Question about Night Owl Optics Night Owl Scorpion 168500 Network DVR 16 Channels H264 500GB 8 Camera
Dns is wrong
I get a message that reads Update unsuccessfully code 1 or DNS is Wrong
Norstar M7324 DNS Update Code
Never heard of DNS.
Somebody made a programming change from that phone in the system and the system is updating all the phones.
When you press Update it show the ext's being updated, if it is that phone then unplug it for a few seconds should do the trick.
Nov 06, 2012 | NorStar M7324 Telephone
Netflix is not working
Cannot Connect to Netflix" message
  • Make sure your home Internet connection is compatible (more info)
  • Manually change your Wii console's DNS settings. To do this, follow these steps:
    1. Access the Wii system settings (how to), and use the right arrow twice and select "Internet."
    2. Select "Connection Settings," and choose the connection file (1, 2, or 3) that are you are currently using.
    3. Select "Change settings" and click the right arrow 3 times to reach "Auto-Obtain DNS."
    4. Select "No," and choose "Advanced Settings."
    5. Click into the "Primary DNS" field and enter: 008.008.008.008
    6. Click into the "Secondary DNS" field and enter: 008.008.004.004 Please note: These are public DNS's provided by Google and are subject to Google's Terms of Service. If you prefer to not use this service, doing an Internet search for "public DNS" will provide you with several other options you can use.
    7. Select "Confirm," and then "Save."
    8. Select "OK" to start the connection test. Once the test finishes, try to download the update again.
Oct 16, 2011 | Nintendo Wii Console
Wats wrong wit my DNS on my compaq presario CQ60-22OUS Notebook PC
if you are trying to use a custom DNS then you all ready know what you are doing. make sure that the address is right.
  • Google DNS-8.8.8.8
  • 2nd gogole DNS-8.8.4.4
You can all so let your router do the DNS for you.
How to Change DNS
Feb 28, 2011 | Compaq Presario CQ60-220US PC Laptop
Just brought a Sony Bravia HX 800 and added a wireless LAN adapter (UWA-BR100) to get Internet TV. After network set up NOT able to access internet. Message reads Wireless device OK Local Access FAILED...
Hi
I got the Bravia KDL-40EX713 and the uwa-br100 I had massive problems getting it to work with a BT home hub. Eventually I found manual setting that work. Firstly I logged on to the router and went the the advanced settings bit, then I went to the DHCP table that shows all the devices connected. I picked an unused Ip address from the range of existing ones being used (this sort of thing 192.168.1.73)
I then used the following settings for the other fields (I don't think the secondary dns setting is right but it still works)
ip 192.168.1.73
sn mask 255.255.255.0
default gateway 192.168.1.254
primary dns 192.168.1.254
secondary dns 192.168.22.23
If the DNS server ip is wrong then you get local access OK but internet access failed.
Hope this helps.
Ian
Jan 30, 2011 | Apple AirPort Extreme Base Station
When I start my internet service it is connect with full bars but will not bring up a page and then has a little yellow yield sign. Diagnose say " The DNS sever isn't responding". what is wrong?...
Its an issue with the DNS service in the operating system.
For the range problem, u can update your wireless driver and BIOS from the manufacturer website.
Regarding DNS, you can try restarting the service manually.
You can also try system restore from safe mode.
The best way is to reinstall the operating system since if it is an issue with some kind of virus, we can remove that also.
Nov 20, 2010 | Computers & Internet
I can't sign in online I dnt no y but says DNS error
Following on from the PS3 3.50 firmware update today, we have started to hear of owners having problems logging on to their accounts.
We have heard of PS3 owners who have updated their system complaining that they cannot sign in, and every time they enter their password are getting the wrong password message. We have had customers who have two PSN accounts and cannot log into either of them. They are met with wrong password message, and even when they use "Forgot your Password" all that comes up is an error.
Conrad Zimmerman of Destructtoid is reporting that PSN is going to have some scheduled maintenance today. This could be why users are complaining of problems logging on to their accounts.
