Question about Dryers
Instructions for transforma ladder - Dryers
Tip
Building your own ladder golf set
Building your own set for ladder golf is relatively easy and shouldn't take you too long. So you can be up and running in just a few hours.
You are going to need is 1" PVC pipe cut into 6 12-inch pieces and 9 24-inch pieces. You are also going to need 6 elbow fitting, 6 t-fittings. For the balls you are going to need 24 solid golf balls (2 sets of 12 in 2 different colors) and about 28 feet of nylon rope.
To building the ladder to form the base take 4 of the elbow fittings and two t-fitting and the 6 24-inch pipes. Connect the pipes to the elbows and the T's so that they flat side of the T is facing down. There should be an empty socket facing up. When you are finished you should have a rectangle that is 4ft by 2ft with 2 upward facing sockets to hold the ladder.
Next you want to build the ladder. Start by taking one of the remaining 24-inch pipes and attaching an elbow fitting to each end. Then attach a 12-inch pipe to the other side of the elbow. At the other end of the 12 inch pipe you are going to attach a t-fitting, continuing along the plane of the 12-inch pipes attach 2 more 12-inch pipes and in the cross plane attach a 24-inch pipe. Repeat this for the bottom step of the ladder. After you have attached the last pipe fit the open ends into the base and there you have your three step ladder for playing.
To make the balls you are going to need a drill to drill a hole through the center of the 24 balls. After you have drilled the holes in the balls take your nylon rope and measure and cut it into 12 20-inch pieces. It is suggested that you burn the ends of the rope so that they don't fray. Stick the rope through the holes and tie a knot on either side of the ball so they don't move. Put one ball on each end of the rope. You are going to need 6 ropes with 2 balls on each.
Once you have finished making the balls you are ready to play! Some play with each player on their own ladder, if you want to play that way you can follow these instructions again to build a second ladder or you can just use one.
on Oct 28, 2013 | Sport & Outdoor - Others
What is ladder golf?
Ladder golf is a tossing game played with a ladder placed about 15 feet from the player, and three sets of bolas (two golf balls connected by a string). The player has to toss the bolas to the ladder trying to get them hanging by the string to the ladder bar.
Here is a basic instructions video:
http://www.youtube.com/watch?v=sK6qBkBmF3U
Sep 24, 2013 | Sport & Outdoor - Others
What is a telescoping ladder?
Cynthia. The ladders Justin are referring to are not Telescoping Ladders. A telescopic ladder is one that collapses into itself like a telescope or a collapsible tumbler or "cup". Generally stands about 2-3' tall when completely collapsed and you can feed out as much of it as you need provided what you need in height isn't more than the ladders total length.
These ladders are GREAT and are typically used for inspections and cable installers. Some are rated for a fair amount of weight but I wouldn't trust it. We love using them and have been a great tool to have in the arsenal.
I have attached a photograph of one of our telescopic ladders.
Jan 23, 2013 | Tools & Hardware - Others
I have a monkey system #1 vinyl-clad swing set with no manual
http://www.kidwiseusa.com/catalog/product/gallery/image/1451/id/460/ I don't know if you can tell by this picture but it looks like the pole goes on the opposite side from the ladder and the rock ladder goes opposite the slide. How you mount the fireman's pole to the ground it unclear however.
866-KID-WISE is the manufacture's contact number
Mar 29, 2010 | Toys
Have a Jakks Pacific WWE Tables Ladders and Chairs and putting the set together. Problem is that the instructions doesnt specify on how to attach the ring ropes
Ok so what you need to do, and yes I am the real Jeff Hardy, but anyway you need to take the ring ropes and you will see the little attachments on the ringsides, hook the ropes up to that.
Dec 27, 2009 | JAKKS Pacific WWE Wrestling RAW Tables,...
Need instruction for a 17 ft. cosco ladder
Try going on-line to the manufacturers web site if there is one. More to the point is what is it you want to do that you can't with the ladder?
Dec 20, 2008 | Measuring Tools & Sensors
Dryers Logo
42 people viewed this question
Top Dryers Experts
