Washer dial clicks round, but washer stops doing anything useful
We're having intermittent trouble with our Maytag washer A9600. Sometimes during a load the dial continues to click round but the washer stops doing anything, leaving a tub full of wet clothes and water.
On occasion the dial has also failed to stop at the end of a cycle, and continued on to the next cycle.
We thought the belts might need changing, but that didn't solve the problem.
Is this the timer? Motor? Any ideas? Please help!
  • 15,935 Answers
It appears your timer, itself, has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
Squealing During Operation
Probably a worn bearing or a belt slipping, if it has one.
Jan 10, 2018 | Maytag 24 in. MDB7601AWS Stainless Steel...
How to trouble shoot maytag timer nob
There is still water in the machine , the pressure sensor my not be operating there is a loose contact in the motor spin winding or the timer no supply voltage is going to the motor check the votlage at the motor at spin cycle
Sep 20, 2012 | Maytag SAV3710AWW Washer
Maytag washer (model PAVT244AWW). Won't spin. Don't know how old it is or its history, as it came with a home we purchased in October. Several times it's "walked" during the spin cycle. About 6 weeks...
Its the clutch ,And it sounds like it time for a new washer,the clutch is expensive and washer are cheap try a second hand store that sale scratched or almost new machines
Jul 05, 2010 | Maytag PAV2300 Top Load Washer
Fuse blown on Maytag washer
Could have been a surge dont think its anything to worry about ....run and keep an eye on it ....
Apr 12, 2010 | Maytag PAV2300 Top Load Washer
Washer is acting erratic. spin cycle works sometimes. stops half way through cycle sometimes. got a new belt. what's next? pump or timer. both are spendy $ thanks. frigidaire FTR630ASO
The control monitors the door lock prior to and during the spin cycle as a safety feature. The washer will not advance to the spin cycle when the door lock is not activated and stops when the lock is deactivated during the spin cycle.
In your case, the door lock is working intermittently causing the washer to spin intermittently. This is probably due to a faulty door lock and switch assembly or poor connection at the control board or at the assembly itself. Replace the door lock and switch assembly if necessary.
Apr 06, 2010 | Washing Machines
Clacking sound on agitate cycle only, no noise on spin
The agitate cycle uses the motor and a spring to function. The spring is made in pieces and asit gets older some of the sections of the spring break. To verify that it is not a loose drum. Ope the washer during the wash cycle andhold the drun by hand. If the noise stops lool for the loose bolts or replace the springs, they may be weak after that many years.
Aug 18, 2009 | Washing Machines
I have a Maytag A9600 washer that has been acting up. Sometimes during a load the dial will continue to click round but the washer itself will stop doing anything useful. Sometimes this means that the drum...
It appears your timer has failed in this instance.
Jan 21, 2009 | Washing Machines
My Maytag Washer
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
The washer is equipped with a lid switch failure detector. If the lid switch
should malfunction, the detector will stop operations for your safety.
Read below
First,turn the control dial to proper cycle and pull dial out to start the washer. If
equipped with buttons, be sure they are fully depressed.
Close lid and pull dial out to start the washer. For your safety, washer will
not agitate or spin unless the lid is closed.
should malfunction, the detector will stop operations for your safety. Call for
service.
Pauses are normal. Wait and see if the washer will start again.
Please remember to leave a rating before you go!
Thank you
Sep 16, 2008 | Maytag Atlantis MAV6000 Top Load Washer
INDESIT WI101
hiya
these machines will do this if the timer dial has been moved during a cycle, they have a memory chip on the main circuit board.
they also do this if the machine has a fault with the exception that they dont stop, the doorlock light flashes and the timer just keeps clicking.
try setting the timer to a dot on the settings then switching the power on, the doorlock light will flash a few times, turn off again select program then switch back on, machine should now be reset and work ok, if not then count the flashes of the doorlock light as this indicates a fault code.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Aug 04, 2008 | Indesit W 123 Front Load Washer
My Maytag front loading washer does not fully rinse cloths MAH8700A. I purchased this washer about 6 months ago. I usually wash small loads but have noticed it doesnt matter what size load. When first...
Is the drain path free-flowing? That is, does the water eject freely during spin/rinse? Maybe there's a restriction in the line, or it's too high above the washer.
Feb 25, 2007 | Maytag MAH8700A Front Load Washer
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
