Question about IBM ServeRAID-7k Controller (71p8642) SCSI Controller
Slot 4 not responding error code 2300 - IBM ServeRAID-7k Controller (71p8642) SCSI Controller
Hp Laserjet 2300 showing error 53.10.03
  • 53.xy.zz
  • CHECK RAM/ROM MEMORY
  • Description
  • There is a problem with the printer random-access memory (RAM) or read-only memory (ROM). The DIMM that caused the error is not used. Values of x, y, and zz, are as follows:
  • x = DIMM type
  • 0 = ROM
  • 1 = RAM
  • y = Device location
  • 0 = Internal memory (ROM or RAM)
  • 1 to 3 = DIMM slot 1, 2, or 3
  • zz = Error number
  • 0 = Unsupported memory (for example, presence detect bad)
  • 2 = Unsupported memory size
  • 3 = Failed RAM test
  • 4 = Exceeded maximum RAM size
  • 5 = Exceeded maximum ROM size
  • 6 = Invalid DIMM speed
Jan 04, 2015 | Office Equipment & Supplies
Nokia RM-4 2300
If you have a problem with unlock code for your Nokia 2300 . Visit the site Unlocking-free.com . They ask you to provide the country name , network provider name and IMEI number of your Nokia 2300 . After that they deliver the code for your Nokia 2300 through mail .
Dec 23, 2012 | Cell Phones
HP LASER JET 2300 52.00 ERROR
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
4. Replace the engine board.
Tallon41
Sep 12, 2012 | HP LaserJet 2300 Printer
I need security code to lock and unlock my nokia model 2300 but when i try to switch on it say code error . please suggest to reset the security code
you can get the reset code for your nokia 2300 model mobile through this site www.mobileunlocksolutions.com/nokia-dct-master-code-service/rs1wp10 , it has the best services for the master reset code for your nokia mobile .........
Sep 12, 2011 | Nokia 2300 Cellular Phone
Fatal Error 14h 2300 DL
printer.konicaminolta.com/service/ASP/mc2300/.../mc2300SM.pdf
this link is going to take you the manuel that what you have to do when you got an error.
Nov 16, 2009 | Konica Minolta magicolor 2300DL Laser...
Mei35297100/520742/4
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 3123526611 (Unlock code)
Follow this instructions carefully
1 - Switch on your Nokia 2300 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 2300.
3 - Compose #pw+CODE+1#.
4 - The Nokia 2300 would then display the message "SIM Restriction Off" and will be unlocked!
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE ( Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 3123526611) you need to enter is the unique unlock code for your Nokia 2300
Nov 07, 2009 | Nokia 2300 Cellular Phone
ERROR CODE E3 -50 (PANASONIC FP 7742)
E3-50 is the malfunction of the transfer wire cleaner. The transfer wire assembly is under the drum. The transfer wire is on the right. The cleaner moves back and forth. If you feel comfortable taking it out, respond. There are fine metallic wires in each slot, so don't break them
Oct 04, 2009 | Panasonic FP-7735 Black and White Copier
Memory Install Problem. I have just tried installing an extra memory module to my HP Compaq V3000. Was 512K, tried adding 2G. The laptop stopped responding and now won't boot at all even when I removed the...
Hi four short beep codes generally means faulty ram in the first position. If the old RAM was working fine, then try using it in the other slot and see what happens. You may have damaged a pin installing the RAM, if it works in the other slot, remove it and inspect the damaged slot with a magnifying glass and see if you can spot a bent or missing pin.
Let me know how you make out,
Chris
Aug 10, 2009 | Computers & Internet
Canon imagerclass 2300
You will need to see if you can clear the code through service mode, if the error code comes back then you will need a technician to replace your fuser unit.
Aug 04, 2008 | Canon imageCLASS 2300 All-In-One Laser...
Forget my Nokia 2300 Security Code.
my nokia 2300 has been locked.When the phone starts it asking security code.i forget my code please help....
May 05, 2008 | Nokia 1100
IBM ServeRAID-7k Controller (71p8642) SCSI Controller Logo
73 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
