Question about Maytag Washing Machines
Maytag commercial washer 8541652. The 3amp fuse keeps blowing
How do I find out what model I have?
aborcass
  • 2651 Answers
SOURCE: Maytag stackable washer top loader
try replacing entire lid switch assy, come ith new fuse!
Posted on Oct 31, 2008
  • 4 Answers
SOURCE: Fuses keep blowing out
IF water is not going in the drum It sounds like the water valve coil has finally failled , It has been blowing fuses ,because the ccoil on the water valve was getting weak . change this water valve and you sohould be ok , but before doing so chaeck to see if you have the proper voltage going to this valve when It is calling to open ,if the power is there and the water is turned on the valve should be letting water in the machine . you can also take a ohm meater and check the valve for proper resistance . . If the machine is up in years I would change this valve . from the chack I mentioned earlier . hope this helps you
Posted on Nov 27, 2008
  • 77 Answers
SOURCE: fuse keeps blowing out in my maytag washing machine
replace the complete lid switch ***'y. be sure to adjust properly.
Posted on Dec 03, 2008
jumptrout51
  • 3361 Answers
SOURCE: Maytag washer blows 1.5A fuse in back of the top compartment where the dial etc is
There is a micro switch next to the fuse. It is shorted out. Replace the micro switch and solve your problem.
Posted on May 20, 2009
SOURCE: Program computer-Maytag commercial washer mat12pdbaw
Try going to this website and scrolling down to find your Maytag Model number. Click on the model number and the programming steps should come up for you.
Anonymous
Posted on Feb 23, 2011
How to repair maytag washer so it stops blowing fuses
The problem may not be with the washer, you may have it plugged into a circuit that made to carry the load. Check the owners manual to see if it tells you what the draw is and then see if that circuit is made to carry that large of a load
Oct 18, 2014 | Maytag Neptune Washing Machines
Maytag washer
You posted this question in the car and truck section but I'll give it a go.
What is the model number, and which fuse ?
May 02, 2013 | Cars & Trucks
I own a maytag atlantis top load washer model LAT4914AAE and the fuse located behind the knob controls blows when ever i go to wash a load
The reason the fuse keeps blowing is because one of the two switches their where the fuse is is bad and drawing to much amperage so the fuse blows. THe lid switch/fuse asm comes together and it should be replaced.
The part number for that switch assambly is 22001682 it could be purchased at your local appliance parts store or online at;
searspartsdirect.com
apdepot.com
partselect.com
apwagner.com
repairclinic.com
GENE
Sep 23, 2011 | Washing Machines
Fuse blown on Maytag washer
Could have been a surge dont think its anything to worry about ....run and keep an eye on it ....
Apr 12, 2010 | Maytag PAV2300 Top Load Washer
My washer continually blows a fuse
If your machine is the Maytag stacked washer/dryer combo, there are a couple of areas I would look at. The first is the lid switch assembly. The fuse is a safety device designed to blow if the lid switch malfunctions. The two lid switches interact and if they don't both switch at the same time it can blow the fuse.
The second thing to try is to wash a load on cold water only and see if the fuse blows. See if there is a water supply issue. Check the water inlet valve. Remove the water supply hoses and check the small screens in the water inlet valve. Make sure they are clean and clear of rust or debris. Use a mulitmeter or ohmmeter to check the solenoids for continuity. A lack of continuity would indicate a faulty solenoid and the water inlet valve assembly will need replaced. These are a couple of things to consider. Hope this helped and best wishes.
Aug 15, 2009 | Maytag LSE7806A Top Load Stacked...
May 20, 2009 | Maytag SAV571EEWW Washer
Blowing fuses
if you have a friend with a multimeter then you can trace the fault backwards from the plug to see when exactly the short circuit happens without plugging the machine into the mains using the multimeter terminals as the mains terminal and advance the timer by hand to see where the short accurses on the dial so you can see weather the short is the heating element or not that's the main cause of short circuits eric
Dec 26, 2017 | Maytag Commercial Non-Coin Washer,...
Fuse keeps blowing out in my maytag washing machine
the power surge probably shorted out something in the main wire harness or fried your motor. remove the screws from the control panel and look for any wires that are discolored, charred or disconnected. in the event you do't find it there trace the wiring thru the cabinet looking for the same thing. if you don't find that, replace the motor
Nov 16, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
