Question about General Filters 1042-LH Humidifier
Filter Do I change my filter from the top or bottom of the unit and why does my filter have a blue powdery substance?
    Problem Solver:
  • 5 Answers
The filter panel may be replaced from the top or bottom but it's less hassle to replace from the bottom because the top tray retains a small amount of water and also because you must be mindful of working around the feed tube assembly. Also, when replacing the filter panel, clean both trays (requires removing both trays, water feed tube and drain tube) and drain tube ... use a 8 water -1 bleach diluted solution or other anti-bacterial solution and wipe the trays and pour some into the removed drain tube (not the feed tube!) and shake it up a bit. Be careful though as you do not want bleach solution getting in your eyes, nor on your skin and clothes!
Posted on Jan 23, 2009
Leaking at base due to too high of pressure or defective evaporative filter?
Humidifer FAQ's - General Filters, Inc.
www.generalfilters.com/support/faqs/humidification.html
I already have a GeneralAire® 1042 Humidifier installed, but have a 4,000 square foot home. Should I ... Can't I simply clean my Vapor Pad instead of replacing it? Where do I find ... I am seeing a very slight water leak coming from the bottom of my steamhumidifier. What do I do ... Legacy 1137 = 21 GPD / Up to 3,000 Sq. Ft.
GeneralAire® Legacy 1042 and 1137 Humidifiers - YouTube
? 3:22
https://www.youtube.com/watch?v=IM6IXVcjEdU
Jun 27, 2013 - Uploaded by GeneralAire Inc
GeneralAire® Legacy 1042 and 1137 Humidifiers - How to change the vapor pad .... Evaporator Pad (aka filter) change on aGeneral Aire 1042 ...
[PDF]General Aire Humidifier Owners Manual - On Time Mall
Jan 16, 2016 | GeneralAire Legacy 1040 Humidifier...
There are black chunks of like a stone like substance in the water after use. It is cleaned out every morning. You can shake the core unit and little chunks will fall out of the hole at the bottom of the...
These are just the minerals in the salt and water that are burned off during evaporation. It is normal. I have very hard water here and it leaves quite a mess in there.
Feb 28, 2011 | Vicks V150 Humidifier
We have a white powdery substance on everything around our humidifier. It is also on and in the humidifier. Could there be something in our well water?
You have calcium / lime, this is normal in all hard water. At the end of the season soak all affecred parts in white vinager to disolve the build up.
Jan 12, 2011 | Humidifiers
2 months into the heating season I noticed a large puddle around my heater. the Aprilaire 600 unit was leaking. The distrution tray had a red substance around the water holes. Also the overflow drain line...
Mold can really cause problems with humidifiers-
They do need to be serviced, cleaned up, and something like weak bleach used to kill mold spores, -- get it all tidy and clean!
Were you able to clean out the drain line?-- and is it draining now?
And is the float valve shutting off the water flow, before it reaches the overflow drain pipe?
Another concern would be the soaking pad-- Has it been changed recently?
Tell us more--
Mack B
Jan 06, 2011 | Aprilaire 600 Humidifier
I have two questions. How do I properly clean my humidifier and recently it has started coating my furniture with a white powdery film. Why has it started that?
there is some cleaning tablets you can use periodically called protec beads ... cleaning can be done using high acid vinegar soak .. then hydrogen peroxide can be used on any mold .. this unit as well as ultrasonic type models will put out calcium dust if your water has calcium added or is hard water .. calcium is often added to water to give it a good taste .. one way to keep the unit clean for a long time is to use only distilled water .. and make sure there is no calcium added .. (read the small print on the container) .. its hard to clean the fan chamber in this unit .. lots of people complain about the dust .. the wick/filter type humidifiers dont put out dust but the calcium does accumulate on the wick/filter .. so you have to change that frequently (6-9 weeks) .. yours doesnt have a wick but still needs cleaned regularly ..
Sep 26, 2010 | Vicks V4500 1 Gallon Humidifier
I am getting a white scale or powdry dust throughout the house. What is happening?
You need to replace you humidifier pad. The water scales up on the pad and this is the white powdery substance you are getting.
Feb 02, 2010 | Aprilaire 550 Humidifier
Water is leaking from the bottom of the unit
The tune up kit that I ordered arrived on Friday and I installed most of it on Friday night. While it is nice to have a new frame and the distribution panel and I think the price of the whole kit was fair considering it comes with the parts and 2 water panels, the fix was really simple.
The kit came with the water distribution tube with with a new blue orifice (Aprilaire #4232) already inserted. This orifice is in the end of the plastic tube at the solenoid end. When I removed the old water distribution tube, the old orifice was not really dark blue anymore but kind of a light blue and was deteriorating from 12 years of exposure to the chemicals in the water. What should have been a pin-hole size opening in the orifice was up to about 2mm or a little more so the orifice was letting way too much water through.
If anyone else has this leaking problem, and your orifice is several years old, I would check that first. It is a $2.75 part and may be the cause of the leak. The whole feed tube kit is only $8.75 and includes the feed tube, nozzle, orifice, ferule, compression nut, strainer so if you need to replace the orifice, I would order the whole feed tube kit for a little bit more.
Hope this helps,
Roger...
Jan 17, 2009 | Aprilaire 700 Humidifier
Water leaking out of bottom
A leaking humidifier is a sign that the unit's filter needs to be cleaned/changed. I had the exact same problem on this model.
Jan 05, 2009 | General Filters 1042-LH Humidifier
Cool Mist Humidifier Filter Drying Out
How long are you going between filter changes?
A filter that stops wicking water up and turns orange/yellow is one full of deposits.
It sounds like you have hard water. How are you filtering this water before you use it? Distilled water is the best.
Replace the filter. They don't last forever. Mine normally last a month to a month and a half.
Good Luck
Feb 10, 2008 | Honeywell QuietCare HCM-630 Humidifier
General Filters 1042-LH Humidifier Logo
654 people viewed this question
Top General Filters Humidifiers Experts
Paul Carew
jdthefixer
Steve
Are you a General Filters Humidifier Expert? Answer questions, earn points and help others
