Question about Maytag Dryers
Specifications maytag lde8304ace dryer - Maytag Dryers
2 Suggested Answers
  • 40 Answers
SOURCE: Maytag Dryer lde8304ace Something is causing it
squealing is usually caused by either the drum support rollers or the idler pulley,dryer must be taken apart parts inspected,replaced if needed,cleaned and lubricated with turbine oil
Posted on Jan 25, 2010
How do i disassemble the Maytag dryer model MDW9700AZW to replace the front felt seal?
I don't know about your specific model, but there are videos on youtube that might help you and give you an idea about how to disassemble yours.
Nov 17, 2016 | Maytag Dryers
Is this a reliable product? what is the retail cost?
Electric Dryer (MED9600SQ ) ' - Maytag
www.maytag.com/-[MED9600SQ]-1102962/MED9600SQ/
MaytagLearn about features and specifications for the Maytag Electric Dryer (MED9600SQ ) ... Manuals & Literature; Product Help; Parts & Accessories; Features ...
Maytag MDE7600 Electric Dryer - E-Opinions
www.eopinions.com/search/dryers/price...maytag.../1893?...
125 results like Maytag MDE7600 Electric Dryer Maytag MDG8500 Dryer ... ProductFeatures: Power Source: Electric; Dryer Type: Home Dryer; Load Type: .... Maytag MED9600S Electric Dryer ... Durable and dependable features in this dryer representMaytag brands committment to uncompromising strength and reliability.
Jan 11, 2016 | Maytag MED9600S Electric Dryer
How do i replace the drum belt on mayag LDE8304ACE ?
Hi Alan Payne
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley,faulty capacitor, or a faulty motor.
Note: This method works for most front loading machines.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Remove the electrical console that holds the timer switch,start switch, etc. from the top of the dryer if necessary. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the two screws that hold the filter housing to the top of the dryer lid.
Then remove the top of the dryer by inserting a screwdriver between the top and frame on each side of the dryer to pop the lid up from the retaining clips.
Note: Some of the tops tilt backwards on a type of hinge and do not have to be removed completly.
Remove the front of the machine by disconnecting the door switch and removing the two screws located on either side of the dryer frame.
Move the door and front of machine forward to remove.
This will expose the belt,idler bracket and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor pulley.
Here is a link to see a picture of your belt routing in case the belt is broken when you open your dryer:
http://www.expertappliance.com/dryerbeltconfiguration.html
While you have the drum out, I would recommend that you remove and lubricate the drum rollers.
And also clean the shafts of the rollers as they will collect hair,dust,etc and cause problems and then lubricate the shafts and rollers with a good grade of machine oil like 3 in One oil or a vasoline type of lubricant. This will save you a problem later with the rollers getting dry and making a squeeling noise, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise.
You will need to replace the drum rollers if they have flat spots on them.
You can see a picture/schematic of you dryer by going to the following webpage.
Please take time to rate me
Bud
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=26329&diagram_id=28443880#d28443880
Oct 08, 2012 | Maytag Dryers
Maytag electric dryer is making a high pitched noise
The squealing noise is from the belt tensioner. Replace the pulley only on the tensioner along with a new belt. The bearing in the pulley is causing the squeal. Sears will sell this in a kit. The top and the front panel of the dryer will have to be removed to replace these parts
Jul 16, 2010 | Maytag Dryers
How do you change the air flow from the back to the side? maytag preforma
inspect the dryer sides,and see if there is a knockout to remov to allow side venting,some dryers are not side ventable,if the knockouts are there, you may need a kit from maytag specifically for that model...the installation instructions may be helpful if you have them,could provide kit no.,and the how to instruct.
Mar 06, 2010 | Dryers
Maytag Dryer lde8304ace Something is causing it to squel.
Jan 25, 2010 | Washing Machines
Convert Natural Gas Dryer to LP Gas
A dryer is a dryer. Most cases they all work the same. You will need to get an LP conversion kit for that model to complete the task.
Jan 25, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
What is the capacity of the maytag neptune mdg4000aw
motor 1/2 horse power,,,electrical,,120 60 hz,,15 amp breaker needed,,weight 160 lbs,,,capacity 3.2 cubic feet..about 26 pounds...onthe job
Jan 18, 2009 | Maytag Dryers
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
