Question about Minolta EP4000/5000 CS/PRO Copier
I have Minolta Copier CSPRO 4000; it has error Code: c0372 please help
  • Minolta Master
  • 6,696 Answers
The bottom paper draw and duplex section have each a plug you plug into the copier in the rear. you mite want to check them for loose connections or the connectors themselves the code is stating that copier can not talk with bottom draws or the duplex section which makes your second side on a single paper. Open close front door to reset and could reset the machine power it off disconnect bottom draws and duplexer then just use the copier that way.
Posted on Feb 08, 2015
Cogz
  • 1326 Answers
SOURCE: Minolta CSPro 3000 Copier/how to enter service mode
Press Stop - 0 - 0 - 1 or it maybe User Funciation then meter count - Stop - 0 - 0 -1 , it's been years since I worked on them
Posted on Feb 07, 2009
goalie39
  • 469 Answers
SOURCE: code C0070 durning the working time
Have you replaced the toner lately? I beleiv it is a toner motor fail to turn, check the toner bottle, remove it and reinstall the bottle.
Close up the machine and try it again.
Hope this works for you.
Ed
Posted on Apr 27, 2009
goalie39
  • 469 Answers
SOURCE: Giving code of "C004A". What does that mean?
A C004a code is a error code with a fan in the copier. It is either not working or is making a noise. You may be able to hear the affected fan and try to lubracate it. There is a Trouble reset botton behind the cover of the display contrast knob. Its on the inside front cover above the fixing unit. Try to rest the code there first. Good Luck
Posted on May 05, 2009
  • 1297 Answers
SOURCE: minolta cspro 2010 error code c05
pLEASE DESCRIBE YOUR PROBLEM CORRECTLY.tHE 05 CODE REFER TO FUSING UNIT.Check or change the fuser unit components,clean the thermofuse and thermistors.
Posted on May 22, 2010
  • 1297 Answers
SOURCE: minolta CSPro copier is not printing
Change the transfer/separator corona holders,corona wires and clean the optics(mirrors,lens exposure lamp),and make a copies.
Posted on Jun 05, 2010
How to remove 601 code photo copier Minolta CSPRO 4000
Scanner fault,open the front door upper left should see access cover, open press trouble reset if the code comes back replace
Parts that may need to be replaced
Scanner Motor M4
Power Supply Unit PU 1
 SCP Board PWB-F
 Master Board PWB-A
If you can find these parts you have a legacy Minolta analog copier not even digital
try this as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jan 08, 2016 | Minolta Office Equipment & Supplies
How do clear a m4 code on a minolta cspro 4000
please open the back side cover press the motherboard reset button .
Jun 12, 2014 | Minolta EP4000/5000 CS/PRO Copier
Have a MINOLTA CSPRO 4000, erro code C0040----"FAN
The fan is not easy to replace...... The fan is located under the black transport belts. The fan is part
of the unit that brings the paper from the transfer & drum to the fuser unit. The unit is black and it looks like tank tracks. From what I remember the fan is acturely in the transport unit ... Good Luck
Apr 27, 2011 | Minolta EP4000/5000 CS/PRO Copier
Minolta CSPro 4000 with error code C:C0040
Fan motor, open close front door, to reset.
Oct 28, 2010 | Minolta EP4000/5000 CS/PRO Copier
Minolta cspro 2010 error code c05
May 12, 2010 | Minolta EP4000/5000 CS/PRO Copier
How do i install my CSPRO 4000 printer to my computer?
The EP4000 is a Minolta analog copier. it has no computer connection.
Jul 02, 2009 | Minolta EP1083 CS/PRO Copier
Minolta EP5000 cspro
Automatic Image Density Control sensor error.Please clean the sensor under OPC drum,press the reset switch after open the front door.Enter into service mode (press STOP-0-STOP-1) select F code history ,open and close the front door,press menu,press reset twice.
Jun 06, 2009 | Minolta EP4000/5000 CS/PRO Copier
Feb 06, 2009 | Minolta Di3010 Copier
Ep2080 minolta cspro
Ep2080 minolta cspro error code comes up with c0500
Dec 06, 2007 | Minolta EP4000/5000 CS/PRO Copier
37 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
