Question about Kitchen Ranges
Need wiring diagram
For a kenmore ceramic top electric range the burners work but the digital clock and everything that controls the oven went out
Posted on Feb 08, 2009
I have a Kenmore electric smooth top range that I cannot use the oven on.
it sounds like the clock assy. cooked or there's a shorted wire somewhere,did the bake element crack or short out?this also can take out the clock assy.if the part is 150 dollars that 's not bad,some of them cost 300 or more.good luck with your oven,also you should have an electrician come in and put the stove on it's own electrical line.
Feb 27, 2013 | Kenmore Kitchen Ranges
We were given an electric smooth top kenmore range. When it was initially plugged in, the digital panel came on. When the stove was pushed into place, the digital clock/timer went off and the oven won't...
The electronic timer/clock must be working and be in manual mode for the oven to work. Try turning the power off and on and see if it resets. If is doesn't you might need a new timer unit. If you don't need the timer and clock it can be easily by-passed at the rear by joining the active and load wires and the oven will work.
Feb 26, 2011 | Kenmore 9535 Electric Range
This range was set for self clean. When i returned home the digital display was not on, the oven was locked, I turned on the top burners to see if they were working, they are. I tried disconnecting power...
their is a thermal fuse between the power and the main clock/timer ......find the wiring diagram ...it will be located in a small brown enevelope ....either on back../or where the range drawer.is ..remove it to look ..under either on right or left...this diagram will tell you the wire color /location on the clock/timer control..let me know an good luck.../joe/
Aug 31, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
Kenmore model number 91193412000 burners went out
Its almost impossible to tell you how to repair it without being there to view what is going on. by what you are saying, it looks like you have a short between two or more wires, possibly stuck together from heat. After switching off, remove cover at the back and follow the wiring to the clock and the burner switches and look for anything obvious. Look for a wire possibly burned off and leaning onto another electrical wire.
Jul 19, 2010 | Kenmore 91112 / 91114 / 91117 Electric...
I have admiral Stove top burner is workni but oven is not working
This may be due to a bad main clock/electronic control but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
Go here for Admiral Stove Parts: http://www.repairclinic.com/Admiral-Range-Stove-Oven-Parts
www.RepairClinic.com
Feb 03, 2009 | Maytag Admiral LER3330AAW / LER3330AAZ /...
Kenmore Range
Try just unplugging the unit for about 5 minutes. That will reset the clock and hopefully fix the problem. If not you probably need to replace the clock.
Nov 15, 2008 | Kenmore 46564 / 46565 / 465 / 6646569...
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work
my frigidaire oven will not light. The broiler works and the oven ingiter lights up, but the oven will not ingite. The electronic display does work.
Aug 25, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven burnout
replace the oven control
Apr 25, 2008 | Kitchen Ranges
Kenmore Electric Range
F1 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Feb 15, 2008 | Kenmore 46564 / 46565 / 465 / 6646569...
Oven display won't work
rmedrano, Try pressing and holding the stop-time and cancel pads together for 5 seconds, see if it comes back to life. If not, try the cancel and clock keypads together for 3 seconds. First is the control lock-out funtion and the second is the display blank mode. If these fail to work, you are going to have to test for power at the board. The clock (ERC) has a 3 year warranty incase you have to call for service. Catriver.post back.
Dec 16, 2006 | Maytag MES5770 Electric Kitchen Range
Kitchen Ranges Logo
174 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
