally
May 10, 2013 | Altec Lansing MX6021
I recently found some awesome altec lansing speakers with a huge sub too. but ... i can't find the volume control knob and without that, i can't make it work !! T___T any solutions? i tried looking for...
Hi there, by saying you found, do you mean that is a complete set, I have the same speaker set, and the volume control knob is on one of the satellite speaker. If you are missing that speaker I doubt that you can do anything with it because you will most likely find them for sale as a set and not separate. Thanks hope this helps.
Mar 09, 2011 | Altec Lansing ATP 3W Computer Speakers
I'vebeen given an Altec Lansing Spealer system, AVS500, for a computer, but it is missing a power supply; 18 volts DC and 1 amp. Altec Lansing no longer make that series or its components Any...
lost instructions on how to hook up. Large speaker makes static. Right speakers work great.
All colors match but can not find the proper jack for the black wire coming out of large speaker
I suspect this is the problem
Oct 17, 2008 | Altec Lansing AVS 500 Computer Speakers
Altec Lansing MX6021 Logo
2,695 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jerry Umali
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
