Question about Seagate FreeAgent Pro Desktop - 320GB - 7200rpm - 480Mbps USB 2.0, 300Mbps External SATA ... Hard Drive
Malfunction seagate drive 250 working fine until comp said it did not recognize attached usb device because it malfunctioned, is there anyway of saving it or retrieving the data on it?
  • loopdoc Jan 21, 2009
    Cheers will try and post result
    Genius:
  • 1,269 Answers
You can try to take it out from the enclosure and plug the hard drive directly to your motherboard for you to retrieve the date. Or just buy a different drive enclosure.
Posted on Jan 21, 2009
Seagate usb hard disk not detected and not accessible (error performing inpage operation) what this is error sulation
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
or you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap if this solution does not work and you might need one
hope this helps you
Jul 30, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Windows xp will not recognise the seagate freeagent desktop drive
Assuming you have tried other usb ports and had no change,remove the usb connection, then go back into device manager and select the usb controller, right click and select delete as this will erase any input driver the usb port recognises. Restart the pc and then the controller should be reinstalled automatically as it sounds as though the controller has become corrupt for some reason. Go back into device manager and check there are no exclamation marks, reconnect the drive and see if it's recognised.
Oct 05, 2007 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
External hard drive has spontaneously stopped working. Makes a faint beeping sound but no lights on
the beeps are post during post the very first work is done by the ram all the memory in the ram is first transferred to the hard disk and remains active until turned off.
make sure that your RAM is securely seated,
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
when you plugged the external disk drive you got that windows could recognize the USB device change the cable just replace the cable of the hard disk everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps
May 03, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
When I plug my seagate free agent go portable hard drive (250 gig) into my usb, it register's that there is a device pluged into the computer (give's me the DING, that window's is famous for) but say's it...
try a different usb drive. if you are using win 7 or vista uninstall that device driver you downloaded. if its xp re install your usb drivers from the windows site just go to your device manager
win 7 vista click on computer sys prop device manager see if drive is connected hit update driver or roll back. same with usb system on win xp right click my comp. go to prop, then device manager let me know if this helps. but really important to make sure that you are plugged into a usb port in the back of the pc not thru a hub
Mar 16, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Computer (windows XP)not recognizing external usb device (seagate FreeAgent go 250 GB)
i had a few problems myself and i figured out that the plug was busted inside so i got a new 1 and it works :)
Aug 12, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
USB Device Not Recognized...
try to the laptop firewire port, if works. I didnt find any support for youfirelite drive
Dec 29, 2009 | SmartDisk FireLite 40 GB Hard Drive
Computer Doesn't See Freeagent Go 250 external drive
Uninstall all usb controllers from device manager and then restart your computer. Scan ur system with mcafee 8.5i
Jan 29, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Urgent : 2.5" Seagate External HardDisk USB2.0 Problem
hi there have you tried to boot to bios and selecting the device from there and save and reboot and see what happnes
Dec 29, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
USB External storage device not working properly
please update the USB Drivers and if that Doesnot Work then Update the BIOS of you Computer from the Manufacturers Web site
Nov 01, 2008 | Dell Computers & Internet
Seagate external hard drive problem
Hello, Did you try to use this drive on another computer? Did you have the same problem? Did you try using a different cable? I would try these things first in order to determine if the problem is with the drive or with the computer. Good Luck! Dr. Know
Dec 23, 2007 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Seagate FreeAgent Pro Desktop - 320GB - 7200rpm - 480Mbps USB 2.0, 300Mbps External SATA ... Hard Drive Logo
387 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
