Question about Microsoft Xbox Console
Dvd will not play
All games work fine. any dvd that i try to play will load to menu. then i am unable to select any action using the dvd remote or the controller. cd's will play automatically and cannot use remote to control actions however, cd's do respond to game controller. what the!!!! help!
  • Keith Johnson Jul 04, 2007
    hey cheebster, since posting this problem i have found out water was spilt onto remote!! I wonder if thats got something to do with it??? gee you think. thanks for help, handy to knoe the I.R. trick.
    Scholar:
  • 39 Answers
Hi there. If i understand correctly, you do have the official microsoft DVD dongle and remote ? If so, you might wanna see if the remote is defective. Do you have a camcorder at home ? There is a trick to see if a remote sends it's infrared signals. Put the camcorder on, in a dark room, and put the IR transmitter on the top of the remote in front of the camera. You'll see the IR remote transmitter blinking if you press some buttons. Human eyes can't see it, but the camera does! Try it with another remote that you're sure that works, you'll see. If the microsoft xbox remote doesn't do anything, check batteries, else it's proably defect. If you like to tinker a bit with things, you might wanna open it up to check if there's any cold solder point on it (a broken connection), but you need soldering skills to do so. Else, you'll need a new remote. Hope that helps ! cheebster.
Posted on Jul 03, 2007
  • Vincent Forcier
    Vincent Forcier Jul 04, 2007
    Hi there ! Well, it seems narrowed down to the remote ! Check batteries and try to clean the board inside of it with alcohol (make sure it's dried out before using after, tho!). Else, you'd need a new one :( Check ebay, clones are dirt cheap ! 10$ or so.
    Thanks, cheebster.
SOURCE:
Purchased the DP300 at the Goodwill. The DVD has the remote control;however, I do not know how to use the remote control. I used the red, yellow, and white connector to my the DVD player and to the TV but...
with regard to using the remote control :
Make sure the batteries in the remote are working (they go in the back of the remote at the bottom).
Turn on the DVD player with the power button on the DP300 itself (lower left). Open the dvd tray either with the remote (press open/close button, upper right) or with the button on the DP300. Put a DVD in the tray and close it with the remote or the button on the DP300. The DVD should load.
Use the arrow buttons in the centre of the remote to select choices from the onscreen menu of the DVD. Press Play (centre of the 4 arrow buttons) to activate the choice you want. For example, if you want to play a movie, use the arrow buttons to go up or down until "play movie" is selected, then hit PLAY, and movie will play. If you want to choose a scene/chapter of the movie, use arrow buttons to go up or down until Scene Selection or Chapter is selected (highlighted), and press PLAY. This should bring up a list of the scenes or chapters. Use the arrow buttons to select the one you want, then hit PLAY, and that scene should play.
If the DVD tray is taking less than 20 seconds to operate, there is likely no problem. If it is taking more, there may be. I think the mechanism that opens and closes the tray is often the first thing to stop working on DVD and CD players.
Jul 20, 2011 | Norcent Technologies DP300 DVD Player
PAL, NTSC
Pls tell us which tv set u have..
Dec 08, 2007 | Mintek DVA-8700 System
Tip
Display problems while playing Virtual Console games
If you are experiencing display issues (dim, blank or half-blank screen, ghosted image, etc.) with a Virtual Console game while using the Component Video Cable, please read the following:
Some Virtual Console games default to displaying 240 lines of video. Some HD TV's are unable to display a signal with only 240 lines. Try the steps below to set the Wii to output 480 lines of video, which may solve the problem:
  1. While on the Wii Channel Menu (main screen of the Wii), connect a Nunchuk to Wii Remote.
  2. Select the Virtual Console game from the Wii menu, then select "Start" to begin the game.
  3. When the game starts, press the Home button on the Wii Remote. (In many games, the music can be heard when the game starts.)
  4. Select "Operations Manual" from the Home menu.
  5. Press the Z + A + 2 Button simultaneously (the Z Button is on the Nunchuk). A sound will be heard if the button combination has been entered correctly.
  6. Close the Home menu. The game should now display correctly. Note: You will not have to do this the next time you play, as the Wii console will remember these settings.
If the Virtual Console game is still not displaying properly, but all other games work fine, please call 1-800-255-3700 so that we may assist you further.
on Mar 04, 2010 | Video Game Consoles & Games
DVD player won't play new movies
Try this
1.While the previews are playing, press the Menu Button on your DVD player remote to access the DVD's Main Menu.
2.Go to Scene Selection and press your Enter or Ok button on your DVD player remote.
3.Highlight Scene 2 and press the Enter or Ok button. This will start the DVD in Scene 2.
4.Use your rewind or reverse button on your DVD player remote to rewind back to the beginning of Scene 1.
Walt Disney Home Entertainment Technical Support
1-800-723-4763, Monday's 9:30-7:30 and Tuesday through Friday 9:30-6:30 CST
Excerpt from email tech support Walt Disney
Dec 07, 2007 | RCA B27TF680 27 in. TV/VCR/DVD Combo
I put in my action replay after it loads then i put in the game i want to play, check the codes i want to use then select play with codes and hit x after it says ensure that the game in in the console and...
Try selecting fewer codes and letting the game boot. Too many codes at once overtaxes the cpu. When this happens, you can get many results, Action Replay freezing, game not loading, or glitched game.
Oct 28, 2010 | Video Game Consoles & Games
REMOTE CONTROL DOES NOT OPERATE DVD
I am having the exact same problem, however I have the official remote that goes with the TV. Have you found a solution to this yet? perhaps its a problem with the TV rather than the remote?
Mar 11, 2010 | Televison & Video
Ps3 won't load games or dvd..WTF?
1.You Should Try to clean your disks 2.put one in and go to games or videos depending on what u r doing and if your ps3 detects there is a game in there press triangle on the disk icon and select play 3.if that didnt work go to http://www.Playstaton.com/Support
Hope it Helped!
Jun 04, 2009 | Sony Playstation 3 (PS3) Console
Ps2 action replay wont work on 60gb ps3
The Playstation (R) 3 has most likely been patched. I find it knocks back not only Action Replay but XPLODER also (The EU version of Gameshark) both for PS2 it is likely that SONY has blocked it out to stop consumers playing region locked dvd movies. So if you in UK you can only play Region 2 PAL dvd's, if you in the us, you can only play Region 1 NTSC dvds. If in AUS, you can only play Region 4 Dvd Disc....etc.... AR Max had a feature to bypass this problem, thus why sony has probably patched against it. As for a solution I am also searching for one, truth be told, I don't think there is one.
You should boot up your codes on your PS2, then the game.
Save your game.
Then copy your save game to your PS3.
Hope this helps.
Feb 06, 2009 | Sony Playstation 3 (PS3) Console
HOW TO PLAY DVD WITHOUT REMOTE
try pressing stop while at the menu. then stop again. then hit play. that works for most dvd players
Sep 28, 2008 | Pioneer HTD-510 System
Me again still same problem dvd discs won't read properly?
You are trying to play dvd's? Then you will need the remote sensor plugged in to the box before it plays movies. IT's called a xbox dvd movie playback kit. Part # x08-25387
Dec 08, 2007 | Microsoft Xbox Console
Microsoft Xbox Console Logo
43 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
