Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Konica Minolta Bizhub C350. Precut 4x6 full bleed postcards.
I don't see a selection to print 4x6 in the drop down menu under paper size in the print screen software output. I see A5/ A6 etc.in mm. I can change the input to 4x6 & 4x6 postcards or custom sizes & not select output at all b/c if I do it just doesn't print. I can print it but I have a 1/4" or so white border. I can't get a full bleed borderless print. Does this mean it won't do it? I would think that if it wasn't able to take & print on the 4x6 at all then it might not be capable but it will I just can't figure out the borderless full color part. Is there a fix? What is the best way to print 4x6 I can only print up to 11x17 on a 12x18 and if I do 8 1/2x 11 it still is not giving me 4x6 full color. The best I thought was to have 4x6s cut before printing = 9 out of a 12x18 size. Please help & thanks for your time.
    Champion:
  • 214 Answers
Hello
Yes, there is no 4x6 choice, you have to input costume size.
For the bord-less part, i first would recommend to use a little bigger costume size so if paper with is 20 mm and there is a boarder about 1-3 mm then input costume size 23 mm. Caution, this can cause a paper jam, because there is a solenoids, what read paper. or you can use a bigger paper and later cut off the boards. Because this printer is not capable printing board-less photos
Posted on Jan 22, 2009
  • 167 Answers
You cannot print borderless on the C350.
The only way is as you suspected.
Print it on oversized paper and cut afterwards, this is how it is done in printshops.
You could impose them multiples up and cut aftwards for optimum cost savings.
Running a 4x6 will damage the fuser unit over time and you will need a Service tech to come by and replace it.
Posted on Feb 17, 2009
Where do I load paper in a Kyocera FS-C5350DN Full-Color Laser Printer
At the bottom of the printer you will find the paper cassette. Pull the handle and the cassette will slide out. Eventualy you will need to ajust the size of the paper.
Jun 23, 2014 | Kyocera FS-2000D Laser Printer
How can I print full bleed on konica Minolta C451
Hi, unfortunatley you cannot print full bleed on any printer that uses toner. The way to do it is to print them on A4 Wide or A3 Wide paper and them trim them like you mentioned.
Sep 13, 2012 | Konica Minolta Bizhub C451...
How do I print postcards on HP PSC 950
Hello!
Here is your solution to print postcards size.. 1. Select your image and press mouse right . 2. Select print and select your printer. 3. There may be many sizes indicate there... but you must select 4x6 or 5x7 as it is postcard size. 4. Now select your paper quality (eg. Photo paper plus glossy ) 5. Press print.... That is it .... good luck
Sep 08, 2011 | HP PSC 950 All-In-One InkJet Printer
How do you clear error code on a bizhub C350. A piece of paper was fused on the fuser unit and we were able to get the paper off. Now we have no access because the panel is locked.
while powering up machine hold down utility/counter key until trouble reset appears on screen. select it and ok should apper under it. power down machine for atleast 10 sec and turn machine back on.
Jul 22, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
How do i go about printing different size of photos? they are all different sizes.
There are two basic ways to change the print size of your photos/documents.
1. You can go to file/print or you can press cntrl + p on your keyboard. the print menu will come up. go to properties/features. when it opens, look for resizing options. Under resizing options you will see print at actual size and scale to paper size. Select scale to paper size and list box will activated. Select the paper size to scale to from the list. If you are not familiar with paper sizes then this list introduction should do. The conventional official paper size is A4, half of that is A5, and half of that is A6.
2. other procedure is to right click on the photo/image and select print. a print wizard will pop up. it will ask you to chose size of images.
Good luck,
Ryan
Jun 11, 2011 | HP Deskjet D4160 InkJet Photo Printer
Hi can a Matching paper size is not available cause a printer konica bizhub c350 to be offline?
If your copier is connected to your network and you get this error, the answer is no. If you are getting the miss match error then the print job could be stuck in the que. This would cause it not to print. If you dont know how to clear the print job, restart your computer and try to print again using the correct paper size.
Mar 08, 2011 | Konica Minolta DiALTA Di183F Copier
Can I print envelopes on my Bizhub 250
BYPASS TRAY is sed when printing onto paper with a size not loaded into a paper tray or onto thick paper, overhead projector transparencies, postcards, envelopes or label sheets Can be loaded with up to 150 sheets of plain paper, 50 overhead projector transparencies, postcards, label sheets or sheets of thick paper, or 10 envelopes referred to as the "bypass tray" throughout the manual. (See page 2-60....ATTACHED )
ftp://207.18.56.26/software/BPG/Userbizhub200250350CopyOperPh2_5.pdf
Feb 15, 2011 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Bizhub C350, need to setup ip address
Utility / Administrator settings (pass:12345678) / Network settings / TCP/IP settings. Select auto IP, or enter it manually. You can check IP address by printing Configuration Page: Utility / User Settings / Printer setting / Print Report / Configuration Page. Press start.
Dec 09, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
1,606 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
