Question about LG LSC26905TT Side by Side Refrigerator
My side by side is not making ice anymore?
I have an LG 710 side by side fridge ( water and ice..).Only had it 5 weeks.
I have noticed that the ice maker has stopped making ice?
How do I get it making ice again.?
Thank-you Tania
  • 410 Answers
Tania, if your unit is only 5 weeks old you should call an LG service co to repair in warranty. you shouldnt have I/M problems this early
Posted on Jan 21, 2009
The water dispenser is not putting out water and ice maker is not making ice. The fridge frequently cycles like it is trying to send out water.
it's still under warranty for up to 1 year,call whoever you bought it from and it should be repaired free of charge and next time you write send model number.
Dec 08, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water on floor
I had this problem with our 2 door frost-free LG fridge (model GR-B207EC). Perhaps you also notice a regular ice buildup in the bottom of the freezer compartment?
My solution was to switch off the fridge and unplug it from the wall, unload the freezer compartment and remove the white plastic back panel inside the freezer compartment. The panel has arrows marked around the edges where the catches are that hold it in place. Carefully flex out the panel at the catches using a large flat blade screwdriver if necessary. Ice buildup can make removal of this panel more difficult.
Behind this back panel is a condenser, under which is a silver tray, which is designed to catch the drops which fall from the condensor (this is the 'frost-free' part of the fridge). I found mine solidly frozen with ice and used a low-heat setting on a heat gun to melt the ice. In the absence of a heat gun a hair dryer will work fine, but don't melt the plastic components of the fridge. (It is also unadvisable to chip away ice with a knife of other sharp implement as you can easily slip and damage yourself or the fridge).
After fully defrosting the tray (this will take some time), including the drain hole in the base of the tray (pour a small amount of warm water in the tray and make sure it drains readily), reassemble the fridge components and restock your fridge. Remember to plug it back in and switch it on.
No more water leaks.
As an alternative to this fix ... if you have the luxury of being able to transfer the contents of your fridge to another fridge and not have to use the leaky one for a while ... empty the fridge and freezer, unplug it from the wall, leave the doors open for a week in a warm location. I didn't use this method but I reckon a week would be long enough to defrost the ice buildup behind the back panel of the freezer and allow the water to drain, yielding the same result.
Feb 28, 2010 | LG Refrigerators
We have a LG LRSC 26923 frig. It will make and dispense ice fine. We cannot get water to come through the dispenser. We had this problem a couple weeks ago and it looked like water had frozen up in the...
i believe there is a water filter in the fridge side as well as a storage tank. if the fridge is set too cold the tank or filter will freeze. causing blockage. Try setting fridge to 38 deg or higher for a couple of days. should melt blockage
Aug 26, 2009 | LG LRSC-26922 Side by Side Refrigerator
Amana SBD21VE No water to ice maker
your water line to the fridge is most likely leaking. You should turn it off right away. The line turn off is either behind the fridge or under sink. sometimes its in basement. The line is very easy to replace. You can get the plastic ones at home centers for under 5 bucks.
Jun 08, 2009 | Amana ASD2326HE Side by Side Refrigerator
Our fridge does not make ice - Whirlpool Gold side-by-side GS5SHAXNT00
Can you lower the ice maker temp on that model.
Thanks J
Jan 05, 2008 | Freezers
Same as others. Whirlpool Gold side-by-side. Water was running yesterday but minimal ice. Now that's gone and I don't even hear the water. Turned on/off the infrared sensor. Still get drinking water, just no ice in the bin. There's a couple cubes in the maker itself when I open the door (which I've closed completely). Help?
Dec 02, 2007 | Refrigerators
Ice doesn't dispense and both freezer and refrigerator aren't cold enough
yes. pull out the frig and look on the back. facing the back on thr right hand side there a rectangle metal plate. under that plate is the main computer board that controls the whole thing. they have been causing alot of problems one of which is the one your having. replace that board and your problem is solved
Nov 26, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Another Ice Maker Problem
i suspect that repair man got it wrong. ice may be blocking return duct to fridge. worth a chance to turn off for 24 hours with doors open then retry
Jun 14, 2007 | LG LSC26905TT Side by Side Refrigerator
Several problems with ice maker
i suspect he real problem is that the freezer is not defrosting. its difficult but take off thge back panel in the freezer and see if there is ice build-up on the pipework behind.if so melt it off with a hair-dryer and check also that the drain is clear. the water you have had on the floor could be due to intermittant defrosting
Mar 14, 2007 | Hotpoint HSS25GFP Side by Side...
LG LSC26905TT Side by Side Refrigerator Logo
438 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
