Question about Princeton Digital VL1916 19" LCD Monitor
After a power outage, monitor won't turn on
We plugged in a drill to an outlet and it sparked. The circuit went out and the breaker had to be reset. this was the circuit that had the computer and monitor on it. Once the power was back on, the monitor will not turn on (the computer does turn on). It is a Princeton VL1916. How do I get the monitor to work?
  • 741 Answers
Anytime there is an electrical surge the weakest part is the "Inverter" inside your monitor. It is two pencil size tubes that generates the DC power to the backlight of your monitor. Bring to repair shop and ask to look at the inverters. Once changed it will work fine
Don't forget to rate this solution.
Posted on Jan 22, 2009
The UPS in this office is out of order, message that appear on screen is 'UPS V OUT LIMITS' and 'Battery critical'
follow this steps and fix it. God bless you
Plug the battery backup into a working electrical outlet. If the battery backup turns on when the power button is pressed, then the problem may be that the previous electrical outlet is faulty. Proceed to step three. If the battery backup doesn't turn on, proceed to step two.
  • 2 Reset the circuit breaker on the battery backup. APC battery backups have a labeled circuit breaker button located on the unit near the phone line, fax line, USB, network and coaxial cable inputs. Press the button to reset the circuit breaker. Power on the battery backup by pressing the power button. If the battery backup powers on, proceed to step three. If the battery backup doesn't turn on, proceed to step six.
  • Read more: http://www.ehow.com/how_7266444_troubleshoot-apc-battery-backup.html#ixzz2lwOvPO75
  • 3 Determine if the battery backup is charged and providing battery power. With the battery backup on and plugged into a working electrical outlet, plug a computer monitor into one of the battery backup outlets labeled "battery backup plus surge protection" on the battery backup. (APC power supplies have some outlets that provide only surge protection while the other outlets provide surge protection plus battery backup.) Turn the monitor on. Unplug the battery backup power cord from the wall outlet. If the monitor remains on, the battery is holding a charge, supplying electrical power and the battery backup is working properly. If the monitor goes off, proceed to step four.
  • 4 Charge the battery. Plug the battery backup into an electrical outlet and allow the battery to charge for 16 hours. This will fully charge the battery.
  • 5 Test battery charge. Once the battery is fully charged, repeat step three. If the monitor stays on when power is interrupted to the battery backup, the issue is solved and the problem resulted from an incompletely charged battery. If the monitor turns off when power is interrupted, the battery within the battery backup is faulty and needs to be replaced.
  • 6 Replace the battery backup unit. The unit itself is faulty. If the battery backup is under warranty, contact APC to request a replacement.
  • Nov 28, 2013 | MGE NOVA AVR 1100VA Tower UPS 81111 UPS...
    No power when television is turned on
    1) test the outlet box and plug a desk lamp if work, if does the circuit is o.k if NOT reset the c.breaker from your home
    2) test the power cord for open or break
    3) see for a blown fuse inside and replace, or c.breaker tripped reset.
    4) test for short in transformer+coil+filter+diode+rectifier and ground chassin.
    5) test the Horizontal output for +125vdc +HVREC+FLYBACK+vertical output for 80vdc+all they go to the CRT. measure the color circuite +12vdc+other circuite+12vdc+audio 24vdc. see the block diagram oTHERWISE you must to the repair shop TV
    God bless you
    Jul 31, 2012 | Zenith Televison & Video
    I have an Ifit treadmill. I was changing speeds and it turned off and won't restart. It beeps when i turn it on but no lights on console.
    Power issues with ProForm treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
    If the machine is plugged into a working outlet, make sure the safety key is in the keyhole on the console. If the safety key is not plugged into the machine or if it is pulled out during operation, the treadmill will not operate.
    Finally, make sure the circuit breaker located on the frame near the power cord is set to "Reset." The circuit breaker is set to "Reset" if the top of the button is pushed in. When the breaker is tripped, push it back to the "Reset" position and wait five minutes before powering on the treadmill.
    If the ProForm treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
    Increase Engine Horse Power.
