Question about Olympus Camedia C-2500L Digital Camera
Power Circuit I need to replace my power circuit. It's kind of impossible to find it here in the philippines. can anyone recommend a site where i can order it.
    Genius:
  • 2,985 Answers
The simple answer you will not find any parts available for digi cameras- because there are none- the makers don't work that way in the main. If the camera is Young[ish] the Tech Support team may offer to replace the camera or charge a modest fee for a swap out. But finding spares - Nah!
Posted on Jul 03, 2007
SOURCE:
I have an insignia model me-37d20sna14. We turned it on one night and the screen was almost impossible to see. If we turned the bedroom light off I could at least see the picture. There is audio
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board...
Feb 06, 2017 | Insignia Televison & Video
I have an RCA model LED42C45RQ with a blank screen. I have audio, no back lights, but I can see a picture on the screen with the flashlight test. What do you recommend replacing? Thanks
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Dec 31, 2016 | RCA LED42C45RQ 42" LED TV 1920x1080, 60...
TV has no picture has sound model L40E62AZ an anyone help
http://electro-medical.blogspot.com/
Mar 21, 2016 | Televison & Video
TV less than 3 months old.No picture but still got sound.Anyone any idea what fault might be.
Feb 20, 2016 | Televison & Video
Does anyone know which capacitor I need to change on the circuit board to stop the display screen from flickering?
Flickering can be of many reasons. A fault in the power supply board too can cause this. Contact any service technician before replacing anything.
Sep 24, 2015 | Televison & Video
Which components do I need to check following a voltage surge (lightning) on Hitachi colour TV CL32WF810AN.
If the main fuse should blow up; surely there should be a short circuit to any component/s at it. If the secondary [DC] fuse also has blown up, there should be a reason for it too.
You should first check out the main power board alone, and then the secondary board connected. It will be impossible to follow these without its schematic diagram. Try to download it by internet. Without proper guidance; how can we follow the complicated circuits, and check the components?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 06, 2014 | Televison & Video
Television switches off by itself.
There is some kind of short circuit to any of the component/s at its circuit board. Short-circuit protection circuit [built in] energizes and shuts off the TV each time you switch it ON. The fault location to this kind of trouble is a skilled work and not a user repairable one. It is best to contact any service technician. Its main power supply regulator section circuit should be troubleshooted. Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
google.com/+GopakumarGopalan
Dec 02, 2013 | Televison & Video
Power will not go on after machine was dropped. Plastic was broken broken on the top of the device near the power connection but the circuit board appears to be undamaged.
The board may appear undamaged, but the instrument's behavior says something is broken. I have no idea what kind of musical instrument this is, but circuit boards are all the same.
Especially on boards with narrow circuit traces and surface mount parts, damage can be very hard to see. A trace might have a hairline break which would be impossible to see without bright light, strong magnification, and some idea where to look.
It's also possible that the board is fine, but some part has been damaged. The lead from some part may have broken away from the circuit trace, for example. Or a small surface-mounted component may have popped off completely or had a lead broken off.
Unfortunately, this kind of trouble is very hard to fix without detailed product information (circuit diagrams and board layout). Unless the manufacturer makes a service manual available to the general public, this means sending the unit back to them or an authorized service center for repair.
Feb 03, 2010 | Zoom Music
Sharp 42' LC-62C42U main circuit board needs replacement
I would recommend Shopjimmy.com.
Parts are at reasonable prices. Compare with the prices at Partstore.com and you'll see what I mean.
Aug 06, 2009 | Sharp LC-62C42U 42 in. LCD TV
Power button flashing red, cannot turn on or off...
this symptom is usually caused by a breakdown in the power-supply circuit. in most modern receivers (transistorised and/or ic), it may also be caused by a breakdown in the horizontal deflection circuits (horizontal oscillator, pre-drive or drive circuits.). this is because the supply volatages for the tuner, video intermidiate frequency(VIF), video amplifier, sound intermediate frequency(SIF) and vertical output circuit are usually supplied by the horizontal output circuit. since you are not inclined with this kind of job, better bring it to a qualified tv technician. with regards to the cost of repair, i cannot tell you the price since my location is different from yours. but to give you and idea, here in philippines $100 is enough for this kind of trouble!
Feb 12, 2007 | Toshiba 32AF42 32" TV
Olympus Camedia C-2500L Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
