Question about Canon CanoScan LiDE 500F Flatbed Scanner
Canoscan lide50 does not scan
It shows: error message 2,7,0 - how to fix this problesm
  • spcoyne Feb 13, 2009
    When I try to scan, I get the same error message as the last poster.
    Scholar:
  • 52 Answers
Please follow these steps :-
1- try to scan the image in MS paint.
just open mspaint by the RUN command.
click on FILE and select FROM SCANNER AND CAMERA
then try to scan.
2- Try to restart the scanner service from the services.msc
type services.msc in RUN command.
restart the system.
or
try to restart the system in safe mode then try again to scan the document.
press F8 for safe mode while reboot the system.
3- Try to delete scanner from the DEVMGMT.MSC
just click on scanner in the list and delete that.
it can be in USB list.
restart the system
or
4- Try to uninstall scanner's driver from the DEVMGMT.MSC
just type DEVMGMT.MSC in RUN command
then select the scanner from the USB device and right click on the scanner and try to uninstall driver.
then install driver from the cd or internet.
Posted on May 07, 2009
How to scan using canon scanner f916900
install driver for f916900
later double click on my computer go to scanner device, open it and try to follow the steps to scan
Aug 15, 2009 | Canon CanoScan LIDE50 Flatbed Scanner
I am unable to download driver/software from the canon webside. It keeps giving me an error. I don't know what I am doing wrong. Please help!!!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=8052
Scroll down to the pull down menu that says "Select OS".  Pick the right one and download the driver to the Desktop or a location you can remember.   Extract the files to a location you can remember and run the Setup to install the drivers.  Stop being a noob.
Apr 21, 2009 | Canon CanoScan LiDE 50 Refurbished Scanner
An error message when i try to scan
On the CanoScan Toolbox program bar, select settings. Then hit the Browse button next to "Select Folder where Temporary Files are Saved" and go up one level to Canon from TB50. Then hit OK. This fixed the problem for me after Microsoft Updateinstalled updated Canon drivers. It looks like the geniuses at Canon are either having you write to a write-protect folder or one that only has system permissions and then giving you a disk-full error.
Mar 25, 2009 | Canon CanoScan LiDE 70 Flatbed Scanner
Link Scanned Image - Error Message on Canon CanoScan 500F
"Link Scanned images to..." refers to the programme you want to open the file. Navigate to the .exe of your preferred viewer
Mar 25, 2009 | Canon CanoScan 5000F Flatbed Scanner
Error message
Hi toolpusher
Try going to CanoScan Toolbox > Settings and reset the 'defaults' button at bottom... this will restore factory settings and hopefully fix your problem... The other error message you can expect to get is "unable to scan - insufficent memory, check your **** space' (or something similar)... same fix works for both! ...Have had both messages on mine, sounds like a semi-regular conflict on some sort, but seems to be easily fixed. Good luck :-)
Sep 01, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
Have uninstalled and reinstalled software for CanoScan LiDE60 and still coming up with 2 error messages - "cannot communicate with scanner" and " unable to open TWAIN source". How do I...
Are you scanning from Toolbox? Make sure the correct scanner is selected in the Settings section.
What OS is this? Try scanning from various applications.
Does the scanner react at all at any time?
Make sure you have installed ScanGear and not just Toolbox.
Apr 30, 2008 | Canon CanoScan 4400f MultiFunction Color...
Error message 2-178-0. What does this mean.Changed drivers but no change in message?
Try this:
Open the CanoScan Toolbox.
Click the Save option.
Put a check in the box that states "Display the Scanner Driver".
Click Scan.
Click the Advanced Mode tab.
Make sure Select Source is set to "Platen".
Click the Preview button at the top left.
If the error still occurs, then most likely it will be a service issue.
One thing to check...see if the inside lamp illuminates when you turn the scanner on using the power button at the back left side of the scanner.
Jan 31, 2008 | Canon CanoScan 8400F Flatbed Scanner
Scanning negatives on CanoScan 600F, I get an error message "Cannot write or read. 252.0.0"
The Canon support site is the place to go for that if your Manual does not tell you.
However remove the software and reload it - it may be as simple as that.
Dec 26, 2007 | Canon CanoScan LiDE 600F Flatbed Scanner
Canon CanoScan LiDE 500F Flatbed Scanner Logo
186 people viewed this question
old marine
old marine
