Replacing a dual SD receiver(VIP 322) with a dual tuner HD/SD receiver(VIP 221K). Don't have any smart cards for the new receivers. Also adding another VIP 221K as a replacement HD solution for the second tuner TV that is a VIP 722.
SOURCE: I have a ViP 722.
Okay I am not positive I have this right as far as the configuration of the system but I will give it a shot. If you run the 722 to the tv using rca's you get the hum. I assume this as there are no inputs on a dish 722 receiver. I can suggest one possible solution which is to buy an rf modulator. It will convert the signal from rca to coax so you can connect as you wish. There are several types out there so ensure you get the one that converts from rca to coax. I would suggest the following configuration: Remove all connections from tv and hook 722 up via rca's to rca input 1 on the tv, check for hum. If it is present now you need a new 722 as it is passing to much power thru the connection. If there is no hum connect your cable and tivo to the tv via whatever inputs you have remaining. Lastly connect the DVD player to another input that is free. You will have to system through your inputs to view the three sources but should not have the hum. I hope this solves your issue. Thanks for using Fix Ya and let me know if I can be of further assistance.
SOURCE: 322 dual tuner-failure to receive signal only to one TV
If you have one cable leading from the wall toward the back of the receiver you can disconnect the seperator and diplexer (if equipped) from the SAT 1 and SAT 2 ports and connect the line from the wall directly to one of the ports and run a check switch test. You should get a 1 of 2-4 depending on lnb type on the tuner you connected the line to and a 1 of 38 on the other. Perform this operation for both SAT 1 AND SAT2 as described above. If you have the 1 of 38 appearing only on the port that the line is not connected to then the receiver is good and the problem may be the seperator which is the silver device that has two wires going to the back of the receiver initally and one port connected to the SAT port of a diplexer. Disconnect the diplexer and hook the seperator to the receiver and run the SAT line from the wall to the single port of the seperator and do a check switch. If you don't get a 1 of 38 it is good and you have a bad diplexer. If your system does not use diplexers and you are experiencing the loss on TV2 you may have a bad TV2port on the receiver. You can take the wire from the TV2 PORT(in home distribution system) and place it on the 3-4 that the TV1 line is run from. Then go to TV2 and put that tv on channel 3 and see if you have picture. If the problem is at TV1 reverse the process by connecting the line on the 3-4 ut to the TV2 port and putting TV1 on chanel 60 or 73 and see if you get picture. if either produces picture on the bad tv the port to that TV is faulty. If you were still unable to get picture it may be a cabling, connector, barrel isssue that requires a tech to visit. Hope this assists you. Thanks for using Fix Ya.
SOURCE: 60hz hum
I sent a solution to this already. If you did not receive please let me know. Thanks for using Fix Ya.
SOURCE: my dish 322 receiver wont work 2 tv,to get service
SOURCE: dish vip 622 and vip 722k frequent picture freeze and restart
Sounds like a signal strength issue. You may have either a low signal or something like a tree limb is blowing into the signal path dropping the signal strength to a point low enough to causes issues.
