Question about Stainless Garden Sun Steel Propane Patio Heater
Gas is on, there is spark from ingnitor, but the pilot light will
Not light. We hold the dial in as required. The heater is less than one year old but is not used for long periods of time.
  • 15,935 Answers
The unit is equipped with a themocouple that sends a small amout of voltage to the regulator telling it there is a pilot present, and allows it to open.
If the thermocouple is out of position, or dirty/sooty, the voltage will not register as flame present, and the pilot will not stay lit after releasing the button.
Clean or replace the thermocouple to fix your problem. Sometimes fine grit sanpaper will clean it up nicely without replacement.
Thank you for using FiXyA - A FiXyA rating is appreciated
Posted on Jan 21, 2009
I have a Bosch 10P water heater. Pilot light has blown out and while trying to relight the pilot the stop button has been pushed down and won't pop back out. What am i doing wrong? Cheers
What leads you to suspect that pilot blew out instead of another problem?
Fact that pilot will not relight, indicates other factors at play.
Open following link for Bosch troubleshooting resources including manual, and Bosch contact info:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Best place to start is your manual.
http://waterheatertimer.org/pdf/Bosch_10P-installation.pdf
1) Manual recommends 'cleaning by authorized person, never less than once a year.'
Tankless water heaters, and most newer tank-type gas water heaters, are highly technical and finicky devices that require continual maintenance, with tankless requiring 'yearly' maintenance while tank-type require 'periodic' maintenance.
2) Troubleshoot in manual says 'no gas supply' or 'blocked pilot' replace pilot injector
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 21, 2011 | Bosch & Tankless LP Hot Water Heater
Tip
How to light a pilot light on a gas furnace
If your gas furnace is an older type with a standing pilot light, this video is for you.
If your furnace is a newer, more efficient type, it most like has either an Electronic Spark Ignitor or Hot Surface Ignitor that does not allow you to relight.
REMEMBER: If you don't have a CO Detector less than 5 years old in both your main living area and in your bedroom - get them today. CO is colorless, odorless, and deadly.
on Mar 20, 2010 | Heating & Cooling
How do i light the poilt light on a comfortmaker
depending on how old the unit is varies... if you actually have a pilot assembly you will hold down the pilot valve located on the gas valve adn you would turn dial to pilot and push down red button or knob itself the stick a long match in pilot assembly area and lite...once lighted keep holding down for about 15 seconds to get thermocoupler hot adn then rotate dial to on...if it goes out star toperation again and if continues then the copper thermocoupler next to pilot assembly is dirty or bad... if you don't have a pilot assembly and unit is within last 10 years or so you may have a hot surface ignitor in there and it automatically glows on the call for heat and will lite..if your not seeing it its made of porcelein and could have cracked or went out.... some units also have spark ignition and originates from the board and then will go to a spark module ....repost if you have more questions a/c & heat servicer for 18 years...
Jan 08, 2011 | Heating & Cooling
-Pilot Won't Light- My Lite2 LG is 2 years old, but never used. I just hooked up the gas with 3/4" pipe and pressure/flow is good (I don't have a manometer tho). The pilot flame won't light (igniter is...
Open up the union in the gas line and bleed all the air out. Once done the pilot should light in a short amount of time. If it still will not light, remove the pilot and inspect it for spider nests in the head or regulating cap.
John
Sep 21, 2010 | Jandy Laars Lite2 Ld 400,000 Btu Heater
Describe your Problem i have a quasar vulcan gas heater pilot light is on but wont ignite. can hear it clicking trying to ignite what is the o=problem . this heater maybe about 20 years old
What do you mean by the pilot light is on but won't light. Do you mean that there is gasbut won't light. If so the spark may not be hitting the pilot properly or it may not be getting enough gas. If lighting but continuing to spark the sensor may need cleaning. This can be cleaned with steel wool (not sand paper), probably will need to disassemble the pilot asembly The pilot may also be dirty reducing gas flow. If this is the case dis-assembly will be needed and the pilot cleaned.
Sep 05, 2010 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
My 3 year old "Smart Water" heater will not turn on. No hot water
It sounds like there is air in the line, so open the gas line just a little for a few short seconds to let some gas out, after that, keep the one red dial on pilot then turn the other to about medium. Light the pilot by depressing the red button, then once the pilot is lite, continue to hold the red button for about 1 minute, Once that is done slowly release the button and then turn the dial that is set to pilot to on position and give it about 1 hour to heat up
May 08, 2010 | General Electric GE SmartWater Household...
Pilot light wont stay onfor outside pool heater. gas co made a service call & relit the pilot light, it went out again 4 days later.
Thank you for posting your question here on Fixya.com.
Has anyone replaced the pilot generator yet? A millivolt heater (one with a pilot light) requires about .75 volts from the generator to operate. As the generator ages it puts out less and less voltage and eventually gets to weak to even hold the pilot gas valve open. Replacing it with a new generator will usually fix the problem you describe.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Mar 17, 2010 | Pool & Spa
My 1.5 yr old gas water heater has a pilot light problem
YOUR WATER HEATER HAS WHAT IS CALLED A STANDING PILOT-STAYS LIT ALWAYS WHEN THE PILOT GOES OUT YOU LOOSE EVERYTHING. YOU HAVE TO REPLACE THE THERMOCOUPLE WHICH KEEP THE PILOT LIT. ONCE THE PILOT IS LIT THE THERMOCOUPLE SENDS IN MILLIVOLTS TO THE BURNER TO SAY ITS READY FOR BURNING
IF YOU ARE NOT FAMILURE WITH THIS REPLACEMENT PLEASE FIND SOME ONE WHO CAN. IT IS NOT HARD TO DO ASK A NABOR OR FRIENDS SOME HAS TO KNOW HOW. SERVICE COMPANYS ARE OUT FOR THE MONEY FOR A 10 MINUTE JOB
Aug 10, 2009 | Water Heaters
No Hot Water in morning
Remove the cover then the access cover, then you can see inside,
the pilot light is probably out.
If out turn the gas off, then get a long match, grill lighter,or piece of paper ready to light, you should be able to see the little thin
gas line that runs inside the tank and see where it connects to,that is where you need to light, now that you see where to light, turn gas knob to pilot, and press down and at the same time light the pilot.
( blow into the pilot area before putting match inside to make sure no gas has built up inside) Hold down the knob for a minute then release, if pilot goes out try again and hold down longer, if you hold it for 3mins and it does not stay lite, the thermocouple is bad and you will have to replace it.
Apr 14, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Pilot light will not light
you should have to push the dial or a seperate button in to manually open the pilot gas valve. If you find this not to be true and you have a spark either the pilot burner assembly needs to be pulled and cleaned.
Dec 18, 2008 | Heating & Cooling
Stainless Garden Sun  Steel Propane Patio Heater Logo
668 people viewed this question
Top Stainless Pool & Spa Experts
Merv Vickery
Merv Vickery
Gene Haynes
ray gallant
Are you a Stainless Pool and Spa Expert? Answer questions, earn points and help others
