Question about HP OfficeJet 6110 All-In-One InkJet Printer
Printer does not switch on at all
Power pack is fine and power is available on the printed circuit board.
  • Johann Reyneke Jan 14, 2013
    Under normal conditions the printer lights will flash when AC power is switched on. This does not happen now, no lights, no noise, and when the printer is switched on by means of the on/off switch nothing happens, no lights, no noise, no nothing. The full 31 volt output from the power pack appears on the one printed circuit board. Somebody suggested that the voltage may be regulated downward to 5volt somewhere else on the printed circuit board(s) and that this regulator may be faulty. Without circuit diagrams this is difficult to verify.
4 Suggested Answers
SOURCE: Power on switch and orange arrow flashing, will not feed or print.
I had the same problem and found this solution. It worked for me, hope it helps you too.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09315&lc=en&cc=us&lang=en&product=60653&dlc=en
Posted on Aug 25, 2008
  • 327 Answers
SOURCE: Printer des not print
mostly its due to the connection usb cable between printer and the computer .just check out if the cable is fitted perfectly if its perfect and still not printing it can be possible that cable is gone faulty just replace that cable,u can get this usb cable at radio shack websites. thanks.
Posted on Dec 23, 2008
e-Guru
  • 3917 Answers
SOURCE: L7650 printer will not turn
Hi
Try the HP web site under support but it could be an electronic problem that needs fixing.
However check this official website of hp to get support as per their resolution:-
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=bpd05351
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Posted on Sep 04, 2011
My dell aio940 powers down when i turn it on. If I hold ythe power button it will stay on, but when i try to print it will power down
Good day
Hi did you try to open your printer? may be the power on/off button of your printer is loosing try to fix the loosing wire on/off button..
1. open the printer using a flat or philip screw.
2. try to switch on
3. try to find the loosing conection
after you fix the button try to print if the power is down may be ther was a problem in the circuit board..
May 30, 2011 | Office Equipment & Supplies
My HP Photosmart 3210 won't print
Try this:
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "OK".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
Oct 07, 2009 | HP Photosmart 3210 Printer
Printer will not print hp error messsage oxc19a0024 removed all cartridges pupluged as recommended
OKSolution 1:
  1. Turn off power and unplug from power source.
  2. Open right side of printer.
  3. Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
  4. Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
  5. Unplug power source.
  6. Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
  7. Plug in power source and turn printer on.
Solution 2:
  2. Open right side of printer (looking at the front).
  3. Disconect,by pulling gently, the flat ribbon cable off the main circuit board that is the smaller of the two.
  4. Plug in power source and turn printer on. Wait till you hear no more movement from inside from unit booting up.
  5. Press both cancel and power button at the same time.
  6. Message on printer screen will be, "Enter Special Key Combo".
  7. Push keys; Left-Ok-Right.
  8. When printer screen changes, scan through and look for "System Menu" and push "Ok"
  9. Scan agan and look for "Clean Derivative" and push "Ok". Wait for 1 minute.
  10. Scan agan and look for "Clean Firms" and push "Ok". Wait for 1 minute.
  11. Press "Cancel" 4 times
  12. Turn off power and unplug from power source. Wait for 2 minutes.
  13. Reconect the flat ribbon cable by aligning and carefully pushing into the conector on the main circuit board.
  14. Plug in power source,and turn on power.
  15. When printer boots up, answer the questions on the printer screen for your area.
  16. The printer will cycle the ink from the cartridges to the print head and back.
Pineworks
Oct 01, 2009 | HP Photosmart C5180 All-In-One InkJet...
Error0xc19a0024 on a hp 6180 will not print
Follow the below 2 solutions :-
I
  6. Reconnect the flat ribbon cables by aligning and carefully pushing into the connectors on the main circuit board.
II
  9. Scan again and look for "Clean Derivative" and push "Ok". Wait for 1 minute.
  10. Scan again and look for "Clean Firms" and push "Ok". Wait for 1 minute.
  13. Reconnect the flat ribbon cable by aligning and carefully pushing into the connector on the main circuit board.
If problem persists, let me know.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 07, 2009 | HP Office Equipment & Supplies
HP C5180 error messsage Oxc19a0024 will not print. what to do.
Ok this is a old postint but you may come back to see it or it may be handy for some one elles.
Solution 1:
Solution 2:
  17. All the best: Pineworks
Jun 18, 2009 | HP Photosmart C5180 All-In-One InkJet...
Can't set HP 2200 Inkjet to print online
The printer gets it's power from a power pack which was plugged into a power board which was successfully powering the computer and other peripherals.
By chance I discovered the outlet on the board was not powering the printer.By changing the plug from the printer's power pack to another power outlet the printer came online--- Problem rectified.
Thank you for being available if needed.
Billy B.
Dec 30, 2008 | HP Office Equipment & Supplies
HP OfficeJet 6110 All-In-One InkJet Printer Logo
23 people viewed this question
Seeker5211
Seeker5211
