Question about Zodiac Lm3-24 Salt Water Chlorinator W385210 25k Gallon
I have a Zodiac lm3 24... when the chlorinator changes polarity every 2nd time the no flow light comes on and the output is a solid orange LED. Water is flowing around the cell but the chlorine generation has ceased. When it changes poIarity a 2nd time it works ok, hence it only produces chlorine from one pole. I only replaced the cell 12 months ago so could it be the PCB power board?
  • David Spradling
    David Spradling Sep 03, 2017
    check cord if ok maybe bad cell
4 Suggested Answers
SOURCE: ZODIAC DUOCLEAR 25K DOESN'T FUCTIONING WELL
I have the zodiac duoclear system and have used it for nearly two years. All in all, it's a very good system. I have had similiar issues on occassion. Have you tried the master reset button on the lower right hand face of the control board? I've been able to clear up the lights by resetting the system.
If the salt content in the pool is not correct, the system will not allow you to superchlorinate. Your salt level should be at 4000 ppm. The add salt light is programmed to come on if the system gets below 3600 ppm. When the system is below 4000 ppm, it is unable to generate the chlorine needed. The lower the salt, the less you can chlorinate. Might not be your problem, but I've run into this before too.
The lights for replacing your cartridge puzzle me. I'm making an assumption that your pool is probably dirty if you're trying to superchlorinate. The dirtier the water, the faster the electrode in the cartridge will get covered in scale from the current and conversion process. Try cleaning the new cartridge by placing it in a bucket with a 75% water and 25% muratic acid mix. Let it soak for a few minutes and gently swirl it around in the mixture. This will clean the contacts in the cartridge.
Keys with the Duoclear system: Salt content and clean the filters regularly. Don't know if this will solve your problem or not, but good luck.
Posted on Jan 26, 2009
  • 990 Answers
SOURCE: I have a Zodiac LM Chlorinator, just bought the
If the cell is clean check your flow switch. Take a water sample to your pool store to check your salt leavel again also have them check your stablizer or cynuraic acid it should be between 50-80 ppm to control the chloriene that you produce. If this runs to the top of the scale 99ppm at most Leslies stores have them dilute your sample by half and try again. If that runs to high it will stop the chloriene from working. Also always be sure your filter is clean.
Posted on Jun 27, 2010
thepatioman
  • 52 Answers
SOURCE: Can't adjust the chlorine output level of Zodiac LM3-15
Nost often it just needs to be cleaned. Calcium build up can clean in a tub of 1 Part muratic acid to 5 parts warter. or a 2 to 1 soultion of vinigar and water, otherwise it could be faulty. Cleaning typically works.
The Pool Tech
Posted on Jul 14, 2010
Today I have the no flow light flashing on my Zodiac Tri Clorine generator, when i remove the wire to the flow meter it comes on all the time then put it back on and it flashes I have plenty of flow a
if your positive there's the same or better flow than when it was newer , id say you have a defective flow sensor there
a simple flow test I do using a std pool hose of 1.5 inches in diameter is to hold it at 90degrees to ground resting it on a 1 foot high solid edge and measure out in inches how far the water reaches before hitting ground , this is purely a comparison test , you need to know what it was before there's a problem as several factors influence this simple test , so its results are site specific
Dec 27, 2014 | Zodiac Pool & Spa
Zodiac ei series salt levels are fine cannot increase chlorine indicator light above 20%
need more info is this connected to a system if so you have to change it in the system if not on a system sounds like a bad control board
May 19, 2014 | Zodiac Nature 2 Cra30 Replacement...
Zodiac lm3
The lm series chlorine generator has a tri-sensor inside the cell that measures flow, water temp, and salt level in pool. If the controller is indicating no flow after it has been cleaned properly, then the cell is most likely in need of replacement.
Jan 06, 2014 | Zodiac Lm3-24 Salt Water Chlorinator...
Lm2 unit. No chlorine output. no flow light is on but dim. super chlorinate light is on.
check voltage at cell if high cell might be shorting out or transformer going out
May 20, 2012 | Zodiac Clearwater Lm2-24 Complete Salt...
The Pool Tech
Jul 04, 2010 | Zodiac Nature 2 Cra30 Replacement...
I have a Zodiac LM Chlorinator, just bought the house a month ago. Appeared to be working fine. Pool store said to add salt (although add salt light not on). We did not add any at that time. We had a short...
Jun 25, 2010 | Zodiac Duo Clear System Chlorine...
Zodiac Lm3-24 Salt Water Chlorinator W385210 25k Gallon Logo
97 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