The maintenance is expected to take place during 8 am until 5pm Pacific time. There will be a lot of users who are at work during this time so it will not be a problem for them, but for everyone else it will be somewhat of an annoyance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&^$@#$
Sep 21, 2010 | Sony Playstation 3 (PS3) Console
Oops this link appears to be broken dns error - cannot find server windows 7 explorer 8
The error refers to the Domain Name Server (DNS) that your system uses is unable to translate the Uniform Resource Locator (URL, web address either Typed in the address line or linked using a hyper-link, favorite or default home page) (In english, the translation of a web address link www.google.com to the Internet Protocol (IP) address that computers actually use to show the page)
Possible causes:
  1. The URL is wrong. (Typed wrong, link no longer active, link changed)
  2. The DNS server listed for your ISP configuration is not working.
  3. The web site is offline.
  4. The DNS server settings for your internet configuration are wrong.
Possible resolutions:
  1. Try a different Web Address, see if it works
  2. Restart (Completely power off your Cable/DSL modem and then do the same with your router)
  3. Check you IP address configuration settings and ensure that auto-assign DNS is selected (Default setting)
  4. Boot to safe mode with networking, see if you can get online that way.
Dec 21, 2009 | Computers & Internet
Wii will not update, comes up with and error code message
Error Code: 32002 The Nintendo Wi-Fi Connection servers could be experiencing a high amount of traffic. Please try your connection again later.
If you have waited several hours and are still unable to connect, there could be an issue with your connection. Please review the folliwing information:
  • Ensure you have entered the correct DNS into the Wii console's manual settings (link). You can verify this by following these steps:
    1. Click the "Start" button in the lower left-hand corner of your computer.
    2. Click "Run."
    3. Type "cmd" into the box and press Enter.
    4. Type "IPCONFIG/ALL" and press Enter.
    5. The Subnet Mask, Default Gateway, Primary DNS (first listed), and Secondary DNS (second listed) information will be displayed. Ensure the information you have entered into the Wii console's Manual Settings appear exactly as displayed.
    6. If you have more than one DNS server listed, try switching the first and second in the Wii's primary and secondary DNS server slots.
  • Try temporarily disabling your router's firewall. *
  • If you are still receiving this error code, please click here for assistance.
    Nintendo Wi-Fi USB Connector
    Wii LAN Adapter
If you have tried the steps above but are still having issues connecting, it's possible that our servers may be temporarily down. Please try your connection again later.
*While Nintendo provides this information for our consumers' use, it is up to each consumer to determine what security needs they have for their own networks, and to decide how best to configure their network settings to meet those needs.
Sep 25, 2009 | Nintendo Wii Console
My ps3 keeps on sayin dns error
if your set to obtain setting automaticly try rebooting your router then go through the network setup again to refresh all the setting.
If you put in the ip address and dns setting in manually then double check the info that was given a good test is to use an alternative dns for dns #1 like 4.2.2.3 and see if that clears the error , if it does then the dns server that you were given is down or you were given the wrong info
Sep 23, 2009 | Sony Playstation 3 (PS3) Console
DynDns update fails
I have given a ref. configuration for you. If you could provide me the debug results it would be great to help you.
set dns ddns
set dns ddns id 1 server-type dyndns clear-text
set dns ddns id 1 username USERNAME password PASSWORD
set dns ddns id 1 src-interface untrust host-name HOSTNAME.dyndns.org
set dns ddns enable
Then try exec dns ddns id 1
Oct 09, 2008 | Juniper Networks NetScreen-5GT Plus...
Night Owl Optics Night Owl Scorpion 168500 Network DVR 16 Channels H264 500GB 8 Camera Logo
171 people viewed this question
Top Night Owl Optics Home Security Experts
Lawrence Oravetz
Domenico Grillo
Carlyle Houlder
Carlyle Houlder
Level 1 Expert
Are you a Night Owl Optics Home Security Expert? Answer questions, earn points and help others
