Question about IBM Infoprint 1352 Laser Printer
Hello h?seyin durna lexmark c510 931 service printhead error ?
  • Anonymous Apr 24, 2009
    printing solid full black pages
  • 412 Answers
Printhead error - No first sync
Posted on Mar 09, 2009
Lexmark 650n printhead Service Error 935.26
110% faulty Printhead. Part required is PN: 40x4463
Easy repair, both side panels and top cover removal then just unbolt the Printhead and replace.
Dec 02, 2012 | Lexmark Office Equipment & Supplies
HORIZONTAL LINES ACROSS T644 PRINTER AND 930.00 ERROR CODE
The error code 930.00 indicates a problem in the laser print head section of the printer. This will cause error in the printouts like you are having. This type of problem is not user serviceable and will require an authorized service dealer to obtain and install the printhead assembly. This is directly from page 2-24 of the service manual.
Jul 24, 2012 | Lexmark T644 Laser Printer
935 Service Printhead error
Error 935
Printhead Error - Mirror motor unable to reach operation speed Check cables, look for chafing or damage to ribbon cable at sharp bends around rear cover. Replace printhead or ribbon cable.
May 27, 2011 | Lexmark E350d Laser Printer
I have an error on my Lexmark T632 printer saying 933 service printhead error, can you tell me what this means
Printhead error message indicates that the printhead (laser scanner) unit inside the printer is not working correctly.
First step trying to fix this is to turn printer off, and back on after 10 seconds. If this won't clear it, try and plug the printer in a different power point straight into the wall. If the error does not clear, the printer will probably require service to correct the issue.
Sep 28, 2010 | Lexmark Optra T610 Laser Printer
It will not print and is reading 935.15 Service Printhead Error what do i need to do to fix this?
Here's an article in the Lexmark website on A Printhead Error Is Appearing on a Lexmark E250d(n), E350d, E352dn, or E450dn Printer. Just click on this link: http://bit.ly/9GQzbO. If all else fails, it may require service. I would also suggest you replace the power supply.
Jun 20, 2010 | Lexmark E450dn Laser Printer
JUST INSTALL MY NEW PRINTER, LEXMARK C540 SERIES, I KEEP GETTING A ERROR MESSAGE THAT READS 100.08 SERVICE PRINTHEAD ERROR. WHAT DOES THIS MEAN PLEASE? I HAVE INSTALLED AND UNINSTALLED TO REINSTALL. THE...
Most of the time the problem can be resolved by reseating the printhead cable which can be accessed by opening the back cover of the printer. If that won't resolve the problem, I recommend to have it serviced. It's a possible defective printhead.
Apr 29, 2010 | Lexmark C543dn 26B0000 Workgroup Up to 21...
935 service printhead error
Hello. Unfortunately, if that's the case, there's not much you can do about it but have it serviced. Hope I can assist you more with it.
Apr 06, 2010 | Lexmark Lemark E352DN Laser Printer
What is 931 service error
Hello my friend,this is printhead error,check connections at both ends of cable for corosion or oxidation,reconnect them.Also can be system board error.You can check the operation of
the printhead shutter and clean the printhead window with a lint-freecloth folded over a cotton swab; do not use a bare swab and do not use any cleaning fluids or water on the printhead window if you see the defect on the photo conductor.Good luck:)
Feb 03, 2010 | Lexmark T642 Laser Printer
I have a Lexmark E450dn displaying a "935.15 Service Printhead" error message and will not print. Seeing as Laser Printers do not have printheads, instead they have Scanners and Fusers, which should I be...
a 935 printhead error is a fatal error which means the scanner motor has failed to initialize. the term printhead is short for printhead scanner. this error can be caused by either the engine board or the scanner % wise 40%engine board 60% scanner ive done 120 repairs on lexmark laser for the last 7 years trust me one of these is the problem
Jun 16, 2009 | Lexmark E450dn Laser Printer
931.01 Printhead Service Error
there is a Printhead error - No first sync
Dec 21, 2008 | Lexmark X342n All-In-One Laser Printer
IBM Infoprint 1352 Laser Printer Logo
359 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
