Question about GE GSS25JF Side by Side Refrigerator
TFX28PPCBWW leaking I have a GE Refrigerator M/N TFX28PPCBWW where the water line to the ice machine broke just past the flow solenoid. How much water (oz) is sent to the ice tray and how often does the water turn on when no water is sensed in the tray?
  • 410 Answers
The i/m holds between 3-5 ozs and will try to fill approx. every 10-15 mins with no water in it..
Posted on Jan 21, 2009
Water will not flow into ice maker
Not typical for both sides of your=> WR57X10032 Dual Water Control Valve
but this is possible. You will need to do some testing of the control valve found at the link above or HERE If there is no problem with the part then you will need to turn water off and disconnect water line feeding the refrigerator. Place the water line into a bucket and have someone turn water back on so you can see if there is something blocking or restricting flow to your refrigerator. I will be here to answer any questions you may have, Thanks Sea Breeze
Here is a manual=> GE Refrigerator Technical Service Manual
Let me know if you would like my assistance, Thanks Sea Breeze
Nov 05, 2012 | GE Profile Arctica Stainless Steel Top...
No Ice. Replaced 4 solenoid water inlet valves. Icemaker spins around, but no water comes up. Any ideas?? Bruce
Follow the water source line on the back of the refrigerator to the shutoffvalve on the water supply. Turn the shutoff valve counterclockwise to open itfully. Inspect the water source line for kinks. Straighten the line to removekinks.Confirm water flows to solenoid one end. And also check freezer door is closed as it will sense solenoid to open to water flow into ice maker. Sometimes, water flow might be plugged by frosting. Check freezer setting temp 5 degree. Thanks.
Jan 29, 2011 | GE Profile PDS22MHR Bottom Freezer...
Ice maker not making ice water dispenser works well
There are 2 solenoids, one controls the water dispenser the other controls the ice maker water supply. Follow the tubing down the back of the refrigerator to find the ice maker solenoid. If the line is frozen between the back of the refrigerator and the ice maker it won't make ice either. If the line is frozen you need to check to see if the solenoid is leaking, this allows a trickle of water to continously flow through the lina and freeze.
Jan 08, 2011 | Refrigerators
I've got a GE side by side refrigerator that's approx.7 years old. This past weekend, I resolved the problem of not getting water out of the cold water dispenser. After replacing the two-way water solenoid...
Check around the door gasket to see if gasket pulls off or is it held on by screws if there are screws you can separate the door and insulate the tube if no screws than replacing the door is the only repair.
Jan 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
No water entering ice maker.
Replace the solenoid valve , the piece the wall water line connects to , on the refrig . With both ice maker AND valve replaced , that is the complete ice production new .
Jan 01, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Water won't flow to the ice maker but does to the door dispenser
make sure that the solenoid valve that lets water into the ice maker is working. you can also double check that there is no blockage in the supply line and at the solenoid.
Aug 07, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile TPX24...water leaking from under freezer side...water dispenser works fine, but ice maker not working properly. What could be the problem...and how do I fix it?! Thanks
i had the same issue twice. 2 suggestions 1) Remove the front grill at the bottom and you will see a plastic water line. Inspect it to see if it is leaking. Turn on the water dispenser when you are looking at the line. 2) pull out the refrigerator and remove the lower panel. Follow the plastic water lines to a solenoid valve and inspect the lines when you activate the water dispenser. water may leak from where the lines go into the solenoid value. if may be a simple fix like cutting the ends off the lines and reinserting into the solenoid valve.
Jun 14, 2009 | GE Profile TPX24PBDCC Side by Side...
Ice maker frozen, water leaks from bottom of refrigerator
I am assuming this is a refrigerator that has been in use for some time. The water line coming in is connected to a solenoid valve, this is activated when the icemaker cycling sends a signal for more water. There should be a downward tilt so the water drains from the inlet to prevent freezing of the line. If it is leaking low in the back where the water connects it may be that your solenoid valve is leaking and that you are not getting good water flow to the icemaker. Meaning two things no or very little ice and the possiblility of freezing.
Unless you know what a solenoid valve is and I suggest you call a repair man.
May 03, 2009 | GE Refrigerators
Water leaking from ice maker GE model# TFH22PRS
Hi
Please check to make sure the water tubes are attached properly and are fastened tightly.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please revert for further assistance and Do rate the solution as "FixYa" if found useful.
Thanks
Rylee
Mar 16, 2009 | GE Refrigerators
Ice maker tube freezing up
  • change the water valve on the back of the machine.
  •  the water valve is slowly leaking water up to the icemaker where it freezes and builds up ice, blocking the water flow.
Jun 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE GSS25JF Side by Side Refrigerator Logo
115 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
