Question about Reddy Heater-30-55,000 BTU Variable
R 150 B wont stay running
I have a R 150 B that was working fine had been putting 5 gals of fuel at a time, took it to gas station and filled it up now it runs for maybe 30 sec then shuts off, tried cleaning filter, checked plug..any ideas?
  • 92 Answers
Most common problem is the CAD flame sensor, two wires in a round rubber boot about 2 inches long facing the combustion chamber. You can get one from Mr.heater for 3 bucks and even though the wires are a different color you can just splice the to your old wires and it will work fine, just did the same thing with mine and it's perfect now.
Posted on Jan 23, 2009
Fuel problem. first time out ran for an hr now it wont start. have spark will run if i put gas down cylinders. fuel line and rail not plugged.
Fuel pump dead or dying. Injection systems need 110 psi, and a pump only doing 30psi will still not run .
Jan 02, 2016 | Cars & Trucks
2010 F 150 oil light warning and wont accelorate
get you a gallon of marval mystry oil drain your oil and filter put a little mystry oil in your old filter rinse it out put back on and oil plug too fill with mystry oil crank truck let it run for 3 min let cool of drain put in new filter and oil if problem still accelorate and oil light still stays on you might have problems with oil pump if oil light goes out and still problems accelorating try changing fuel filter if this doesn't do the job also crack you truck up (if it is carberated carb) take air fiter off carb intake pour a little mystry oil in carb very slowly while running this helps to clean deposites due this for about little at a time you will hear motor sound like choking stop let motor catch up do this for about 3-5 min then pour mysry oil in till motor dies let set for 3 min start motor them put gas treatment (STP) in gas tank this should do the job if you have furl injestion put one cup of mystry oil in gas tank and one bottle of (STP) and atleat 6-10 gal of gas. if this doesn't do the job you may need to tale the truck to a spec.
May 27, 2014 | 2001 Ford Focus
I have a 2004 kia optima with 52000 miles on it. After every fill up at the gas station no matter if I put 5 dollars or 20 to fill the tank up the car won't start unless I put my foot to the gas pedal and...
Two things come to mind. You broke the pressure seal to the fuel system when you took off the gas cap. The fresh gas rushing in disturbs any dirt or debris on the bottom of the tank.
Next time you use the car when you arrive at our destination, simulate what you do when you fuel up. This will mimic everythig except the new fuel rushing in. If it is still hard to start you know it's something to do with the evaporative fuel system. If not, you need the fuel tank inspected .
Feb 06, 2010 | 2004 Kia Optima
How big is my gas tank on my 1989 dodge 150 full size truck
Should be 30 U.S. gal (25 imp gal; 110 L)as you have the higher end model. The lower end models have 22 U.S. gal (18 imp gal; 83 L)
Sep 09, 2009 | 1989 Dodge Ram D-Series Pickups
1999 TAHOE z71 STOP AFTER FUELING GAS
take it to a GM dealer and see if the electronic key reader needs to be replaced
Aug 16, 2008 | 1999 Chevrolet Tahoe
93 dodge intrepid 6cyl 3.3
Your fuel level sending unit is not working properly. The fuel pump and sending unit is one thing in the tank. It isn't too bad of a job to replace, it takes about 2 hours. Buy a manual for you car and it'll have step by step instructions on how to do it.
Jun 10, 2008 | 1993 Dodge Intrepid
Reddy Heater-30-55,000 BTU Variable Logo
132 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
