SOURCE: my cruz tablet 103 won't keep app open, it just reverts to home page. Any suggestions?
You need to update your tablet, or update the programming on your tablet. Apparently all the android 2.2 tabs are considered "legacy" models and don't support the newest google and java script. Since this is what the net primarily uses, those of us with the Cruz are hosed.
I would start by rebooting the device if you haven't already. Also go into your settings, Applications and select All applications if you can. Fin your application you use to download and install apps with, such as the Play store. Clear out the cache. Now try to download again that should fix it.
SOURCE: can not download apps to a 4sight tablet
Check out:
http://slideme.org/
http://www.freewarelovers.com/android
SOURCE: Downloads are not working..store says i have them but they are not on my tablet
Start by going into settings > Apps. Locate your application used to download/install, typically it will be the Play Store. tab on it and clear the cache, then force stop the application. This should clear out any bad data.