    Jun 02, 2012 | Proform Exercise & Fitness
    Hotpoint rvm1625sj01 no power
    Hello
    Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
    Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
    Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
    Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
    Oct 04, 2011 | Hotpoint RVM1625 Microwave Oven
    Pro form 365 won't start
    Dear Sir:
    I will help you, please do the exact step:
    PROBLEM: The power does not turn on
    SOLUTION: a. Make sure that the power cord is plugged into a surge suppressor, and that the surge suppressor is plugged into a properly grounded outlet (see page 10). Use only a single-outlet surge suppressor that meets all of the specifications described on page 10. Important: The treadmill is not compatible with GFCI-equipped outlets. b. After the power cord has been plugged in, make sure that the key is fully inserted into the console. c. Check the reset/off circuit breaker located on the treadmill frame near the power cord. If the switch protrudes as shown, the circuit breaker has tripped. To reset the circuit breaker, wait for five minutes and then press the switch back in.
    Finally: check, the breaker from the home, if there tripped, check this, and Reset.
    I will recomend when you finally set up, install Stabilizer Voltage, is cheaper us$15,00 aprox
    Thank you in advance, sincerely.
    Blessing, if you need additional help, please contact me.
    E.CUADRA MANAGUA, NICARAGUA.
    Sep 26, 2011 | Proform Crosswalk 365 Console Treadmill
    Machine not turning on
    1. Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
    2. Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
    3. Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
    4. Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
    Hope i could help you.
    Have a nice day : )
    Sep 04, 2011 | Microwave Ovens
    I have three upstairs bedrooms that are all on the same circuit. My sister tried to plug in something to an outlet in her bedroom and it seems that she jiggled the plug into the outlet and the power went...
    I know this may have already been checked, but make sure that any gfci may have not tripped, and also, reset all the breakers if the gfci thing doesn't work... Trust me i know it is annoying but resetting all of the breakers almost always fixes the problem.
    Aug 02, 2011 | Electrical Supplies
    My fridgedaire window unit A/C and heat won't come on. I had replaced an outside light fixture a couple of weeks ago and had turned off the circuit breaker that affected this unit too. Now the unit...
    Plug a light into the outlet used for the A/C, if the light does not come on when reset then the circuit breaker that provided the power to the outlet need to be reset or replaced.
    May 22, 2011 | Frigidaire FAS257S2A WallWindow Air...
    Demudifier worked great, all a sudden it just stopped. No power. Now it won't start up. What should I try?
    First, check the outlet that it's plugged into, to make sure that there's still power to the outlet. If there isn't, then the circuit breaker for that outlet has been tripped, in your home's circuit breaker panel. Leave the dehumidifier unplugged and reset the circuit breaker. If it trips again, without the dehumidifier unplugged, then the outlet is at fault. Perhaps there's a loose wire connection or the interior of the outlet is cracked.
    If it didn't trip without the dehumidifier plugged in, plug the unit it in,. But, before you do, make sure the dehumidifier's Master ON/OFF Switch is OFF. Once it's plugged in, turn the Master ON/OFF Switch to ON and set your controls. If it runs now, GREAT! If it trips the circuit breaker again, there's either a short in the power cord or an internal electrical short. Which will require extensive troubleshooting to find.
    Hope this helps you solve the problem. Please let me know. Thanks.
    May 05, 2011 | Fedders A7DH45B2A Dehumidifier
    The power won't turn on, how can i fix that?
    The possible causes for this unusual behavior may be if 1) electrical power cord may not be plugged in or connection or may be loose. To make sure this is not the problem see that the plug fits tightly in wall outlet.
    2) House fuse is blown, circuit breaker tripped, or a power outage has occurred. Reset circuit breaker or replace fuse. Do not increase fuse capacity. If problem is a circuit overload, have it corrected by a qualified electrician.
    3)Water supply tap is not turned on. Turn on water supply tap.
    If all the above methods doesn't work, please call at 1-877-714-7486 to locate your nearest LG service center.
    Feb 05, 2011 | LG WM-2277HW Front Load Washer
    Princeton Digital VL1916 19" LCD Monitor Logo
    1,608 people viewed this question
    Top Princeton Digital Computers & Internet Experts
    Josh Whitehead
    Josh Whitehead
    William Ward
    Level 1 Expert
    Sunday Ojelabi
    Sunday Ojelabi
    Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
