Question about Garden
Icon 26cc fuel mix ratio - Garden
dunglizard
  • 3 Answers
SOURCE: Fuel mix ratio for 115 hp force outboard engine
50:1 ratio
Posted on May 23, 2009
dontbother10
  • 2220 Answers
SOURCE: pb1000fuel to oil mix ratio for echo
New Echo manuals say "50:1 for all engines regardless of what is printed in manual."
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 2gal premium/8oz chainsaw 2-cycle engine oil - used for many years) and finally the last 5 (±) years 50:1 (1gal premium/2.6oz Stihl 2-cycle engine oil)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few weeks. Anything over 1.5 months old use up in a 4 cycle engine. HTH
Lou
Posted on Nov 09, 2009
  • 17 Answers
SOURCE: FUEL RATIO
For motocross racing..50:1 gas:oil mix. For trail riding and sand pits,..try 40:1.
Posted on Apr 12, 2010
  • 4088 Answers
SOURCE: Fuel Ratio
40:1 is about right. Be sure to use modern synthetic oils made for saws and premix thoroughly before adding to the saw.
Posted on May 04, 2010
heatman101
  • 43501 Answers
SOURCE: oil fuel mix ratio
The manual calls for 32:1 but they will also work well at 40:1
Posted on Feb 04, 2012
Testimonial: "Thank you Mr.Kolb for your answer. I kept telling my buddy to be sure about the oil ratio. I thought that trying 50:1 was risky not knowing for sure. He hasn't tried to do anything yet, now we have someplace to start. Thanks again"
Oil petrol mixture for Rockwell 26cc weedeater
Two cycle engines run on a mixture of gasoline and oil. Each engine type is designed to run on a specific gas-to-oil mix ratio.
IMPORTANT: Use only oil that is labeled for use in "Two-cycle" or "Two-stroke" engines. Home Depot and other stores now have "premixed fuel" of gas and 2 cycle oil.
To mix two-cycle fuel, start by putting correct amount of oil in gas can. Then slowly add correct amount of gasoline. Do not try to mix gas and oil directly in gas tank of equipment.
IMPORTANT: Do not use any fuel that is over 30 days old. Do not mix more fuel than you are likely to use in a month. Old fuel can gum carburetors and prevent starting. Always use fresh fuel.
The chart below shows correct amount of oil per gallon that each mixing ratio requires. Expect that yours will be between 32 gas to1 oil and 50 to 1. 32:1 and 50:1 are most popular.
Ratio GAS:OIL UNITED STATES OIL per 1 U.S. GALLON Gasoline
(128 oz.)
*INTERNATIONAL OIL per 1 IMPERIAL GALLON Gasoline
(160 oz.)
*INTERNATIONAL OIL per 1 LITER Gasoline
(metric)
32:1 4 oz. 5 oz. 31.25 mL 40:1 3.2 oz. 4 oz. 25 mL 50:1 2.6 oz. 3.2 oz. 20 mL
Jan 01, 2015 | Weedeater Garden
Mix ratio mcculloch ct m 32 em
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Sep 17, 2013 | McCulloch 26cc Backpack Blower with Dual...
Starts ok revs ok for a short time then cuts out
The problem your having is your not geting enough fuel into the engine. reconditioned equipment will have some ware on it causing it break down faster.
If your machine manual tells you to use 50:1 ratio use 32:1-40:1 because 50:1 has less oil in it to lubercate engine than 32:-40:1 new/recondition equipment when run older equipment from the 90's 32:1-40:1 fuel ratio will run better and last longer. You may have to adjust mixing screws on carburator for the 32:1-40:1 ratio, but you notice better performance out of your trimmer and it will may start faster.
Oct 05, 2011 | Ryobi Factory-Reconditioned 26cc 22" Gas...
What is fuel/oil mix ratio for ht22 hedge clipper
50 to 1, 20 ml per liter or 2.6 fluid oz per US gallon
Sep 19, 2011 | Homelite Factory Reconditioned 26cc...
Fuel mixture ratio for an eger bevear blower
Check your fuel cap it might be on there molded in the plastic,if not call your local service center and they will be glad to help! One more question how does one own a blower that mixes fuel and one does not know this answer. Confucius says? Anyways Good Luck PAL
Apr 28, 2010 | McCulloch 26cc Gas Blower Mcb3208
Wht is the gas to oil ratio for a homelite vac
Yours is not a current model and I did not find a manual. The following is an excerpt from a 26cc MightyLite Blower/Vac UT08550/UT08951 "Operator's Manual":
This product is powered by a 2-cycle engine and requires pre-mixing gasoline and 2-cycle lubricant. Pre-mix unleaded gasoline and 2-cycle engine lubricant in a clean 1 gallon container approved for gasoline.
Recommended fuel: This engine is certified to operate on unleaded gasoline intended for automotive use.
Mix Homelite Premium Exact Mix lubricant with gasoline according to the instructions on the package. If Premium Exact Mix lubricant is not available, use a high quality synthetic 2-cycle engine lubricant, mixed at 2.6 oz. per gallon (US).
Do not use automotive lubricant or 2-cycle outboard lubricant.
NOTE: Premium Exact Mix fuel mix will stay fresh up to 30 days. DO NOT mix quantities larger than usable in a 30 day period.
PREMIUM EXACT MIX (50:1)
GasolineLubricant
1 gallon (US) 2.6 oz.
1 Liter 20 cc (20 ml)
1 quart fuel:3/4 ounces of oil = 1 Gallon fuel:3 ounces of oil or slightly less than 43:1. Not what a current manual recommends.
If properly adjusted your blower will operate fine on 50:1 regardless of what the manual reads. HTH
Lou
Jan 31, 2010 | Homelite Leaf Vac Attack
McCulloch 32cc blower, what is the fuel mixture, gas/oil
Do a 40:1 ratio to start, if it smokes cut it back alittle but 40:1 should be ok. Better to be alittle high on mix than not enough.
Jan 05, 2009 | McCulloch 26cc Backpack Blower with Dual...
Garden Logo
118 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
