Question about E-Machines Computers & Internet
Unable to access my computer
I took the cover off to vacum the dust out of it and then hooked everything back up and it was kind of fuzzy so i restarted it a few times the same thing happened so I opened it back up and made sure nothing was loose plugged it back up and it does the windows startup, shows bios and then goes to the screen were you can start it in safe mode, normally ect it will not let me choose it times out goes back and does the same thing as listed above (cannot get past that step)
  • 115 Answers
Your cpu might be loose your heat paste may be removed
Posted on Jan 22, 2009
I have a Samsung SU3364 vacum cleaner have never been able to use the crevice tools as there is no suction when you take pipe off, only when you use it as a floor vac, any suggestions have tried every
If the vacuum is old, the intake path from the hose to the dirt receptacle may be plugged from years of dust, dirt and grime. This happened to one of our vacuums, and I had to take off the bottom guard, the belt and the sweeper bar to access the intake, and it took me about an hour to get it unplugged.
If this is a new machine, the hose may not be properly connected when you are using the crevice device. Check the manual for proper installation.
Jul 22, 2014 | Samsung 5490M Lightweight Upright Vacuum...
Can hear air coming out but not cold enough , took all food out of freezer, vacumed back area (lots of dust)
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 19, 2009 | Refrigerators
The router is running fine all hook ups are fine changed the wireless card took that to a computer place and it was running fine at the shop when I got the pc home unable to access the internet even though...
The cable internet is not "seeing" the computer. The router is blocking it. That is why it works if you plug it into the modem directly. How to solve this is to turn everything off and unplug power to modems and routers for 3-5 minutes. Then replug in routers. Then restart computers.
That is why it worked at the computer store. Everything was shut down and restarted.
Also, sometimes it is necessary to call the ISP (for example Comcast) and have them re-send the signal. Also going to Control Panel Network Connections and choose "repair the connection" will reset the signal.
Be patient it will work.
Aug 15, 2009 | NetGear RangeMax WPN824 Wireless Router...
My acer AL1912 monitor keeps going fuzzy. It kind
An unusual problem for a flat screen monitor.
I suggest you connect the monitor to another PC to see if the problem persists since it could also be caused by the video card (or circuit, if on board).
Check your cables making sure they are solidly connected and wiggle them to see if you can cause the problem to come or go away; this would crudely check the shielding of them.
This kind of aberration could easily happen with a conventional CRT monitor if power supply filtering was failing but as mentioned, uncommon in a monitor that is essentially digital.
May 12, 2009 | Acer AL1912 19" LCD Monitor
Lasko heater shut down
The 5840 has a problem with dust getting on the heater element and turning itself off after 2 minutes running. HERE IS THE FIX. Unplug the unit from the AC outlet, Then using a can of dusting air ( the kind you use to clean a computer key board) aim the compressed air INTO the middle louver of the upper adjustable heater vent and blow out the dust that has gotten on the heater element. ( You are actually blowing into the unit, clearing off the lint/dust that has gotten on the backside of the heater element that you can not see without openning the entire case).You can see the front of the heater element inside the louvers, It's the shinny metal part that looks like a small radiator.It sits behind the middle louver. After blowing out the dust, shake the entire unit to allow the dust to settle to the bottom of the case. Using a vacum cleaner try to vacum out any dust from the LOWER FRONT intake. Once the dust has been blown OFF the heater element, the unit will work just as new and not shut itself down!
Feb 15, 2009 | Lasko Ceramic Heater
Lasko heater run about 5 minutes and shut down/how to clean
i have the same problem ... i almost throw this heater out ,,
the fix .. open the unit theres 6 screw at the back.. remove it if you have problem removing the triangle screw use the small square head screw ...size 0 and then you also need to open the black plastic ..
i believe it has 8 screws .. then vaccuum all the dust .. chances are the front and the back of the heating element is covered with dust ..
after that put all back together and i guaranteed it should work like brand new ,,,, dont worry its not that hard ... the only hard thing for me was removing the 2 triangle screws at the back .. Goodluck
Dec 09, 2008 | Lasko Ceramic Heater
Fuzzy
I have posted this response to similar problems.
Your display being fuzzy as you described is indicative of either:
a. weak picture tube; or
b. component failure or deterioration.
Even if it were a weak picture tube or deterioration, it is still possible to "squeeze" a few more usable time out of the monitor. You simply have to adjust the focus control. Normally, this is accessible from the rear of the electronic circuit board and is a part of the Flyback transformer (FBT). Below is an image of a sample FBT. Pls notice the two (2) protrusions, one of them is marked as Screen and the other as the Focus. You need to adjust the focus till it satisfies your visual requirement or preference.
A word of caution. This procedure is not recommended if you have no TV/Monitor repair experience. It is not a fix. It is as earlier stated, squeezing in just a few more usable time. The unit would have to be adjusted "live" with the cover off. You need to be familiar with electronic components, tools and circuitry as well as working with powered devices and extremely High Voltage. The monitor may have to be operated with insulated support since the back cover will not be attached. Additionally, you may need to use a mirror to check if you adjusted it as you want it.
As you try to adjust it with an insulated screwdriver, you will notice that there is mid point where the focus will just be about right. You may have to adjust a couple of times to get the setting as you want it.
Should you feel uncomfortable doing this, perhaps you may need to seek the assistance of a qualified TV/Monitor technician.
Hope this be of some idea/help. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Jun 26, 2008 | NetTV DTV 34X 34 in.CRT Conventional...
Picture bounce or flutter
In case there is a loose connection and the convergence board is not damaged. This is what I did and worked out "perfect".
My Mitsubishi HDTV Medallion 1080 has been with us for about 7 years.
The TV started showing distortioned colors and images and even when I used the convergence options from the main menu, it would not show clear images until it would be working for around an hour or if we would hit it until the image would fix. It got worst over the time at a point that it would require 2-3 hours working and several punches and kicks.
No doubt dust has done it's job, well, a vacum with a brush end can help resolve the problem.
1. Make sure the TV is off and disconnected from power.
2. Remove the rear cover at the back (it is clear wood colored and is at the lower part of the cabinet)
3. Using a vacum with a brush end, vacum all the dust that you will find. Be cautious not to hit the components and do not or apply preassure while doing the work
4. On the left side, you will see a card over a mother board, make sure to vacum it well and that it is well inserted in the slot (I did apply some preassure to make sure it was fully inserted)
It took me around 15 minutes and my tv is working like NEW.
While you are removing the dust with the vacum, you may want to vacum the 3 lenses as well, again, using the vacum, no need to clean them with a cloth. I saw a thick layer of dust over them and could remove it easily with the vacum.
Hope this will work for you.
Al
May 13, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Unable to start my Laptop (Acer Ferrari 3400)
This could indicate power or motherboard failure, you are wise to e-mail the acer technical dept. http://support.acer-euro.com/request/uk/index.html
Jan 05, 2007 | Acer Ferrari 3400 Notebook
Computers & Internet Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
