Question about Refrigerators
Greenway water cooler gwd860w-3 water not working
No hot or cold. no water
  • 263 Answers
SOURCE: Cold water freeze
you have to lower the termostat because is freezing the the cold water duct that happens when is cold or winter
Posted on Jan 01, 2008
SOURCE: water not getting cold
how do you check the compressor?
Posted on Jul 18, 2008
  • 958 Answers
SOURCE: water is hot on both
are you talking about a water cooler dispenser with hot and cold valve?
if you do, the cooling side is not functioning well.
is the compressor running? if not, check the thermostat.
if the compressor tries to start but can not. check the relay of the compressor, it may be bad.
if the relay is ok then the compressor is bad.
another thing to look at is the hot water thermostat. it may no longer functioning as to the cause of the bottle to be extremely hot.
tnx 4 using fixya,
drcool
Posted on Oct 06, 2008
SOURCE: cold water doesn't get cold
Having same issue. Water cooler about a week old, in use in a small office with about 10 people and 2 5-gal water jugs consumed weekly.
The chiller for the cold water no longer works, and they display lights on the front and on/off switch in the back no longer light up. The hot water is working, I'm wondering if there is a potential recall issue with the unit.
Posted on Jul 24, 2009
SOURCE: My Greenway water cooler/heater does not cool the
I have exactly the same problem. Greenway here in Canada don't want to know. Its over a year old so Greenway wont cover it under their warranty. Being 'Fit for Purpose' doesn't come into it.
Posted on Jun 11, 2010
Cold water connection is hot
Did you put hot to hot side? And cold to cold side?
Cold water pipe usually has shut-off valve.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#new
Add comment and say brand and type of water heater for possible follow-up
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 23, 2013 | RELIANCE ELECTRIC WATER HEATER
GE Water Cooler Cold Water does not come out, Why?
It works like a fridge or ac. When its charge gets low it can't cool. It will cycle on and off as freon goes around the circuit. Must be leaking around seals or crack in line. A good ac man could check its pressure to determine. Also, thermostat could be going bad, I would check that as well.
Feb 17, 2013 | GE Profile PXCF22RBS Hot and Cold Water...
Why does cold water mix with the hot when the switch is set on hot
Depending on the age of the unit you may be looking at a faulty switch. Sometimes the contacts for the cold water solonoid on the switch may be fused shut and therefore you will always get cold water no mater what you select. If hot water is what you need the easy way to do this is select hot water and close the tap for the cold water until needed again. Hope this helps
Sep 06, 2012 | Admiral AW22 Top Load Washer
Whirlpool water cooler #whkm-D40 cold push-button broken, does not release water
First, check its button properly. Second, check the circuit board properly.
Chevy Silverado Parts
Aug 27, 2012 | Refrigerators
My Hamilton Beach water cooler is just dripping water on the cold side but running free on the Hot side.Yesterday I flushed the cooler out with vinigar and hot water but today we have a problem
I have same problem keeps running till freeze up so i put a timer on the power cord it shuts off at 11.00 pm till 6am in morning the water keeps pretty cold and a lot cheaper then a new board or scrapping the cooler after starting for about an hour water is cold
Jun 18, 2012 | Hamilton Beach Water Cooler with Storage...
There is a hot water valve & a cold water valve on the Dexter T300 machines but it is a 2 coil valve. does the hot water valve supply only hot water or does one side provide water to perhaps the...
supplies hot water when needed, cold water when needed. and then warm water when needed. so the second coil is for warm water. it basically mixes the hot and cold water.
Mar 17, 2011 | Washing Machines
How does rhe hot and cold water hook up on a 71-40d which is which top and bottom
Tanks are marked with Hot and Cold.
1) If water connections are on top of tank, look for red marking or word HOT that shows where hot water pipe connects. Look for blue marking or word COLD that shows cold water connection.
2) If water connections are on side of tank, cold water connects to bottom one, and hot connects to top.
3) If hot and cold are reversed, the tank will not work.
Pipes on top of tank: cold water enters tank and is sent to bottom of tank in a long tube called the dip tube. This means the cold is on the bottom since hot water rises to the top. The hot water exits top of tank.
Pipes on side of tank: You want cold water to enter bottom, so hot water naturally rises to the top outlet.
Nov 14, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Our washing machine is putting out hot water when the temprature setting is on cold ...and cold water when it is on hot. All rinses are hot. What part could be bad?
The water temperature is incorrect The temperature of the incoming water determines the temperature of the water in your washer. You get either hot, cold, or a mix of the hot and cold water that's currently available to the machine. So if the cold water that enters the machine is very cold--or if the hot water entering the machine is very hot--the warm water is affected. If you live in a Northern climate, unless you adjust the hot and cold water taps that supply water to your washer, the warm water supplied to your washer is usually hotter during the summer months and colder during the winter months.
Jan 03, 2010 | Washing Machines
Refrigerators Logo
151 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
