Question about Canon Pixma MP480 All-In-One InkJet Printer
Mg3170 printer error p2 - Canon Pixma MP480 All-In-One InkJet Printer
Why is it that wireless printing using same hardware and service provider will no longer work at new address and SP account?
When you say :"identical" do you mean the same unit, or another unit of the same model? I experienced the same issue after moving, with a new "identical" model modem/router provided by the ISP. Until the provider replaced the router with another "identical" one I couldn't get the wireless printer (HP in my case) to connect no matter what I did either using the WPS function or entering my network settings manually. Other wireless devices worked okay.
Sep 09, 2014 | Canon MG3170 INKJET COLOR ALL-IN-ONE...
Mg 2270 p2
Hi Andrey,
Did you mean P02?. If yes, means that carriage error occurs on your printer. This error is another format of error code 5100. It describes the same thing that applicable for all Canon inkjet printer model.
I hope the following link would be useful for you. Thanks.
Error Code 5100
Jan 14, 2014 | Canon PIXMA MP240 All-In-One InkJet...
I have failed to reset error 5011 and P2 on my canon mg2100, please help
On my Canon MP 240 the P2 error code was because the belt which drives the cartridge unit had slipped off, so the motor turns but the cartridge unit doesnt move. Just make sure the belt is fitting over the cog correctly. As you look into the printer from the front - the cog is on the left hand side. This took away the P2 error code message on the lcd.
Oct 05, 2013 | Office Equipment & Supplies
Setting up wirless printer
What is the brand/model of the printer you want to set up? Please clarify. I have Canon MG3170 wifi printer and it need USB cable to connect with PC to set up the wireless thru its software (IJ Network Tool).
Please clarify your printer and I will try to help if I can. Good day!!
Mar 12, 2013 | Office Equipment & Supplies
MG3260. trying to set up and keep getting P2 error message. tried turn off both power cord and switch. still the same
not picking up ink cartraiges, is the plastic sticker peice off the ink cartridges? are they lined up right in the printer, do you have enough paper in the machine for it to register.
Feb 09, 2013 | Canon PIXMA Office Equipment & Supplies
Cant set up cannon mg3170 wirelessly
Hi Rachel,
I know this isn't exactly help, but I thought I should say something.
I had a similar canon printer which connected to my wireless network and then after a few days decided that it had had enough of wireless printing. I did everything including a reinstall. I then took it back and got a new one. This strangely did exactly the same thing, so I took it back and got a refund and am now happily wirelesly printing on an Epson printer.
Sorry this isn't a solution,
Darren
Aug 13, 2012 | Canon Office Equipment & Supplies
P2 error, replaced rinse probe, hi limit thermostat, still have an error p2
P2 error is the final rinse probe. Depends on the model of the D/W for location, next to the vac breaker.
Apr 26, 2012 | Hobart AM15T Dishwasher
Two lights blink and p2 flashes. it cant even initialise
Error No. P2 is a problem of Scanner board... kindly change your scanner board... it may help your problem... thanks.
Aug 20, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Canon Pixma MP480 All-In-One InkJet Printer Logo
388 people viewed this question
old marine
old marine
